    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 188.2k Views 13 Watching
    • olisheaO
      olishea
      this guy is firing out some impressive plugins isnt he!
      oli
      • olisheaO
        olishea
        the subdivide plugin is exactly what i needed!
        oli
          SUbdivision
          Will work fine with Bridge, Split πŸ˜‰
          New version of Array 3D : Random, Base/ target
          • olisheaO
            olishea
            OK I got all the scripts installed, time to have some fun!
            I put the scripts in the command folder but I can't see them anywhere when I open MOI? There are no buttons/icons?
            I feel like a newb again! πŸ˜„
            oli
              You can make 2 things! πŸ˜„ (if you have a PC ? )
              Press Tab and write the name of the plugin!
              Here the subdiv's name script is _Subdiv_6 (no sensitive case)
              Or make a shortcut ! Menu Options (bottom screen) / ShortCuts
              Put in the left column any combinaison of keys
              and on the right column _Subdiv_6 πŸ€“
              Have fun modeling !
              • olisheaO
                olishea
                OK I will have another go. I am using both PC and Mac...just to confuse you! πŸ˜„
                oli
                • olisheaO
                  olishea
                  I am just using my Mac at the moment to have a play....but I am still confused.
                  I have pasted the script into the commands folder.
                  Opened up MOI.
                  Added shortcut.
                  Then I get the error message? I am simply subdividing a cube for this test.
                  oli
                    Try with _subdiv_beta6 as you have in your list's files πŸ’š
                    Sorry for the confusion, i had changed my name of file! 😳
                    After the writing name, of course Enter! πŸ€“
                    Ps Of course you can make a Copy / Past of this name file from a Text file of numerous scripts!
                    (because install more "easy" is some time losted at the beginning : play first with the toy) 😎
                    I have these Shortcuts for the "subdivision" modeling process)
                    • olisheaO
                      olishea
                      yes pilou! good spot!
                      thanks for the advice. I am loving MOI so far!
                      oli
                        yes, it's a true gem πŸ˜„
                        New version of the _array3d πŸ˜‰ speed*2!
                        • olisheaO
                          olishea
                          Nice! I got Subdivision to work thanks very much mate!
                          I just need to work out how well a subdivided solid exports.....when I export to OBJ or STL it seems to go quite jagged even at high resolution/poly.
                          oli
                            Example, image, files ? πŸ’š
                            • olisheaO
                              olishea
                              It's OK I'll sort it out. All the mesh previews look unsmoothed when uploaded to the 3D printing websites. It's more noticeable in the first image....it could be because i'm trying to subdivide and then punch holes/fillet afterwards and it causes a messy mesh. The fillets are a different resolution to the subdivided mesh so some conflict will occur. I'll get there I'm just being silly. πŸ˜„
                              oli
                                File 3DM?
                                In waiting a little tut by Chipp Walters
                                      VoronoΓ― Diagram by Max Smirnov
                                      Select Voronoi: Name it, Select Polygon: name it
                                      Select Voronoi's lines
                                      Call Boolean Inter
                                      Click Polygon
                                      Et voilΓ ! πŸ˜„
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/570504_orig.jpg
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3263482_orig.gif
                                      • olisheaO
                                        olishea
                                        does it work in 3D?! πŸ˜„
                                        oli
                                          You can make yet some things with it! πŸ˜‰ (and it's work in progress! ) πŸ€“
                                          • olisheaO
                                            olishea
                                            There is a [ missing from your link mate
                                            One day, i swear, there will be a plugin where you just click "apply pattern" and then BOOM it's done! Whatever voronoi/tessellation you like. Just couple of clicks!! One day!!! πŸ˜„
                                            oli
                                            • 11
                                            • 6 / 11
