    Substance and Sketchup Workflow
    107 Posts 9 Posters 16.3k Views 9 Watching
    • KrisidiousK Offline
      Krisidious
      watch this tut starting at the time set.
      By: Kristoff Rand
      • JQLJ Offline
        JQL
        @jason_maranto said:
        Substances make alot more sense for character and prop models based on subD which have high poly sculpts (ZBrush or similar) to pull geometry-based information from.
        I also understand this quite clearly.
        SketchUp models are usually so basic that the best features of Substances really will be marginalized. And that is before you even have to deal with UV unwrap and seam issues.
        Simple is good!
        So imagine all I want for a given model is to use one of the edge procedurals to create a fake bevel in my arch models.
        Would I need to unwrap it to achieve my objective, or would I be able to achieve this without unwrapping?
        (I'm sorry for the insistence in unwrap without even trying, but that really is work that I wouldn't want to introduce in my workflow. I'd prefer to have no bevel than to waste half an hour unwrapping a model)
        www.casca.pt
        Visit us on facebook!
        • jason_marantoJ Offline
          jason_maranto
          Edge effects are all controlled by geometry baked textures, so resolution would be an issue for larger models and UVs will become an issue if not properly handled. That is also assuming the SketchUp created geometry is intelligable to SD/SP... which could be the fault of the model creator or SketchUp itself.
          • JQLJ Offline
            JQL
            Well I really have to try. I know how to texture a model in SU as preciselly as possible and only that unwrapping slips my grasp. My main objective is to keep everything inside sketchup as long as I can and just jump out of it when I really need.
            Of course I'm open to a broader frame of mind if that does pay off.
            Thanks for all your help Jason.
            Let's see where this leads to...
            www.casca.pt
            • JQLJ Offline
              JQL
              I don't get it. At a certain stage the guy is trying to make squares fit together quite precisely, then, suddenly he starts dragging and scaling things around in what seamed a random way to me.
              In the end the squares didn't fit together, obviously, so why did he do that in the first place?
              www.casca.pt
                Krisidious
                4096 is as high as the maps go.
                they do already have procedural choices like tile size and dirt and aging. you can apply it in the converter then apply the texture to the model.
                But it doesn't seem to map correctly on it's own.
                He's doing that because the car is to scale and the image is pixels. the larger the mode detail of course and the uvw unwrap doesn't actually have to touch all over.
                By: Kristoff Rand
                  Krisidious
                  By: Kristoff Rand
                  • JQLJ Offline
                    JQL
                    Yeah... Thea Substance Converter is pretty cool! I love hitting the randomize button! πŸ˜„
                    www.casca.pt
                      Krisidious
                      without the real substance studio I think you will have to use maps and you will not get any of the options to affect the map procedurally.
                      By: Kristoff Rand
                      • JQLJ Offline
                        JQL
                        That's true and that's almost what I have right now. I'm used to create my own maps with an image editor and I like the control I have, but it takes me so much time fine tunning everything.
                        I recently found awesome bump and it serves it's purpose very well and is also able to generate all the pbr maps one needs and name them with any convention.
                        Basically that emulates the B2M workflow and it can also be used with Thea converter to automatically create a PBR material.
                        So it really is the ability to tinker with procedurals inside Thea Substance Converter that is ticking me to dive into Designer.
                        However, if you think of it that way, you're not getting much as the final result is a static material.
                        So substance designer only really starts paying off if you use it for procedurally and non desctructivelly texture a specific model.
                        Let's assume we can get a sketchup model to export nicely to Substance Designer, using 3ds or collada or obj. (as Jason pointed out it's not clear that even this is easily achievable...) But let's assume we can, then it all comes down to what Rich pointed out initially. UV mapping or ultimatelly UV unwrapping.
                        If I can deal with that in my workflow, I can justify using Designer as it's the UV unwrapping that will allows me to place the effects I want, in the right place of the model inside Substance and then turn that substance into a material I can replace with a thea material inside sketchup.
                        I'm willing to take the long shot and I hope I'll have an as streamlined as possible workflow in the near future (with just the enough details we need in architecture) to share with you guys.
