    Mouse functions windows 8.1
    6 Posts 3 Posters 652 Views 3 Watching
    • PatrickDP Offline
      PatrickD
      My pan and orbit mouse functions have stopped working in Sketchup 2015 (Make version).
      It worked fine after I installed SU but stopped suddenly. This was after I inserted a component during a drawing session. Any ideas on how I can get these functions back? Pan and orbit work fine when selected from the menu but I have to exit before going to the next command. The mouse wheel works fine for zooming.
      Any advice appreciated.
      Many thanks
        It's unlikely to have anything to do with inserting a component. I expect that's coincidental.
        Have you checked mouse settings? What kind of mouse is it? What assignment is selected for the center mouse button? Have you checked to see that the center mouse button works in some other application? I've had the CMB fail on mice in the past.
        • PatrickDP Offline
          PatrickD
          Hi Dave
          Don't you ever sleep !! ๐Ÿ˜ฎ))
          Thanks for getting back. The mouse is a Logitech standard two buuton + wheel. I have tried another mouse (both fairly new)whith the same result. I have re-installed SU but no change. As I say when first installed everything was hunkydory. The mouse works as it should in other applications. Bit of a mystery, guess I maybe stuck with shortcuts for the immediate future. Lucky I've retired so there's no pressure on my output!
          Thanks once again.
          Regards
          P
            Not much. ๐Ÿ˜ข ๐Ÿ˜›
            Did you install the Logitech mouse driver software? If so, I think you should be able to find assignment options for the mouse buttons in Control Panel>Mouse. Check to see what assigment has been given to the center mouse button.
            • BoxB Offline
              Often the logitech drivers can be the problem. It can be better to run the mouse with the default win drivers.
              • PatrickDP Offline
                PatrickD
                Hi Box
                Thanks for that, worth checking out.
