    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • jemagnussenJ
      jemagnussen
      Hi Medeek,
      Super plugin, just bought it... πŸ˜„
      Would you consider a metric version in the near future? It would be very helpfull to the "metric world" of designers.
      Best regards
      Jesper
      HP ZBook 15, Windows 10 64 bit
      Intel Core i7-6820HQ @ 2.70GHz
      32 GB Ram
      NVIDIA Quadro M2000M
      • jujuJ
        juju
        Jesper
        yes please! also the pitch of the truss in degrees instead of the x-in-12 system.
        • medeekM
          medeek
          @jemagnussen said:
          Hi Medeek,
          Best regards
          Jesper
          I don't think a metric version would be too hard to create. It would be cool if I could somehow have a configuration file of sorts so that imperial or metric could be semi-permanent setting that can be switched within SketchUp. Not really sure how to do this within the API but I will add that to the todo list.
          I'm assuming the units of interest would be millimeters, correct me if I'm wrong. I think I will also open up the pitch variable so any pitch can be chosen instead of limiting it. I would also like have it in the settings where someone can manage the default values and choose between degrees or x/12 for the pitch.
          I'm not really familiar with the metric lumber sizes. Would you want the variable completely open or limited to certain metric standard sizes?
          Nathaniel P. Wilkerson PE
          Medeek Engineering Inc
          design.medeek.com
          • jujuJ
            juju
            can it not reference the sketchup session to see which units are being used and then use that?
            • jemagnussenJ
              jemagnussen
              Hi again,
              JuJu's proposal of using the units being used by Sketchup would be the most intuitive. For using standard sizes I would imagine that an open approach would suit most users.
              Best regards
              Jesper
              32 GB Ram
              • medeekM
                medeek
                It's kind of funny how everyone else in the world is metric yet the USA is still using the old English units.
                design.medeek.com
                • medeekM
                  medeek
                  Howe truss type is now active.
                  The latest plugin version is 1.0.4. I would highly recommend downloading the latest version since I have also spent some time this morning cleaning up my code and removing global methods and variables so that I don't clash with other extensions or modules.
                  http://design.medeek.com/resources/images/truss_su7_800.jpg
                  design.medeek.com
                  • medeekM
                    medeek
                    Monopitch trusses are also now live:
                    http://design.medeek.com/resources/images/truss_su8_800.jpg
                    Currently the 2/2 and 3/3 configurations are available, more of this truss family will be added after I address the metric issue and a few of the other requested items.
                    design.medeek.com
                    • jujuJ
                      juju
                      thanks for the active development, looking forward to the metric version
                      • jujuJ
                        juju
                        If I may list a request, the way your tool currently works seems fine, but it could be more helpful (faster modeling) if one had the option of indicating the area of the trusses (with it auto-calculating the truss centers, with a maximum parameter setting) much in the same way tomot's truss tool does it.
                        *** EDIT ***
                        and maybe a quick launch icon that one can locate on the toolbar?
                        • medeekM
                          medeek
                          Currently I am dumping the trusses at the origin (0,0,0) since that seemed like the most natural thing to do but I can see where a more intuitive placement system makes more sense and would eliminate the additional steps needed to move the array of trusses into place and possibly rotating them.
                          I like the idea of selecting a rectangle which auto-sizes and orients the trusses.
                          Adding a quick launch icon should not be too much trouble either.
                          design.medeek.com
                          • pbacotP
                            You're on fire! Good work.
                            • medeekM
                              medeek
                              I've added a toolbar/icon which admittedly is more convenient than having to open up the extensions menu item.
                              I'm not entirely sure I'm happy with the icon set I've created but it is really hard to make much of a 24x24 or 16x16 square.
                              http://design.medeek.com/calculator/sketchup/images/mdkplg_tool_icon16_2.png
                              http://design.medeek.com/calculator/sketchup/images/mdkplg_tool_icon24_2.png
                              design.medeek.com
                              • medeekM
                                medeek
                                I'm looking at adding in scissor trusses. Below is a matrix of common scissor truss configurations. Once they get much larger than a 6/6 I think they probably go to site assembled half trusses, I'm not entirely sure since I don't have any drawings or diagrams of anything larger than a 6/6.
                                http://design.medeek.com/images/MISC/scissortrusses1024.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  For the common truss types I've configured the plugin to detect the SketchUp template units and display a metric UI. I've also replaced the x/12 system with degrees for the metric interface. All member sizes and other dimensions are open for the metric interface as well.
                                  Go ahead and give it a whirl, if it checks out then I will go ahead and update the attic and monopitch UI with the metric option.
                                  design.medeek.com
                                  • jujuJ
                                    juju
                                    Hi Nathaniel, wow, I'm loving the progress and response time.
                                    Icons: they seem easily recognizable enough, they should do fine
                                    Truss configurations: excellent news! this plugin is getting better by the day
                                    Unit: so the metric is implemented and live? Seems like I'll be parting with some money soon, even though I bought tomot's tool previously, the way this is developing (and the options offered by it) I'll definitely be interested in getting the paid tool instead of the trial version.
                                    thanks!
                                    • jujuJ
                                      juju
                                      @juju said:
                                      Seems like I'll be parting with some money soon...
                                      say hello to order #13, thanks.
                                      • medeekM
                                        medeek
                                        Wow. South Africa. Now I can say my customer base is worldwide. Thank-you for the support.
                                        Hopefully the plugin does not disappoint.
                                        There are so many things one can do with this it is almost overwhelming.
                                        I was looking at gable end trusses last night and beyond the typical gable end truss you would have the option for a dropped top chord as well as structural gable end trusses.
                                        Then there is all the variants and configurations associated with hip roofs that need attention (ie. California Style Hip Set.).
                                        Send in the requests and I'll work on them as time allows.
                                        design.medeek.com
                                        • jujuJ
                                          juju
                                          @studio43 said:
                                          I looked for the download button to get the latest version. All I can see is an option to "trial" and "Buy". Do I have to purchase the most up to date version after I already bought ver 1.0?
                                          Interesting question, I'd be interested to know how long upgrades will be available for as well. However, in order to buy the plugin you have to register a user account on the site, from there you can access the product (-s) you've purchased, so my guess will be that updates will be accessed/downloaded from there.
                                          • studio43S
                                            studio43
                                            I looked for the download button to get the latest version. All I can see is an option to "trial" and "Buy". Do I have to purchase the most up to date version even though I currently own a copy of version 1.0.0?
                                            • 76
                                            • 77
                                            • 3 / 77
