    [Plugin] SectionCutFace
    569 Posts 171 Posters 541.4k Views 170 Watching
      @maki84 said:
      Yes, it's runs ok!! The pluggin is on Tools menu. Thanks so much.
      For those that come after and might read your post: No, it isn't in the Tools menu. It is found in the Context menu as indicated in the description and instructions for use as well as the reply to you from TIG above your posts. And, being in the Context menu, it only shows up when you right click on a section plane.
        As Dave says... 😒
        SketchUp's native 'Section' tool is found under the Tools menu [or on the appropriate toolbar[s]].
        This places a SectionPlane which cuts sections through objects in the current context...
        These have no 'faces' at the cut-plane.
        BUT my 'SectionCutFace' tool only appears when one SectionPlane is selected, and then it appears in the right-click context-menu - no where else. Note how the available commands may vary, e.g. if the SectionPlane already has a SectionCutFace and the Updating option was chosen in this tool's settings dialog...
        It will add a group of 'faces' at the cut-plane - using the settings you have chosen.
        • E
          ednewcome
          I love this plugin. It has revolutionised my Sketchup use! Many thanks. Ed.
            marceloccrestani
            Hello guys!
            I installed plugin but when I open Sketchup 2015, it shows this message attached
            Anyone can help me?
              syahreenhishamudin11
              hi everyone. i got some problem to install this plugin. actually just wanna ask where to copy this plugin into my sketchup file? thanks
                Like all PluginStore entries... it downloads as an RBZ archive.
                Use the native SketchUp > Preferences > Extensions - Install... button to install that RBZ.
                Once installed this particular tool only appears in the context-menu if you have just one Section-Plane Selected - read its Usage notes...
                • P
                  pois
                  Tig... amazing plug in!
                  But a problem I know has been discussed but I can't find a simple workaround. Simple object, clean geometry and shows as volume in the inspector, but I can not get it to honor the solid to poche the correct area. Any thoughts on how to message it?
                  Dave
                    Hmmm... It works correctly sometimes.
                    Could you share the SKP?
                      It tries to decide what is solid and what is not.
                      In your case something about the objects cut throws it off.
                      It is not God.
                      It makes mistakes.
                      However it is easily resolved.
                      Make the cut as a one-off [i.e. no to 'auto-update'], no to 'hide edges', yes to 'keep all edges', no to 'lock'.
                      When it makes it incorrectly you can just edit the group, draw over an unfaced edge and it should then get a face.
                      Paint the new faces with the material eyedropper-ed from nother face.
                      Select + <delete> on any the unwanted faces.
                      Hide edges using Erase+shift as desired.
                      Lock when done if desired.
                      • G
                        gracacampelo
                        Hi, when I try to install it manually it dosen't appear in the Extension Preferences Window, and every time i open sketchup again this error appears:
                        Error Loading File SectionCutFace.rb
                        Error: #<NameError: uninitialized constant TIG::SectionCutFace::DESC>
                        C:/Users/Graça/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SectionCutFace.rb:50:in <module:SectionCutFace>' C:/Users/Graça/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SectionCutFace.rb:17:in module:TIG'
                        C:/Users/Graça/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/SectionCutFace.rb:15:in `<top (required)>'
                        If i try it by the pluginstore and auto install it, it says: Error, can´t unZip.
                        Can you help?
                        Regards
                          The issue is in your Windows user-name, 'Graça'.
                          Having accented characters is user names has been well documented, it causes issues with some of SketchUp's Ruby API methods like FILE...
                          Many such errors have been addressed in recoding.
                          Indeed the SCF PluginStore ought to be better than most at resolving this.
                          I'll Private Message a beta version, which I know has additional error trapping...
                          In regard to the SectionCutFace issue... I'll also look at that and see what I can do - although I thought it was already 'future-proofed'
                            Here's v4.7 http://sketchucation.com/pluginstore?pln=SectionCutFace
                            It now traps for errors resulting from most Windows User-names which contain accented characters.
                            Note this fix only works in >= v2014...
                            This is because accented User-names can cause issues with FILE trying to get the Plugins folder in the AppData path, but in newer Ruby versions it is fixable...
                              AcesHigh
                              which is exactly why I hate this new location of plugins for Sketchup.
