    Layout To PDF Rendering Issue
    layout
    19 Posts 6 Posters 4.2k Views 6 Watching
      Ash, I do all my drawing work in SketchUp and all the documentation in LO. I haven't found a need to use other programs for the drawing work but then I don't often get CAD files from others. I do 100% of the drawing work for the projects. The only thing I need to create from the LO project is PDF files, too.
      I expect it's difficult to figure out all the nuances and keep them straight when you have to work in many different programs. I'm glad I don't really need to do that.
      • ashscottA
        ashscott
        Good on you. Working in multiple programs is a nightmare. However, I'm building a repertoire or techniques where I can get just about any design job done in Sketchup and Layout which is kinda satisfying.
        Just some stuff I do with Sketchup.
        • pbacotP
          Perhaps for load time issues, you can work with lower quality setting under Document Setup / paper / Edit Quality. I don't know how LayOut can be close to CAD clarity if you don't output with Hybrid or Vector. Your clients have a point. For most people CAD output will look better than LayOut, for now anyway.
          • pbacotP
            @ashscott said:
            Do you primarily work in SU or do you use other 3D software as well?
            I ask because I am doing work across so many disciplines but don't have time to learn new software packages so am just sticking hard with sketchup -
            Somehow we have to get past this, because this is what everyone has said about every design software except their first. You will still feel the same when you are as old as me. It's hard but probably unavoidable. SU is good because we can pick it up faster, but it still takes a while before one may produce professional work with it, as you know. I believe though it has been shown that you can "polish" your SU-LO work to be top of the line.
            • ashscottA
              ashscott
              Yes, given patience I think the workflow you can learn in SU/LO is powerful because it is so fast for going from concept to working drawings. Initial learning curve is shallow, long term learning curve is steeper. All in all I think its well worth it.
                sonder
                Ashcott, what graphics card are you using? a file like the one you posted should vector render almost instantly with a good card.
                • ashscottA
                  ashscott
                  That was just a screen shot of a much larger file (many pages) with perspective and shaded textures on multiple pages.
                    sonder
                    I actually don't keep a single project on one LO file. I create LO files based upon the drawing type - Site plans, Floor plans, Elevations etc. This really helps speed things up and should disaster happen with a corrupted file, your entire project is not lost. Then you can simply book the PDFs into a sinlge PDF if you care to. I keep them separate as it is easy to issue individual files as needed.
                    • ashscottA
                      ashscott
                      That totally makes sense. I do find that with engineering drawings I'm triple checking the practical implications of the design as I process the LO file and I often make numerous changes during this time - for example making something easier for folks in the workshop to actually construct. I feel this chopping and changing between LO and SU to make changes is more straightforward if I just have one LO document to update reference.
                      But when they get really big then yes, I have to split them up
                      • utilerU
                        utiler
                        Makes sense for auto numbering too. Keeping plans / elevations / sections in separate files means numbering prefixes work easily. πŸ‘
                        Just Curious...
