    This tripped me up (again) today
    25 Posts 6 Posters 5.6k Views 6 Watching
      I think so. 😒
        Jim
        @thomthom said:
        Are .dup and .clone aliases?
        No, but I don't know the details.
        • AdamBA
          AdamB
          FWIW This whole area of Comp Sci is pretty tricky to resolve in programming languages generally because ultimately these references are not 'semantic free'.
          Sometimes you want a 'deep' copy and sometimes you want a 'shallow' copy. The classic example is if you have a class Car which has an attribute which is a reference to the car manufacturer, when I copy the car, I generally wouldn't want to deep copy the entire Ford motor company (or whatever).
          So languages essentially cannot a priori "know" what the meaning and therefore the intent of these references are, hence we have to either manually descend a parts hierarchy choosing to copy or not copy, or keep a top-level reference.
          Adam
            Jim
            It might be eaier to explain by looking at object id's:
            >> a = %w( one two three )
            => ["one", "two", "three"]
            >> b = a
            >> a.object_id
            => 23021928
            >> b.object_id
            => 23021928
            Here is an image what what this means in the computer. Both a and b now reference the same object, an Array. However, note that each array element is a reference to another object.
            When we .dup a, we get a new Array object, including it's elements. But remember the elements are just references to the original objects.
            >> b = a.dup
            >> a.object_id
            => 23021928
            >> b.object_id
            => 22854408
            Which can be seen by:
            a[0].object_id == b[0].object_id => true
            So when you .dup an array, you get a new array. Because the elements of the original array are references to a non-primitive type (String in this case,) the new array's elements reference the original elements.
            As Dan says, there are no variables in Ruby, only references to object.
            Here's someone else's explaination
            When you copy an object, all you do is copy its set of instance variables, which are just references to other objects. For an array, the instance variables are its set of indexes, which again are just references. Copying an array just means making a new list of references, but the objects they point to remain unmodified and uncopied.
            • Dan RathbunD
              Dan Rathbun
              NO, even though both create "shallow" copies:
              • .clone copies the frozen and tainted state of the receiver object.
              • .dup copies the tainted state of the receiver object.
              In addition:
              (http://phrogz.net/ProgrammingRuby/ref_c_object.html#Object.dup)":1q9fng7v]In general, clone and dup may have different semantics in descendent classes. While clone is used to duplicate an object, including its internal state, dup typically uses the class of the descendent object to create the new instance.
              In general it is always safer to try using dup first (especially if you don't want to get a frozen object.)
              (http://forums.sketchucation.com/viewtopic.php?f)":1q9fng7v]
              @kwalkerman said:
              So apparently, you can do face.clone, ... I if so, I might be able to determine what is happening with face.clone
              Karen,
              The .clone and .dup methods come from standard Ruby class Object, and create "shallow" copies. Ie, (from the book,) "the instance variables of the obj are copied, but not the objects they reference."
              FYI: I went on to say not to use these methods with Sketchup's C++ objects (... until they get overriden methods that work correctly.)
              I'm not here much anymore.
                I use clone a lot for SketchUp's objects...
                What is the issue with SU's .clone?
                • Dan RathbunD
                  Dan Rathbun
                  It WILL work for any classes that are subclasses of standard Ruby classes, such as Length, which is a subclass of Float.
                  It WILL work for any custom Sketchup classes that provide an overidden version of clone, such as:
                  Geom::Point3d
                  Geom::Transformation
                  Geom::Vector3d
                  • note that these work like dup and not clone (in that they do not copy the frozen state of the receiver.)
                  The Ruby inherited edition will not work for many C++ objects like Sketchup::Face.
                  To get around this, TIG shows in the other thread, how to use Sketchup::Group.copy to "clone" Sketchup::Drawingelement subclass objects, like Faces, Edges, etc.
                  Geom::BoundingBox objects can be copied by using their .add method (if clone or dup does not work):
                  bb2 = Geom::BoundingBox.new.add( bb1 )
                    So SU doesn't override .dup for Point3d and Vector3d?
                    That would explain why I had problems before when I tried .dup for Point3d. I've had to use .clone.
                    • Dan RathbunD
                      Dan Rathbun
                      Yepper... I remember having that discussion with you in another topic thread.
                      Either most the Sketchup classes need to override Ruby's .dup and .clone with methods that work, or they should be removed for those classes.