                        www.casca.pt
                          Krisidious
                          Ok I just got the trial of these programs because they are so cool that not only do they offer the Thea thing for free and not only is it a great program but it's priced to fit small business budget. Kudos allegorithmic.com
                          So Now I'm trying the procedurals.
                          By: Kristoff Rand
                            Krisidious
                            By: Kristoff Rand
                            • FrederikF Offline
                              Frederik
                              Great to see that you guys have lots of fun...! πŸ‘
                              Cheers
                              Kim Frederik
                                Krisidious
                                with the Designer, or with the Painter or with just our converter and the library of materials on their site I thing the procedural will work fine. And as you and Jason said or suggested. you can output at low quality each texture to lighten load which is not even a big load for nice cards.
                                By: Kristoff Rand
                                  Krisidious
                                  This is going to work...
                                  By: Kristoff Rand
                                  • JQLJ Offline
                                    JQL
                                    Kris,
                                    It's great you've downloaded that already!
                                    Let me ask some questions:
                                    Are you only creating materials with Substance, then converting to Thea and then applying them inside SU or are you importing the house model to Substance designer, applying the textures there and then somehow bring everything back to Sketchup?
                                    Did you unwrap that house?
                                    If you have your house model inside Substance Designer, could you try the edge procedural?
                                    I'm exploring blender and unwrapping...
                                    www.casca.pt
                                      Krisidious
                                      Are you only creating materials with Substance, then converting to Thea and then applying them inside SU?
                                      ***So far I've edited samples from them. And saved them as Thea Mats. Then added them to my model.
                                      I've also added some of my own and edited them through the standard side. you can't edit the kool settings like for the Substance Designer materials, you can only add the all the multi layered effects maps if you have made them already or you own them from somewhere else...(this is a drawback because this is where the procedural taxturing is.)***
                                      or are you importing the house model to Substance designer, applying the textures there and then somehow bring everything back to Sketchup? You only use your mesh inside Project Designer/Painter in order to see what you're doing and to provide a mapping environment for the procedure. You don't have to re-import your model back to sketchup, you just have to use the SD texture on that mesh and it will recognize it. Both make maps and so does the converter. You never even have to make the map from what I can tell. it creates it on the fly.
                                      Did you unwrap that house? No, I did not... It's just a live procedural stone texture and concrete below.
                                      I didn't bring my mesh in... I'll be testing with that kind of thing later.
                                      I would like to add that if you were unable to pay the Substance Designer or Painter programs for the $20 a month for 6 months, you could always use Awesome Bump. https://github.com/kmkolasinski/AwesomeBump it's free and will make the files to use the Substance Converter needs. But, you will not get procedural textures out of it. In fact, it would seem to me that the current texture tools we have inside Thea Material Editor surpass that. I think the main value if you didn't own the Substance products would be importing all your maps at one time and prepping them a bit on size before you bring them into Thea Material Editor.
                                      By: Kristoff Rand
                                      • JQLJ Offline
                                        JQL
                                        Kris, you're wrong about Awesome Bump.
                                        AB can generate all PBR maps you need, from a base texture you feed into it. You can also manually tune many fine aspects of it.
                                        It can generate the four main maps:
                                        • Diffuse;
                                        • Metallic;
                                        • Roughness;
                                        • Normal.
                                        And several others quite effectively, like height maps...
                                        In what concerns Substance Designer. It can also generate PBR mateirals, probably much better than AB and with the added procedural parameters.
                                        However where it stands apart is in texturing the model directly using geometry related procedurals that act with relation to the model itself and it's geometric properties. This and the fact that it's all done in a nondestructive and interactive way it's what interests me the most.
                                        Without being able to pull this off, I'll keep my workflow as it is right now...
                                        www.casca.pt
                                          Krisidious
                                          Wrong about it? I I said it can do that... I said it can't do procedural.
                                          By: Kristoff Rand
                                          • JQLJ Offline
                                            JQL
                                            Sorry, this was what you said that got me confused. I thought it meant that thea surpassed Awesome Bump at generating maps. But I now think what you're saying is that Thea texture tools surpass the limitations one would be faced by not having procedurals from Awesome Bump.
                                            I'm still unsure if this is what you meant...
                                            www.casca.pt
                                            • 4 / 6
