    This tripped me up (again) today
    25 Posts 6 Posters 5.8k Views 6 Watching
      So SU doesn't override .dup for Point3d and Vector3d?
      That would explain why I had problems before when I tried .dup for Point3d. I've had to use .clone.
      • Dan RathbunD
        Dan Rathbun
        Yepper... I remember having that discussion with you in another topic thread.
        Either most the Sketchup classes need to override Ruby's .dup and .clone with methods that work, or they should be removed for those classes.
        And... a point about .freeze, we would not want to freeze most of the Ruby objects that Sketchup needs to modify (data classes and any object class that is kept in the model.) So copying the frozen state doesn't mean much, so the overriden dup could likely be just an alias for the overriden clone.
        In most Sketchup classes the .freeze method should be also removed. It can be done for many of them, by removing it from Sketchup::Entity.
        I'm not here much anymore.
          I passing... IF you want to make a completely separate array based on another array's 'reference' then us
          so
          a=[1,2] b=[]+a
          makes array a and array b separate arrays as
          a[0]=99
          gives
          a ==> [99,2]
          but b is not affected
          b ==> [1,2]
            August
            I am SO glad that I found this 5-year-old thread. I, too, was having trouble copying an array and having the copy be independent of the original.
            In my case, I had an array of points that I had generated, and I wanted to create a closed curve from them. My strategy was to copy the point array
            curve = []
            curve = point
            and then add point[0] to the end,
            curve << point[0]
            so that a curve created from the new curve[] array would return to its beginning point.
            path = ents.add_curve curve
            But the above sequence kept adding the extra point to the point array too.
            What I finally kludged around to was
            curve = []
            curve = point[0..(point.length - 1)]
            curve << point[0]
            Using the sample code from the above discussion, I have tested and confirmed that
            b = a.dup
            and
            b = a.clone
            both have the same problem as my initial
            curve = point
            And I have confirmed that
            b = a.dclone
            gives an error.
            I'm using SU 15, which is supposed to have Ruby 2.0 and Dan notes that dclone is in 1.9, so I'm confused.
            I do have a kludge that works. Maybe it's not so much of a kludge after all. I understand the issue a little more, and hopefully I will remember it in the future.
            FWIW, I hope this helps,
            August
            “An idea, like a ghost, must be spoken to a little before it will explain itself.”
            [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
              The assignment
              curve = point
              means the array 'curve' refers to the array 'point' - they are essentially referencing the same thing, whereas...
              curve = point.clone
              means the array 'curve' is a separate array, which has been made as a copy from the array 'point',
              Consider this...
              curve = point + [ point[0] ]
              which achieves you aim for a 'curve' array defining a 'loop', but done in the one step.
              It combines the array 'point' and a new array made from the first element of that array, all in a new array named 'curve'.
              Incidentally consider naming arrays and other collections in the plural - it is is easy to follow the code - so the array named 'points' consists of a collection of elements, each of which is a 'point'.
              The 'curve' array would also perhaps be better named 'curve_points'
                August
                Thanks TIG.
                I had not tried using that additional set of square brackets. It makes sense.
                As for naming, I thought about using plural in the first place, but most of my usages were as singular references, point[0], point[1], ... point[n-1], point[n] where the singular read better to me. I like "curve_points" -- that is always used as a group, never individually, so plural reads much better there.
                Thanks,
                August
                  August
                  TIG, I'm not sure that clone does what you say it does.
                  This page, http://lukaszwrobel.pl/blog/copy-object-in-ruby suggests that a clone's elements still point to the original elements so some changes to one will indeed show up in the other. That's what I found with my initial testing.
                  Above, Dan says
                  It WILL work for any custom Sketchup classes that provide an overidden version of clone, such as:
                  Geom::Point3d
                  Geom::Transformation
                  Geom::Vector3d
                  • note that these work like dup and not clone (in that they do not copy the frozen state of the receiver.)
                  The Ruby inherited edition will not work for many C++ objects like Sketchup::Face.
                  So I didn't use .clone.
                  And yet, I just tried in the SU Ruby console:
                  > a = ["a","b", "c"]
                  ["a", "b", "c"]
                  > b = a
                  ["a", "b", "c"]
                  > c = a.clone
                  ["a", "b", "c"]
                  > d = a << "d"
                  ["a", "b", "c", "d"]
                  > a
                  > b
                  > c
                  ["a", "b", "c"]
                  > a[2] = "3"
                  3
                  > a
                  ["a", "b", "3", "d"]
                  > b
                  > c
                  ["a", "b", "c"]
                  > d
                  which shows that for these two kinds of changes, the clone is not affected.
                  I'm still not clear on when I can use .clone and when not, nor do I really understand shallow vs. deep copies and frozen objects, so for now, unless I'm doing tens of thousands of copies, I may use a brute force method becuase the shortcuts seem so problematical.
