    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 199.0k Views 13 Watching
      File 3DM?
      In waiting a little tut by Chipp Walters
            Voronoรฏ Diagram by Max Smirnov
            Select Voronoi: Name it, Select Polygon: name it
            Select Voronoi's lines
            Call Boolean Inter
            Click Polygon
            Et voilร ! ๐Ÿ˜„
            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/570504_orig.jpg
            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3263482_orig.gif
            • olisheaO
              olishea
              does it work in 3D?! ๐Ÿ˜„
              oli
                You can make yet some things with it! ๐Ÿ˜‰ (and it's work in progress! ) ๐Ÿค“
                • olisheaO
                  olishea
                  There is a [ missing from your link mate
                  One day, i swear, there will be a plugin where you just click "apply pattern" and then BOOM it's done! Whatever voronoi/tessellation you like. Just couple of clicks!! One day!!! ๐Ÿ˜„
                  oli
                      FatLines by Max Smirnov
                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1939476_orig.jpg
                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/4303546_orig.jpg
                        Delcorners by Max Smirnov
                        Voronoi, Delcorners, Flow
                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/250183_orig.jpg
                        • olisheaO
                          olishea
                          Smirnov is on fire! wow!
                          oli
                            New version of Subdivision by Max! ๐Ÿ˜‰
                            (Trick for volumes with difficulties like here : export as OBJ with triangles
                            then _importObj (By Max ๐Ÿ˜‰
                            and voilร !
                            http://s6.postimg.org/rq8zqot1t/beta7.jpg
                                Teasing by Max Smirnov
                                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/6924353_orig.gif
                                  A new 3.1 version of MoI (Mac version), to fix problems when running in OS X 10.11 "El Capitan" ๐Ÿค“
                                  else in few days! ๐Ÿ˜‰
                                  http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=d7b79cb5632b11f9d86d52326d52d9ca&filename=SubdivBeta8-1.jpg
                                  http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=cc6c689daf7fdc847147bfbe46b9b26c&filename=SubdivBeta8-2.jpg
                                  We can make the same with Artisan! ๐Ÿ˜‰
                                    Subdivision Beta 8
                                    "Open Surfaces"
                                    by Max Smirnov ๐Ÿ˜‰
                                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/2279270_orig.jpg
                                    Pig By Max Smirnov
                                    http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=beefa22434ee5e33a98a64b8048b356b&filename=SubdivB8.jpg
                                      beta 9 Subdivision by Max Smirnov
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/7203751_orig.jpg
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9164830_orig.gif
                                          System KitBash objects added!
                                          https://dl.dropboxusercontent.com/u/3788438/WidgetGadgets4Moi3D/Widgets/BLIVET-SQUARE.png
                                            Nodes arrive inside Moi! (in developpment) ๐Ÿค“
                                            By Max Smirnov!
                                            • 11
                                            • 7 / 11