                      And... a point about .freeze, we would not want to freeze most of the Ruby objects that Sketchup needs to modify (data classes and any object class that is kept in the model.) So copying the frozen state doesn't mean much, so the overriden dup could likely be just an alias for the overriden clone.
                      In most Sketchup classes the .freeze method should be also removed. It can be done for many of them, by removing it from Sketchup::Entity.
                        I passing... IF you want to make a completely separate array based on another array's 'reference' then us
                        so
                        a=[1,2] b=[]+a
                        makes array a and array b separate arrays as
                        a[0]=99
                        gives
                        a ==> [99,2]
                        but b is not affected
                        b ==> [1,2]
                          August
                          I am SO glad that I found this 5-year-old thread. I, too, was having trouble copying an array and having the copy be independent of the original.
                          In my case, I had an array of points that I had generated, and I wanted to create a closed curve from them. My strategy was to copy the point array
                          curve = []
                          curve = point
                          and then add point[0] to the end,
                          curve << point[0]
                          so that a curve created from the new curve[] array would return to its beginning point.
                          path = ents.add_curve curve
                          But the above sequence kept adding the extra point to the point array too.
                          What I finally kludged around to was
                          curve = []
                          curve = point[0..(point.length - 1)]
                          curve << point[0]
                          Using the sample code from the above discussion, I have tested and confirmed that
                          b = a.dup
                          and
                          b = a.clone
                          both have the same problem as my initial
                          curve = point
                          And I have confirmed that
                          b = a.dclone
                          gives an error.
                          I'm using SU 15, which is supposed to have Ruby 2.0 and Dan notes that dclone is in 1.9, so I'm confused.
                          I do have a kludge that works. Maybe it's not so much of a kludge after all. I understand the issue a little more, and hopefully I will remember it in the future.
                          FWIW, I hope this helps,
                          August
                          “An idea, like a ghost, must be spoken to a little before it will explain itself.”
                          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                            The assignment
                            curve = point
                            means the array 'curve' refers to the array 'point' - they are essentially referencing the same thing, whereas...
                            curve = point.clone
                            means the array 'curve' is a separate array, which has been made as a copy from the array 'point',
                            Consider this...
                            curve = point + [ point[0] ]
                            which achieves you aim for a 'curve' array defining a 'loop', but done in the one step.
                            It combines the array 'point' and a new array made from the first element of that array, all in a new array named 'curve'.
                            Incidentally consider naming arrays and other collections in the plural - it is is easy to follow the code - so the array named 'points' consists of a collection of elements, each of which is a 'point'.
                            The 'curve' array would also perhaps be better named 'curve_points'
                              August
                              Thanks TIG.
                              I had not tried using that additional set of square brackets. It makes sense.
                              As for naming, I thought about using plural in the first place, but most of my usages were as singular references, point[0], point[1], ... point[n-1], point[n] where the singular read better to me. I like "curve_points" -- that is always used as a group, never individually, so plural reads much better there.
                              Thanks,
                              August
                                August
                                TIG, I'm not sure that clone does what you say it does.
                                This page, http://lukaszwrobel.pl/blog/copy-object-in-ruby suggests that a clone's elements still point to the original elements so some changes to one will indeed show up in the other. That's what I found with my initial testing.
                                Above, Dan says
                                Geom::Point3d
                                Geom::Vector3d
                                So I didn't use .clone.
                                And yet, I just tried in the SU Ruby console:
                                > a = ["a","b", "c"]
                                ["a", "b", "c"]
                                > b = a
                                ["a", "b", "c"]
                                > c = a.clone
                                ["a", "b", "c"]
                                > d = a << "d"
                                ["a", "b", "c", "d"]
                                > a
                                > b
                                > c
                                ["a", "b", "c"]
                                > a[2] = "3"
                                3
                                > a
                                ["a", "b", "3", "d"]
                                > b
                                > c
                                ["a", "b", "c"]
                                > d
                                which shows that for these two kinds of changes, the clone is not affected.
                                I'm still not clear on when I can use .clone and when not, nor do I really understand shallow vs. deep copies and frozen objects, so for now, unless I'm doing tens of thousands of copies, I may use a brute force method becuase the shortcuts seem so problematical.
                                Thanks,
                                =A=
                                • Dan RathbunD
                                  Dan Rathbun
                                  What I actually said was that the REXML library (beginning in Ruby 1.9,) modified the Array class, by adding the dclone method.
                                  In order to use it, you must either precede it's use with:
                                  require "rexml/document"
                                  or use a refinement.
