    Substance and Sketchup Workflow
    107 Posts 9 Posters 16.4k Views 9 Watching
    • JQLJ Offline
      JQL
      @rich o brien said:
      Can you give a bread and butter example of your end goal?
      What do you mean by that?
      Example of the procedure?
      Example of the final effect I want to see?
      www.casca.pt
      Visit us on facebook!
        I mean that I know you have a textured SketchUp model and that you are going to pipe that into Thea.
        I'm asking what do you think/want Substance Designer can/to do for your workflow?
        • JQLJ Offline
          JQL
          I want it to fake it πŸ˜„ and pimp it πŸ˜„!
          www.casca.pt
          • JQLJ Offline
            JQL
            Ah and I want:
            www.casca.pt
            • JQLJ Offline
              JQL
              Now that I've most certainly annoyed you again, I want to be able to:
              Fake things like round edges in certain materials and one of the procedurals in Substance could do that with normal maps and stuff.
              I want to add moisture, moss, cracks, dirt and that sort of stuff to my architectural models, because I want my clients to understand how they age beautifully if we use good materials instead of the fake pvc, paint, aluminium panels and glossy stuff, etc... one sees in standard architecture.
              I want to break every edge in my model.
              I want to create materials faster than I do now.
              I want to visualize everything with a real time poor quality render and know that my thea render will rock for sure.
              I want grunge in particular places and add it effortless.
              I want to create infinite variations of a material using substances parameters.
              I want a beer.
              I want to see it all in sketchup after texturing.
              I want to modify my model and seamless rebake every needed texture for the magic to happen again.
              I want to update my SU model easily enough so I render it with Thea again.
              EDIT:
              I'd also like to pick up some 3d warehouse models and make them feel natural very fast... but that is a hobby of mine.
              www.casca.pt
                I want a beer.
                EDIT:
                Then you will need your models to be unwrapped. This can be done extremely quickly in Blender using Smart UV project.
                Export Collada. Unwrap and then apply the maps.
                This way you materials are assigned to maps and in Substance you can begin the process of adding magic...
                Substance needs a good unwrap to be able to extract normal maps, ao maps etc to then utilise other nodes to treat those maps as foundations to curvature maps etc...
                It is an involved process. But if you are currently doing this by hand in PS then Substance speeds it up dramatically.
                If you're not then keeping rubbing the lamp and the genie will eventually come out and grant your wishes.
                • JQLJ Offline
                  JQL
                  I knew it! You're earning money by selling blender copies!
                  As soon as you entered the discussion I knew the solution would be blended somewhere on your post replies...
                  Are you sure I need to unwrap my texture in Blender?
                  It kind of scares my doing that? Can't I just texture it in SU and shoot the model into Substance?
                  That is a drag, I'm already predicting stupid things happening when I alter the model after the texturing has been done!
                  So I have to:
                  1 - export it to Blender (will blendup help?);
                  2 - unwrap it there;
                  3 - export as collada;
                  4 - Reimport the unwrapped collada back into sketchup so I have a correct UV mapped model (will this work?)
                  5 - Link the collada to Substance
                  6 - Bake the textures into the model in Substance so I can get postional maps.
                  7 - Texture it there until I create the final substance;
                  8 - Create a Thea material from Substance using the new converter;
                  9 - Apply the material into the Sketchup model without breaking it's UVs...
                  10 - Render and remodel the model to my liking.
                  What now? It's no longer unwraped so I have to start it over from 1?
                  If so, the only step I can skip is 7 as all the creative texture work is done and baking the new model will make all stuff update through node based system...
                  Is this so? Can't I really skip unwrap?
                  If so then I hate you Rich! I was living a nice dream until you showed up!
                  www.casca.pt
                  • KrisidiousK Offline
                    Krisidious
                    you can wrap models and come back into sketchup... and render.
                    This is an unwrapped model in SU.
                    http://www.mediafire.com/view/sqdncopkzqr1dab/99.jpg#
                    By: Kristoff Rand
                      roland joseph
                      how to take a model out sketchup and into substance designer/painter
                      I am guessing that you are just kidding πŸ˜• . The answer is of course rewrite SU entirely so that it has a multi-layer UV and an engine/algorithm to drive the substance materials. Goodluck with that one. πŸ˜„
                        Krisidious
                        I'm happy just using Substance painter/designer in Thea/SU.
                        By: Kristoff Rand
                        • JQLJ Offline
                          JQL
                          Nope Roland, for what I can tell, and for what Rich told here, the only thing stopping us is UV unwrapping. And also, again for what Rich told here, that shouldn't stop us anyway, because we have the ability to use Blender (well I have no ability to use Blender πŸ˜• but I could learn or at least spend some time with it... I've got it installed for ages anyway)
                          The thing is you can create a substance and that substance wich might be a mix of textures procedural effects/materials that are created on specific places based on your model. So it's a model specific material based on multiple generic materials and procedurals and masks that help you position your materials and effects in the model.
                          Inside a gaming engine that complex stuff can be directly applied in a model as a substance file wich is dynamic and might change accordingly to actions taking place in that app, for instance, game actions like getting burned, or being fired at, or whatever...
                          Inside applications that don't support substance, like Sketchup, that can't be done dynamically, but the substance can be converted into a static material that fits that model alone.
                          This material is not a single material like wood, or steel or whatever, but it is in fact a multimaterial, with all the materials that you've created and applied to the model inside substance.
