    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 199.0k Views 13 Watching
    • olisheaO
      olishea
      the subdivide plugin is exactly what i needed!
      oli
        SUbdivision
        Will work fine with Bridge, Split πŸ˜‰
        New version of Array 3D : Random, Base/ target
        • olisheaO
          olishea
          OK I got all the scripts installed, time to have some fun!
          I put the scripts in the command folder but I can't see them anywhere when I open MOI? There are no buttons/icons?
          I feel like a newb again! πŸ˜„
          oli
            You can make 2 things! πŸ˜„ (if you have a PC ? )
            Press Tab and write the name of the plugin!
            Here the subdiv's name script is _Subdiv_6 (no sensitive case)
            Or make a shortcut ! Menu Options (bottom screen) / ShortCuts
            Put in the left column any combinaison of keys
            and on the right column _Subdiv_6 πŸ€“
            Have fun modeling !
            • olisheaO
              olishea
              OK I will have another go. I am using both PC and Mac...just to confuse you! πŸ˜„
              oli
              • olisheaO
                olishea
                I am just using my Mac at the moment to have a play....but I am still confused.
                I have pasted the script into the commands folder.
                Opened up MOI.
                Added shortcut.
                Then I get the error message? I am simply subdividing a cube for this test.
                oli
                  Try with _subdiv_beta6 as you have in your list's files πŸ’š
                  Sorry for the confusion, i had changed my name of file! 😳
                  After the writing name, of course Enter! πŸ€“
                  Ps Of course you can make a Copy / Past of this name file from a Text file of numerous scripts!
                  (because install more "easy" is some time losted at the beginning : play first with the toy) 😎
                  I have these Shortcuts for the "subdivision" modeling process)
                  • olisheaO
                    olishea
                    yes pilou! good spot!
                    thanks for the advice. I am loving MOI so far!
                    oli
                      yes, it's a true gem πŸ˜„
                      New version of the _array3d πŸ˜‰ speed*2!
                      • olisheaO
                        olishea
                        Nice! I got Subdivision to work thanks very much mate!
                        I just need to work out how well a subdivided solid exports.....when I export to OBJ or STL it seems to go quite jagged even at high resolution/poly.
                        oli
                          Example, image, files ? πŸ’š
                          • olisheaO
                            olishea
                            It's OK I'll sort it out. All the mesh previews look unsmoothed when uploaded to the 3D printing websites. It's more noticeable in the first image....it could be because i'm trying to subdivide and then punch holes/fillet afterwards and it causes a messy mesh. The fillets are a different resolution to the subdivided mesh so some conflict will occur. I'll get there I'm just being silly. πŸ˜„
                            oli
                              File 3DM?
                              In waiting a little tut by Chipp Walters
                                    VoronoΓ― Diagram by Max Smirnov
                                    Select Voronoi: Name it, Select Polygon: name it
                                    Select Voronoi's lines
                                    Call Boolean Inter
                                    Click Polygon
                                    Et voilΓ ! πŸ˜„
                                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/570504_orig.jpg
                                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3263482_orig.gif
                                    • olisheaO
                                      olishea
                                      does it work in 3D?! πŸ˜„
                                      oli
                                        You can make yet some things with it! πŸ˜‰ (and it's work in progress! ) πŸ€“
                                        • olisheaO
                                          olishea
                                          There is a [ missing from your link mate
                                          One day, i swear, there will be a plugin where you just click "apply pattern" and then BOOM it's done! Whatever voronoi/tessellation you like. Just couple of clicks!! One day!!! πŸ˜„
                                          oli
                                            • 11
                                            • 6 / 11