                  Thanks,
                  =A=
                  • Dan RathbunD
                    Dan Rathbun
                    What I actually said was that the REXML library (beginning in Ruby 1.9,) modified the Array class, by adding the dclone method.
                    In order to use it, you must either precede it's use with:
                    require "rexml/document"
                    or use a refinement.
                    (1) Using the REXML library:
                    ` require "rexml/document"
                    true
                    a = []
                    a.respond_to?(:dclone)
                    true`
                    (2) Refinement module:
                    <span class="syntaxdefault"><br />module&nbsp;August<br />&nbsp;&nbsp;module&nbsp;DeepCopy<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;refine&nbsp;</span><span class="syntaxkeyword">Array&nbsp;do<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">def&nbsp;dclone<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;klone&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.clone<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">klone</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">clear<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">klone&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dclone</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">klone<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;</span><span class="syntaxcomment">#&nbsp;class&nbsp;Array<br /><br />&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;refinement&nbsp;module&nbsp;DeepCopy<br /></span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;Author's&nbsp;namespace<br /><br /><br /></span><span class="syntaxdefault">using&nbsp;August</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">DeepCopy<br /><br />module&nbsp;August<br />&nbsp;&nbsp;module&nbsp;SomePlugin<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;a&nbsp;</span><span class="syntaxkeyword">=&nbsp;[</span><span class="syntaxstring">"august"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"dan"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"tig"</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">b&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dclone<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;</span><span class="syntaxstring">"a&nbsp;is;&nbsp;#{a.inspect}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"b&nbsp;is;&nbsp;#{b.inspect}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"changing&nbsp;a[1]&nbsp;to&nbsp;\"bob\""<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]=&nbsp;</span><span class="syntaxstring">"bob"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"a&nbsp;is;&nbsp;#{a.inspect}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"b&nbsp;is;&nbsp;#{b.inspect}"<br /><br />&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;module&nbsp;SomePlugin<br /></span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;Author's&nbsp;namespace<br />&nbsp;</span><span class="syntaxdefault"></span>
                    Any call to using() must occur within the TOPLEVEL_BINDING.
                    This restriction has been removed in later versions of Ruby 2.2+, and the experimental warning that is output on calls to refine has also been removed. (Ie, refinements are no longer experimental and calls to using can happen inside specific module and class scopes.)
                    If you want to see that all the elements of the arrays are different objects, you can iterate them and compare their object id numbers.
                      August
                      Thanks Dan,
                      So refine allows me to add my own operators to an existing class? That's a sweet (and dangerous) concept.
                      I'll have to put that on the back burner for now. I'm still working on basic Ruby.
                      • Dan RathbunD
                        Dan Rathbun
                        Refinements do not affect other people's scripts that do not "use" the refinement module. (They are only valid within the file that has the using call.)
                        • Dan RathbunD
                          Dan Rathbun
                          Another basic concept is the mixin module, which uses include() and extend().
                          In this case, in order to affect only the array you are using, you need to only "extend" the specific array instance object.
                          So, assume you have previously loaded a mixin module thus:
                          <span class="syntaxdefault">module August<br />  module DeepCopy<br /><br />    def dclone<br />      klone </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> self</span><span class="syntaxkeyword">.clone<br /></span><span class="syntaxdefault">      klone</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">clear<br />      self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> klone </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> v</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dclone</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">      klone<br />    end<br /><br />  end </span><span class="syntaxcomment"># mixin module DeepCopy<br /></span><span class="syntaxdefault">end </span><span class="syntaxcomment"># Author's namespace&nbsp;</span><span class="syntaxdefault"></span>
                          Then you need to extend a specific array instance:
                          <span class="syntaxdefault">a </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">"august"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"dan"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"tig"</span><span class="syntaxkeyword">]<br /><br /></span><span class="syntaxdefault">a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">extend</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">August</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">DeepCopy</span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">b </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dclone</span>
                            August
                            Back to TIG's comment about plural vs. singular names for arrays, here is the way I'm naming things. In this context, the singular terms seem to work better for me, probably because I think of it as the mathematical notation P[sub:2dctu78y]0[/sub:2dctu78y], P[sub:2dctu78y]1[/sub:2dctu78y], ... P[sub:2dctu78y]N[/sub:2dctu78y].
                            =begin
                                      point[N]
                                              x-------------x point[0]  angle[0] = angle_between vector[N], vector[0]
                                                 vector[N]   \
                              vector[N] = point[N], point[0]  \
                                                      vector[0] \
                                  vector[0] = point[0], point[1] \
        x point[1]  angle[1] = angle_between vector[0], vector[1]
                                                      vector[1] /
                                vector[1] = point[1], point[2] /
                                                            x point[2]  angle[2] = angle_between vector[1], vector[2]
                            =end
                            • 2 / 2
