    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      Thank-you for bringing me up to speed. I'm still wrapping my head around SketchUp, as most of my experience is with AutoCAD. I didn't even realize that SketchUp had the ability for "blocks", very cool.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • studio43S
        studio43
        I purchased the plugin How do I download the most current version?
        • medeekM
          medeek
          You can always grab the latest version in the Medeek Account Manager, Login and navigate to the plugin page, the download button will have the latest version.
          I'm working on the group/component issue and hopefully should have that up later today.
          SketchUp is actually pretty full featured, I'm pleasantly surprised.
          design.medeek.com
          • medeekM
            medeek
            Trusses are now created as components with each individual member of the truss a group. Arrays of trusses are multiple instances of the same component.
            I think this plugin may actually have some potential now.
            A couple more screenshots for fun. A well designed truss is a beautiful thing to behold:
            http://design.medeek.com/resources/images/truss_su5_800.jpg
            http://design.medeek.com/resources/images/truss_su6_800.jpg
            I really appreciate everyone's feedback, this has helped guide me in the right direction on all of this and improved my understanding of SketchUp immensely.
            design.medeek.com
            • jemagnussenJ
              jemagnussen
              Hi Medeek,
              Super plugin, just bought it... πŸ˜„
              Would you consider a metric version in the near future? It would be very helpfull to the "metric world" of designers.
              Best regards
              Jesper
              HP ZBook 15, Windows 10 64 bit
              Intel Core i7-6820HQ @ 2.70GHz
              32 GB Ram
              NVIDIA Quadro M2000M
              • jujuJ
                juju
                Jesper
                yes please! also the pitch of the truss in degrees instead of the x-in-12 system.
                • medeekM
                  medeek
                  @jemagnussen said:
                  Hi Medeek,
                  Best regards
                  Jesper
                  I don't think a metric version would be too hard to create. It would be cool if I could somehow have a configuration file of sorts so that imperial or metric could be semi-permanent setting that can be switched within SketchUp. Not really sure how to do this within the API but I will add that to the todo list.
                  I'm assuming the units of interest would be millimeters, correct me if I'm wrong. I think I will also open up the pitch variable so any pitch can be chosen instead of limiting it. I would also like have it in the settings where someone can manage the default values and choose between degrees or x/12 for the pitch.
                  I'm not really familiar with the metric lumber sizes. Would you want the variable completely open or limited to certain metric standard sizes?
                  design.medeek.com
                  • jujuJ
                    juju
                    can it not reference the sketchup session to see which units are being used and then use that?
                    • jemagnussenJ
                      jemagnussen
                      Hi again,
                      JuJu's proposal of using the units being used by Sketchup would be the most intuitive. For using standard sizes I would imagine that an open approach would suit most users.
                      Best regards
                      Jesper
                      32 GB Ram
                      • medeekM
                        medeek
                        It's kind of funny how everyone else in the world is metric yet the USA is still using the old English units.
                        design.medeek.com
                        • medeekM
                          medeek
                          Howe truss type is now active.
                          The latest plugin version is 1.0.4. I would highly recommend downloading the latest version since I have also spent some time this morning cleaning up my code and removing global methods and variables so that I don't clash with other extensions or modules.
                          http://design.medeek.com/resources/images/truss_su7_800.jpg
                          design.medeek.com
                          • medeekM
                            medeek
                            Monopitch trusses are also now live:
                            http://design.medeek.com/resources/images/truss_su8_800.jpg
                            Currently the 2/2 and 3/3 configurations are available, more of this truss family will be added after I address the metric issue and a few of the other requested items.
                            design.medeek.com
                            • jujuJ
                              juju
                              thanks for the active development, looking forward to the metric version
                              • jujuJ
                                juju
                                If I may list a request, the way your tool currently works seems fine, but it could be more helpful (faster modeling) if one had the option of indicating the area of the trusses (with it auto-calculating the truss centers, with a maximum parameter setting) much in the same way tomot's truss tool does it.
                                *** EDIT ***
                                and maybe a quick launch icon that one can locate on the toolbar?
                                • medeekM
                                  medeek
                                  Currently I am dumping the trusses at the origin (0,0,0) since that seemed like the most natural thing to do but I can see where a more intuitive placement system makes more sense and would eliminate the additional steps needed to move the array of trusses into place and possibly rotating them.
                                  I like the idea of selecting a rectangle which auto-sizes and orients the trusses.
                                  Adding a quick launch icon should not be too much trouble either.
                                  design.medeek.com
                                  • pbacotP
                                    You're on fire! Good work.
                                    • medeekM
                                      medeek
                                      I've added a toolbar/icon which admittedly is more convenient than having to open up the extensions menu item.
                                      I'm not entirely sure I'm happy with the icon set I've created but it is really hard to make much of a 24x24 or 16x16 square.
                                      http://design.medeek.com/calculator/sketchup/images/mdkplg_tool_icon16_2.png
                                      http://design.medeek.com/calculator/sketchup/images/mdkplg_tool_icon24_2.png
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        I'm looking at adding in scissor trusses. Below is a matrix of common scissor truss configurations. Once they get much larger than a 6/6 I think they probably go to site assembled half trusses, I'm not entirely sure since I don't have any drawings or diagrams of anything larger than a 6/6.
                                        http://design.medeek.com/images/MISC/scissortrusses1024.jpg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          For the common truss types I've configured the plugin to detect the SketchUp template units and display a metric UI. I've also replaced the x/12 system with degrees for the metric interface. All member sizes and other dimensions are open for the metric interface as well.
                                          Go ahead and give it a whirl, if it checks out then I will go ahead and update the attic and monopitch UI with the metric option.
                                          design.medeek.com
                                          • jujuJ
                                            juju
                                            Hi Nathaniel, wow, I'm loving the progress and response time.
                                            Icons: they seem easily recognizable enough, they should do fine
                                            Truss configurations: excellent news! this plugin is getting better by the day
                                            Unit: so the metric is implemented and live? Seems like I'll be parting with some money soon, even though I bought tomot's tool previously, the way this is developing (and the options offered by it) I'll definitely be interested in getting the paid tool instead of the trial version.
                                            thanks!
                                            • 76
                                            • 77
                                            • 3 / 77