                          This means that it has several maps for those materials combined into one. Those maps correspond mainly to 4 things for PBR (photo based rendering):
                          • Base Color Map (similar to diffuse or a color/texture sketchup material)
                          • Normal Map (wich is the same);
                          • Roughness Map (wich controls how smooth the surface looks)
                          • Metallic Map (wich has to do with metallic effects wich are the only materials that can't be created with the above maps alone)
                          In this multimaterial you can also have other maps like Height, Emissive, Clip maps, etc...
                          This means that you can easily translate this multimaterial to any render engine and render it.
                          Thea as launched yesterday a converter that speeds up this material creation and works really well.
                          After the materila is created, you only have to fit it back into the original model, in this case Sketchup and you can render it perfectly from inside Sketchup.
                          The only things missing here in the gaming workflow are:
                          • Sketchup files are not supported but you have stuff like collada and 3ds or obj;
                          • By what Rich says you have to unwrap the model wich sketchup cannot do so you have to use blender or another UV unwrapping software;
                          • You then have to import the model back to sketchup so it get's also unwrapped in SU;
                          • Then you can import it to Substance and work there;
                          • Then you can turn your substance into a multimaterial based on textures instead of procedurals;
                          • Then you apply that multimaterial into your unwrapped model
                          • Then render it and every effect and material falls into place.
                          Teorically it's simple but the workflow is not direct and that is the only thing giving me doubts...
                          Substance Designer has a 30 days trial though, so...
                          www.casca.pt
                            Krisidious
                            3Dsimed will import directly fro sketchup, into 3D max or other programs for unwrapping and then export right back to Sketchup.
                            SimGarage | Home to 3DSimED
                            (www.sim-garage.co.uk)
                            By: Kristoff Rand
                              roland joseph
                              ....forgive me but I still think you are dreaming.
                              • JQLJ Offline
                                JQL
                                Didn't Whaat UV tools did that too?
                                www.casca.pt
                                • JQLJ Offline
                                  JQL
                                  You're forgiven but I'll keep dreaming a bit longer...
                                  www.casca.pt
                                    roland joseph
                                    Well lets start at the beginning...lets first make SU map one single diffuse texture effectively and do something tricky with it like ad depth. πŸ˜‰
                                    • JQLJ Offline
                                      JQL
                                      I'm still following tuts I'l download Substance designer and try that later...
                                      www.casca.pt
                                      • jason_marantoJ Offline
                                        jason_maranto
                                        For the types of effect you want to achieve it is all reliant on great (not just "good", you need great) UV unwrapping -- which is something I pushed for with SketchUp for a long time, but ultimately realized was fruitless. For this, and a couple of other good reasons, if Substances are a part of your workflow (and as time goes on it becomes more and more clear they should be for any type of video game work) SketchUp should not be.
                                        The bottom line is Allegorithmic is a company that is always pushing the technical limitations, and SketchUp is a software firmly stuck in the technology of over a decade ago -- the two are not compatible. My best advice is to move to an modeling application that already fully supports Substance integration like Modo, Maya or 3DS Max. Time (and money) spent learning the new software will ultimately save time (and money) as compared to suffering through a tortured and broken SketchUp-based workflow.
                                          Krisidious
                                          Roland I think you're focusing on native stand alone sketchup. JQL and I are using Thea which renders live in sketchup and uses multi layered maps with all kinds of options. Although I think the full substances are a step beyond with procedural textures.
                                          By: Kristoff Rand
                                          • JQLJ Offline
                                            JQL
                                            @jason_maranto said:
                                            ...if Substances are a part of your workflow (and as time goes on it becomes more and more clear they should be for any type of video game work) SketchUp should not be.
                                            Jason,
                                            I can clearly see your point and in what concerns your perspective I must agree with you totally. However my objective is the opposite. I'm totally into the sketchup workflow and I'm just considering tools that would enhance completely secondary but very interesting enhancements to the product I currently output from my workflow.
                                            I'm on the AEC industry where visuals are secondary but VERY useful product. On the opposite side with gaming and the rest of the entertainment industry, visuals are everything while model documenting is absolutely secondary though it could also be useful.
                                            Sketchup is neither perfect for one nor the other and we can agree with that. But it's good for something...
                                            Sketchup is very good at many things fundamental to my work and can also manage those things secondary but VERY useful to the architectural process.
                                            As we sell paper and ideas only, having some beautiful images documenting those ideas and paper is really appealing to my clients and people I work with, but it's not key.
                                            What I mean with this is that if SU+Layout could be improved to a more fluid workflow and interaction with AEC software, I'd be much more happy than if it went towards things fundamental to the entertainment industry.
                                            My persepctive is that Sketchup is a company that has embraced most of the tech it needs already, wich as assumed that most of the new tech is way over most of their user's needs, and is really concerned in getting tools that fit the needs of their users.
                                            Do I think personally they always nail it? Not for me!
                                            Do I think they always nail their market? Definetelly!
                                            I NEED sketchup and I've got the patience to wait for stuff that I believe will happen.
                                            Would some of that stuff include texture unwrapping, yes it would! But there is more, like better DC system, interactive solid tools or even any kind of modelling that could be non destructive (like node based)...
                                            Do I NEED allegorithmic? NOPE!... I can manage without it.
                                            However I would want to improve on my image output and it seems Substance would easen a lot of the stuff I currently do and could eventually lead to me wasting less time with my secondary job at Archviz.
                                            That's what I'm trying to achieve here... waste less time at archviz so I can focus more on architecture, yet get better output so I get better tools of communicating my ideas, develop my concepts and sell my work, and build or even sell work that will never be built wich happens a lot in an Architect's life!
                                            Bottomline, Sketchup and Layout, might be hammer and nail compared to all the software you suggested, but I'm not in need of an incredible CNC machine as I build simple wood stools...
                                            www.casca.pt
                                            • 4 / 6