                              yeah, right, it solved a few issues regarding writing permissions in the "program files" folders. Yet, it created much bigger problems for anyone with non unicode characters in their username.
                              and solving the username problem is a MUCH MUCH BIGGER problem than solving permissions for Program Files.
                              in fact, nothing short of a complete Windows re-install will solve that, unless you are an advanced user like me and decide to try your luck with some obscure programs to move username folders AND registry editors to change ALL instances with the old username to new username in the Windows Registry...
                              Blame either Microsoft that allows non-unicode characters in the username or programmers that create programs that will be used by people around the world and do not realize usernames may have non-unicode characters.
                              ps: this rant was absolutely NOT blaming you for anything TIG... 😆
                                melene
                                Hi there!
                                For me its impossible to installthe sectioncutface because sketchup doesnt create a "plugins" folder...
                                Any idea what to do?
                                (I'm using Sketchup Pro 14 in win 8.1. I also tried with Sketchup Make 15. No results..)
                                  How are you trying to install it? And what do you mean SketchUp doesn't create a Plugins folder? It must do. The Plugins folder for sketchUp 2014 and 2015 is in User/AppData/Roaming... Did you look there.
                                  In any case, if you are using one of the correct methods to install it, you don't need to access that folder anyway.
                                    Since the release of SketchUp version 8M2 the installation of RBZ based Plugins is handled 'automatically'.
                                    Use the Preferences > Extensions > Install Archive... button.
                                    Choose the Plugin's RBZ file, answer in the affirmative to the promts, and SketchUp does the rest...
                                    Also note that since v2014 there is no Plugins folder inside the main SketchUp folder.
                                    Instead each user gets their own Plugins folder made for them in their C:/Users/UserName/AppData/Roaming/... path - but you really never need to look in that - its creation and the finding of it to auto-install RBZ based Plugins is handled for you by SketchUp.
                                    But if you must find it then use this snippet in the Ruby Console +<enter>:
                                    Sketchup.find_support_file('Plugins')
                                    Because you appear to have issues with some basics... please also note that this particular 'SectionCutFace' Plugin does NOT appear in any main-menu or toolbar - it only appears in the right-click context-menu if the current selection consists of one Section-Plane.
                                    Also not that in v2015 the main-menu heading - previously called 'Plugins' - is now renamed 'Extensions', and it only appears if at least one loaded Plugin has added an entry into that menu.
                                    Also note that some Plugins may not appear in this menu, and they can appear under any other main-menu headings [like 'Draw'], or as a Toolbar or are context-menu driven - so read the specific instructions for each Plugin...
                                    • romboutR
                                      rombout
                                      Sorry if this is a double question, couldnt find it quickly though.
                                      When i have a scene / model which consists of multiple layers already is it correct that sectioncut only look at the mesh on the layer0?
                                      im using su2015 make on mac yosemite 10.10.4
                                        All of your meshes, that is all edges and faces, should be on Layer 0 anyway. It's only components and groups that should get layer associations other than Layer 0.
                                        Even if you violate that most basic rule, SectionCutFace will add section cut faces for geometry that is not on Layer 0.
                                        • P
                                          PP_RhuM
                                          Hi TIG and thanks for all your great plug-ins.
                                          I created an application as a SketchUp extension for parsing a specific model within an XML file and creating all the geometry of this model.
                                          Section planes can be contained within it and I wanted to know if it's possible to call your plugin through a command with needed parameters like this for example :
                                          sectionCutFace = TIG::SectionCutFace.new(section_plane, color, keepAllEdges, hideEdges, lock, autoUpdate, layer)
                                          Thank you for your answer.
                                          Bye.
                                          • JQLJ
                                            JQL
                                            I've been meaning to ask this for a long time but never thought of bothering you with this before: now seems a good chance.
                                            Is it possible to have the name and layer of the section cut face, being the same as the layer where the section resides?
                                            EXAMPLE:
                                            I have a "X PLT 1" layer only active in scene "X PLT 1"
                                            A section in layer "X PLT 1" would generate a SectionCutFace called "X PLT 1" and the Section cut layer would also be "X PLT 1".
                                            Current naming is automatic and I sometimes forget to change layer...
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 28
                                            • 29
                                            • 19 / 29
