    Challenge - Model this unique chair
    21 Posts 10 Posters 3.4k Views 10 Watching
    • pbacotP
      Very nice and super realistic rendering. Is every angle different (besides mirroring)?
      • TaffGochT
        TaffGoch
        Of course it looks realistic -- It's a photograph of the actual chair!
        (pbacot, I had to laugh. Sorry.)
        And yes, multiple angles, of unspecified degree.
        -Taff
        "Information is not knowledge." -- Albert Einstein
        • pbacotP
          I didn't read down far enough. Figured you already knocked it out. Now you really have to make it just as realistic.
          • cottyC
            cotty
            My approach for this nice chair...
            • one component
            • arc tool
            • scale tool
            • circle tool
            • rotation tool
            • mirror plugin
            The rotational part was done with some helping circles like this...
            (After it was finished, I've realized that another rotation point in the center of the boards would have been better...)
            rising_chair_cotty.zip
            my SketchUp gallery
            • HornOxxH
              HornOxx
              Taff, that´s a great task!
              I also thought at first, that´s a rendering :- ))
              Cotty - your presentation is overwhelming! 👍
              never trust a skinny cook
              • alvisA
                alvis
                I agree completely!
                • cottyC
                  cotty
                  Thank you. I've thought about a SketchyPhsics solution which allows the animation of the movement, but I haven't enough time for this...
                  I would love to see other (faster?) attempts here too!
                  my SketchUp gallery
                  • BoxB
                    Couldn't agree with you more Cotty on the Sketchy Physics idea, hit me as soon as I looked at it. If I can get off this phone and Win8 tablet back to an old laptop that still has 2014 I'll knock one up. I can already picture a flat wall of slats falling into a chair position.
                      driven
                      I like the concept and will make a model when I get a moment [or many...]
                      in the meanwhile I did a Visualizer run on Cotty's version...
                      came out nice so thought I'd post it...
                      yes it a quick render of cotty's chair...
                      • cottyC
                        cotty
                        Nice, John!
                        A version with texture (same for all component copies, a little bit repetitive 😉 )...
                        my SketchUp gallery
                        • TaffGochT
                          TaffGoch
                          • one component
                          • arc tool
                          • scale tool
                          • circle tool
                          • rotation tool
                          • mirror plugin
                          Commendations, cotty!  Your method is precisely the approach that I took. (Nice, concise presentation, by the way.)
                          For the confused, the "trick" was to look for additional online photos, to find the "slab" mounted on the wall (or lying on the floor.)  I imported a "slab" photo, as a texture, which I formatted to correct the perspective distortion. That one image provides the relative lengths of all the parts.
                          http://www.designboom.com/cms/images/user_submit/2011/04/copy_0_dsc03238.jpg
                          Getting the footprint "spread" (distance, front-to-back)  is, then, the only factor requiring some trial-and-error. Even then, there is a clue in the first photo. (Look for the two front stiles that are near vertical.)
                          Well, I have to say that, apparently, the challenge wasn't much of a skills test, for you insightful sketchUcation members. Regardless, I hope that, if you haven't yet given it a try, that you will -- adding something of value to your skill set.
                          (I agree with other participants, that an animated depiction would be nice to see.)
                          -Taff
                          'Rising' Chair - RobertVanEmbricqs.skp
                          • cottyC
                            cotty
                            Thank you. Your smaller (drawn to scale) wooden slats looks much nicer and the sitting angle seems to be more comfortable.
                            Thank you again for this challenge.
                            my SketchUp gallery
                              Nicely done Taff, thanks for making the model available to us. Very generous.
                              • BoxB
                                As promised,
                                How to make a slab of timber batons into a nice chair, the Sketchy Physics method.
                                • HornOxxH
                                  HornOxx
                                    THX to Taff Goch! 😎
                                    Any idea of the real articulation on the Up part moving corner ?
                                    Pasted scotch, velchro double face, hinge, ... ?
                                    Ps Funny: materials seems French fries! 💚
                                      'Pilou
                                      It's hinged.
                                      The metal [stainless-steel?] hinges are set flush into the wood.
                                      They are on the back-side of the folded-flat version - you do not see them unless it's assembled, and even then they are underneath the wooden pieces.
                                        driven
                                        closer look...
                                          Thx for the info! 👍
                                          Seems a dangerous chair for hands' children or old person! 😉
                                          • TaffGochT
                                            TaffGoch
                                            I would add, "fragile" and "unstable," as well.
                                            There is no lateral (side-to-side)  connection, except at the floor "hinge." Any lateral force, up top, will bend and/or break things, down below.
                                            Attractive visually, but needs some serious real-world engineering to make it practical furniture.
                                            All I can think to say,Box, is that your posted image is, indeed, an animation. 😒
                                            -Taff
