    3D Truss Models
    1.5k Posts 31 Posters 947.1k Views 30 Watching
    • jujuJ Offline
      juju
      @jemagnussen said:
      Would you consider a metric version in the near future? It would be very helpfull to the "metric world" of designers.
      Jesper
      yes please! also the pitch of the truss in degrees instead of the x-in-12 system.
      • medeekM Offline
        medeek
        @jemagnussen said:
        Hi Medeek,
        Super plugin, just bought it... πŸ˜„
        Best regards
        Jesper
        I don't think a metric version would be too hard to create. It would be cool if I could somehow have a configuration file of sorts so that imperial or metric could be semi-permanent setting that can be switched within SketchUp. Not really sure how to do this within the API but I will add that to the todo list.
        I'm assuming the units of interest would be millimeters, correct me if I'm wrong. I think I will also open up the pitch variable so any pitch can be chosen instead of limiting it. I would also like have it in the settings where someone can manage the default values and choose between degrees or x/12 for the pitch.
        I'm not really familiar with the metric lumber sizes. Would you want the variable completely open or limited to certain metric standard sizes?
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • jujuJ Offline
          juju
          can it not reference the sketchup session to see which units are being used and then use that?
          • jemagnussenJ Offline
            jemagnussen
            Hi again,
            JuJu's proposal of using the units being used by Sketchup would be the most intuitive. For using standard sizes I would imagine that an open approach would suit most users.
            Best regards
            Jesper
            HP ZBook 15, Windows 10 64 bit
            Intel Core i7-6820HQ @ 2.70GHz
            32 GB Ram
            NVIDIA Quadro M2000M
            • medeekM Offline
              medeek
              It's kind of funny how everyone else in the world is metric yet the USA is still using the old English units.
              design.medeek.com
              • medeekM Offline
                medeek
                Howe truss type is now active.
                The latest plugin version is 1.0.4. I would highly recommend downloading the latest version since I have also spent some time this morning cleaning up my code and removing global methods and variables so that I don't clash with other extensions or modules.
                http://design.medeek.com/resources/images/truss_su7_800.jpg
                design.medeek.com
                • medeekM Offline
                  medeek
                  Monopitch trusses are also now live:
                  http://design.medeek.com/resources/images/truss_su8_800.jpg
                  Currently the 2/2 and 3/3 configurations are available, more of this truss family will be added after I address the metric issue and a few of the other requested items.
                  design.medeek.com
                  • jujuJ Offline
                    juju
                    thanks for the active development, looking forward to the metric version
                    • jujuJ Offline
                      juju
                      If I may list a request, the way your tool currently works seems fine, but it could be more helpful (faster modeling) if one had the option of indicating the area of the trusses (with it auto-calculating the truss centers, with a maximum parameter setting) much in the same way tomot's truss tool does it.
                      *** EDIT ***
                      and maybe a quick launch icon that one can locate on the toolbar?
                      • medeekM Offline
                        medeek
                        Currently I am dumping the trusses at the origin (0,0,0) since that seemed like the most natural thing to do but I can see where a more intuitive placement system makes more sense and would eliminate the additional steps needed to move the array of trusses into place and possibly rotating them.
                        I like the idea of selecting a rectangle which auto-sizes and orients the trusses.
                        Adding a quick launch icon should not be too much trouble either.
                        design.medeek.com
                        • pbacotP Offline
                          You're on fire! Good work.
                          • medeekM Offline
                            medeek
                            I've added a toolbar/icon which admittedly is more convenient than having to open up the extensions menu item.
                            I'm not entirely sure I'm happy with the icon set I've created but it is really hard to make much of a 24x24 or 16x16 square.
                            http://design.medeek.com/calculator/sketchup/images/mdkplg_tool_icon16_2.png
                            http://design.medeek.com/calculator/sketchup/images/mdkplg_tool_icon24_2.png
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I'm looking at adding in scissor trusses. Below is a matrix of common scissor truss configurations. Once they get much larger than a 6/6 I think they probably go to site assembled half trusses, I'm not entirely sure since I don't have any drawings or diagrams of anything larger than a 6/6.
                              http://design.medeek.com/images/MISC/scissortrusses1024.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                For the common truss types I've configured the plugin to detect the SketchUp template units and display a metric UI. I've also replaced the x/12 system with degrees for the metric interface. All member sizes and other dimensions are open for the metric interface as well.
                                Go ahead and give it a whirl, if it checks out then I will go ahead and update the attic and monopitch UI with the metric option.
                                design.medeek.com
                                • jujuJ Offline
                                  juju
                                  Hi Nathaniel, wow, I'm loving the progress and response time.
                                  Icons: they seem easily recognizable enough, they should do fine
                                  Truss configurations: excellent news! this plugin is getting better by the day
                                  Unit: so the metric is implemented and live? Seems like I'll be parting with some money soon, even though I bought tomot's tool previously, the way this is developing (and the options offered by it) I'll definitely be interested in getting the paid tool instead of the trial version.
                                  thanks!
                                  • jujuJ Offline
                                    juju
                                    @juju said:
                                    Seems like I'll be parting with some money soon...
                                    say hello to order #13, thanks.
                                    • medeekM Offline
                                      medeek
                                      Wow. South Africa. Now I can say my customer base is worldwide. Thank-you for the support.
                                      Hopefully the plugin does not disappoint.
                                      There are so many things one can do with this it is almost overwhelming.
                                      I was looking at gable end trusses last night and beyond the typical gable end truss you would have the option for a dropped top chord as well as structural gable end trusses.
                                      Then there is all the variants and configurations associated with hip roofs that need attention (ie. California Style Hip Set.).
                                      Send in the requests and I'll work on them as time allows.
                                      design.medeek.com
                                      • jujuJ Offline
                                        juju
                                        @studio43 said:
                                        I looked for the download button to get the latest version. All I can see is an option to "trial" and "Buy". Do I have to purchase the most up to date version after I already bought ver 1.0?
                                        Interesting question, I'd be interested to know how long upgrades will be available for as well. However, in order to buy the plugin you have to register a user account on the site, from there you can access the product (-s) you've purchased, so my guess will be that updates will be accessed/downloaded from there.
                                        • studio43S Offline
                                          studio43
                                          I looked for the download button to get the latest version. All I can see is an option to "trial" and "Buy". Do I have to purchase the most up to date version even though I currently own a copy of version 1.0.0?
                                          • medeekM Offline
                                            medeek
                                            To get the latest version login to the Account Manager here:
                                            Medeek Design Inc. - Login
                                            (design.medeek.com)
                                            Click on the plugin link.
                                            Your order number and data will appear, click on the order number, then click on the Download Now button, this will be the latest version.
                                            All licenses currently purchased are permanent, this means you are entitled to all upgrades in the future. At some point I may move to a yearly license so that those licenses will only entitle the user 1 year of upgrades and then after that they will be required to purchase an upgrade to get the latest version. I don't want to make the licensing a burden to the users but I also want to be fair to myself if I spend alot of time and effort adding in more trusses and features.
                                            You will notice that the License type in the Account Manager lists the License as permanent. This license and order is associated with your Client ID in the database. As long as you have access to your Client ID and can login you have access to the latest plugin.
                                            design.medeek.com
                                            • 75
                                            • 76
                                            • 3 / 76
