    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 170.4k Views 13 Watching
      Example, image, files ? πŸ’š
      • olisheaO Offline
        olishea
        It's OK I'll sort it out. All the mesh previews look unsmoothed when uploaded to the 3D printing websites. It's more noticeable in the first image....it could be because i'm trying to subdivide and then punch holes/fillet afterwards and it causes a messy mesh. The fillets are a different resolution to the subdivided mesh so some conflict will occur. I'll get there I'm just being silly. πŸ˜„
        oli
          File 3DM?
          In waiting a little tut by Chipp Walters
                VoronoΓ― Diagram by Max Smirnov
                Select Voronoi: Name it, Select Polygon: name it
                Select Voronoi's lines
                Call Boolean Inter
                Click Polygon
                Et voilΓ ! πŸ˜„
                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/570504_orig.jpg
                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3263482_orig.gif
                • olisheaO Offline
                  olishea
                  does it work in 3D?! πŸ˜„
                  oli
                    You can make yet some things with it! πŸ˜‰ (and it's work in progress! ) πŸ€“
                    • olisheaO Offline
                      olishea
                      There is a [ missing from your link mate
                      One day, i swear, there will be a plugin where you just click "apply pattern" and then BOOM it's done! Whatever voronoi/tessellation you like. Just couple of clicks!! One day!!! πŸ˜„
                      oli
                          FatLines by Max Smirnov
                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1939476_orig.jpg
                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/4303546_orig.jpg
                            Delcorners by Max Smirnov
                            Voronoi, Delcorners, Flow
                            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/250183_orig.jpg
                            • olisheaO Offline
                              olishea
                              Smirnov is on fire! wow!
                              oli
                                New version of Subdivision by Max! πŸ˜‰
                                (Trick for volumes with difficulties like here : export as OBJ with triangles
                                then _importObj (By Max πŸ˜‰
                                and voilΓ !
                                http://s6.postimg.org/rq8zqot1t/beta7.jpg
                                    Teasing by Max Smirnov
                                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/6924353_orig.gif
                                      A new 3.1 version of MoI (Mac version), to fix problems when running in OS X 10.11 "El Capitan" πŸ€“
                                      else in few days! πŸ˜‰
                                      http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=d7b79cb5632b11f9d86d52326d52d9ca&filename=SubdivBeta8-1.jpg
                                      http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=cc6c689daf7fdc847147bfbe46b9b26c&filename=SubdivBeta8-2.jpg
                                      We can make the same with Artisan! πŸ˜‰
                                        Subdivision Beta 8
                                        "Open Surfaces"
                                        by Max Smirnov πŸ˜‰
                                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/2279270_orig.jpg
                                        Pig By Max Smirnov
                                        http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=beefa22434ee5e33a98a64b8048b356b&filename=SubdivB8.jpg
                                          beta 9 Subdivision by Max Smirnov
                                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/7203751_orig.jpg
                                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9164830_orig.gif
                                            • 11
                                            • 7 / 11