                                  (1) Using the REXML library:
                                  ` require "rexml/document"
                                  true
                                  a = []
                                  a.respond_to?(:dclone)
                                  true`
                                  (2) Refinement module:
                                  <span class="syntaxdefault"><br />module&nbsp;August<br />&nbsp;&nbsp;module&nbsp;DeepCopy<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;refine&nbsp;</span><span class="syntaxkeyword">Array&nbsp;do<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">def&nbsp;dclone<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;klone&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.clone<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">klone</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">clear<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">klone&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dclone</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">klone<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;</span><span class="syntaxcomment">#&nbsp;class&nbsp;Array<br /><br />&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;refinement&nbsp;module&nbsp;DeepCopy<br /></span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;Author's&nbsp;namespace<br /><br /><br /></span><span class="syntaxdefault">using&nbsp;August</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">DeepCopy<br /><br />module&nbsp;August<br />&nbsp;&nbsp;module&nbsp;SomePlugin<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;a&nbsp;</span><span class="syntaxkeyword">=&nbsp;[</span><span class="syntaxstring">"august"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"dan"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"tig"</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">b&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dclone<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;</span><span class="syntaxstring">"a&nbsp;is;&nbsp;#{a.inspect}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"b&nbsp;is;&nbsp;#{b.inspect}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"changing&nbsp;a[1]&nbsp;to&nbsp;\"bob\""<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]=&nbsp;</span><span class="syntaxstring">"bob"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"a&nbsp;is;&nbsp;#{a.inspect}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"b&nbsp;is;&nbsp;#{b.inspect}"<br /><br />&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;module&nbsp;SomePlugin<br /></span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;Author's&nbsp;namespace<br />&nbsp;</span><span class="syntaxdefault"></span>
                                  Any call to using() must occur within the TOPLEVEL_BINDING.
                                  This restriction has been removed in later versions of Ruby 2.2+, and the experimental warning that is output on calls to refine has also been removed. (Ie, refinements are no longer experimental and calls to using can happen inside specific module and class scopes.)
                                  If you want to see that all the elements of the arrays are different objects, you can iterate them and compare their object id numbers.
                                    August
                                    Thanks Dan,
                                    So refine allows me to add my own operators to an existing class? That's a sweet (and dangerous) concept.
                                    I'll have to put that on the back burner for now. I'm still working on basic Ruby.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Refinements do not affect other people's scripts that do not "use" the refinement module. (They are only valid within the file that has the using call.)
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Another basic concept is the mixin module, which uses include() and extend().
                                        In this case, in order to affect only the array you are using, you need to only "extend" the specific array instance object.
                                        So, assume you have previously loaded a mixin module thus:
                                        <span class="syntaxdefault">module August<br />  module DeepCopy<br /><br />    def dclone<br />      klone </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> self</span><span class="syntaxkeyword">.clone<br /></span><span class="syntaxdefault">      klone</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">clear<br />      self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> klone </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> v</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dclone</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">      klone<br />    end<br /><br />  end </span><span class="syntaxcomment"># mixin module DeepCopy<br /></span><span class="syntaxdefault">end </span><span class="syntaxcomment"># Author's namespace&nbsp;</span><span class="syntaxdefault"></span>
                                        Then you need to extend a specific array instance:
                                        <span class="syntaxdefault">a </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">"august"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"dan"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"tig"</span><span class="syntaxkeyword">]<br /><br /></span><span class="syntaxdefault">a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">extend</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">August</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">DeepCopy</span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">b </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dclone</span>
                                          August
                                          Back to TIG's comment about plural vs. singular names for arrays, here is the way I'm naming things. In this context, the singular terms seem to work better for me, probably because I think of it as the mathematical notation P[sub:2dctu78y]0[/sub:2dctu78y], P[sub:2dctu78y]1[/sub:2dctu78y], ... P[sub:2dctu78y]N[/sub:2dctu78y].
                                          =begin
                                                    point[N]
                                                            x-------------x point[0]  angle[0] = angle_between vector[N], vector[0]
                                                               vector[N]   \
                                            vector[N] = point[N], point[0]  \
        vector[0] \
                                                vector[0] = point[0], point[1] \
        x point[1]  angle[1] = angle_between vector[0], vector[1]
        vector[1] /
                                              vector[1] = point[1], point[2] /
        x point[2]  angle[2] = angle_between vector[1], vector[2]
                                          =end
