    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 199.0k Views 13 Watching
    • olisheaO
      olishea
      OK I will have another go. I am using both PC and Mac...just to confuse you! πŸ˜„
      oli
      • olisheaO
        olishea
        I am just using my Mac at the moment to have a play....but I am still confused.
        I have pasted the script into the commands folder.
        Opened up MOI.
        Added shortcut.
        Then I get the error message? I am simply subdividing a cube for this test.
        oli
          Try with _subdiv_beta6 as you have in your list's files πŸ’š
          Sorry for the confusion, i had changed my name of file! 😳
          After the writing name, of course Enter! πŸ€“
          Ps Of course you can make a Copy / Past of this name file from a Text file of numerous scripts!
          (because install more "easy" is some time losted at the beginning : play first with the toy) 😎
          I have these Shortcuts for the "subdivision" modeling process)
          • olisheaO
            olishea
            yes pilou! good spot!
            thanks for the advice. I am loving MOI so far!
            oli
              yes, it's a true gem πŸ˜„
              New version of the _array3d πŸ˜‰ speed*2!
              • olisheaO
                olishea
                Nice! I got Subdivision to work thanks very much mate!
                I just need to work out how well a subdivided solid exports.....when I export to OBJ or STL it seems to go quite jagged even at high resolution/poly.
                oli
                  Example, image, files ? πŸ’š
                  • olisheaO
                    olishea
                    It's OK I'll sort it out. All the mesh previews look unsmoothed when uploaded to the 3D printing websites. It's more noticeable in the first image....it could be because i'm trying to subdivide and then punch holes/fillet afterwards and it causes a messy mesh. The fillets are a different resolution to the subdivided mesh so some conflict will occur. I'll get there I'm just being silly. πŸ˜„
                    oli
                      File 3DM?
                      In waiting a little tut by Chipp Walters
                            VoronoΓ― Diagram by Max Smirnov
                            Select Voronoi: Name it, Select Polygon: name it
                            Select Voronoi's lines
                            Call Boolean Inter
                            Click Polygon
                            Et voilΓ ! πŸ˜„
                            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/570504_orig.jpg
                            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3263482_orig.gif
                            • olisheaO
                              olishea
                              does it work in 3D?! πŸ˜„
                              oli
                                You can make yet some things with it! πŸ˜‰ (and it's work in progress! ) πŸ€“
                                • olisheaO
                                  olishea
                                  There is a [ missing from your link mate
                                  One day, i swear, there will be a plugin where you just click "apply pattern" and then BOOM it's done! Whatever voronoi/tessellation you like. Just couple of clicks!! One day!!! πŸ˜„
                                  oli
                                      FatLines by Max Smirnov
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1939476_orig.jpg
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/4303546_orig.jpg
                                        Delcorners by Max Smirnov
                                        Voronoi, Delcorners, Flow
                                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/250183_orig.jpg
                                        • olisheaO
                                          olishea
                                          Smirnov is on fire! wow!
                                          oli
                                            New version of Subdivision by Max! πŸ˜‰
                                            (Trick for volumes with difficulties like here : export as OBJ with triangles
                                            then _importObj (By Max πŸ˜‰
                                            and voilΓ !
                                            http://s6.postimg.org/rq8zqot1t/beta7.jpg
                                            • 11
                                            • 6 / 11
