    Keeping face me components in place
    15 Posts 7 Posters 2.2k Views 7 Watching
      Hi all, I have always had issues with keeping face me components anchored in place when I rotate the view. For instance a 2D tree, or person will pirouette around its original placement with a varying radius. This means I am always repositioning sometimes 10-20 trees or people for a particular view before I render. Is there a technique I can employ to remedy this? It would be almost life changing for my workflow.
      • BoxB Offline
        The position of the component axis controls how it will behave.
        If the axis is off to the side it will wave about as you describe but in the center it will rotate on the spot.
        So right click on the component and select change axes, then place it in the center.
        • JQLJ Offline
          JQL
          Cool components box!
          www.casca.pt
          Visit us on facebook!
          • BoxB Offline
            Thanks. I spent many hours perfecting them.
            They can be yours for an exorbitant sum paid to my nigerian PayPal account.
            • pbacotP Offline
              mesmerizing GIF
              • cottyC Offline
                cotty
                Maybe we can start a fund raising to get you paid for those ๐Ÿ˜‰
                my SketchUp gallery
                • BoxB Offline
                  Here's a seductive bit of titillation that might help bring the investors in. ๐Ÿ˜ฎ
                  • cottyC Offline
                    cotty
                    We can call the project "dancing palms"...
                    my SketchUp gallery
                    • pbacotP Offline
                      Need a camel
                      • JQLJ Offline
                        JQL
                        Could you paint it yellow, so it would really look like gold and I could droll?
                        www.casca.pt
                          Thank you box: ) Beautifully and eloquently demonstrated. So simple but it had me stumped. On the same principle I now just: 'edit component' then select the component and move its centre to the axis point shown.
                          • chrisglasierC Offline
                            chrisglasier
                            I am afraid I still don't get it - old age I guess.
                            Image on left in its skp component file has an understandable bounding box but not when imported into main skp file on right. I cannot get the thing to sit in the centre of the shelf. Other face me components are similar.
                            Enlightenment will be much appreciated.
                            • tuna1957T Offline
                              tuna1957
                              chrisglasier, when you import your face me component, right click and explode it. SU "components your component" when it is imported , if that makes sense . Explode it and your back to the original, see if that makes a difference in behavior.
                                chrisglasier
                                Makes sense (works) thanks! Any tips how to anchor, for example, the horse to the center of the shelf?
                                • BoxB Offline
                                  Your screenshot of the orginal tells me that the component axes is set at the bottom left corner, which is the default position. If you move the camera around and that corner stays attached to the origin then my guess is correct. As I demonstrated above you need to move the axes to the bottom ceter of your horse so that it spins on its midpoint.
