    Adding Spreadsheets or Tables to layout page
    layout
    19 Posts 13 Posters 9.2k Views 13 Watching
    • jujuJ
      juju
      @dave r said:
      Juju, I guess a screen shot works but I wouldn't use it due to the low resolution especially with a JPG.
      That is true to an extent, I guess it helps a little working on HD screens...
      • pbacotP
        I think I would just print Excel to pdf and insert the pdf.
          Peter, that works well if you're using a Mac. On PC, not so much.
          • pbacotP
            What happens on a PC?
              No PDF import option.
                seasdes
                FastStone Capture allows screen clips to be saved at whatever resolution that you want. I use it every day.
                Using Sketchup Pro 2019
                • C
                  caronte01
                  I generate PDF from libre office, and then open it in inkscape, where I can save as PNG. At 200-300 DPI. Yes, layout PC needs PDF import badly!!!
                  • G
                    Garyvn
                    I just did a quick check then with Excel and Layout
                    not sure if this is a capability new to Layout 2015 but
                    Copy and paste from excel to LO worked fine - editable table in a text box
                    Also trying a way I always use via powerpoint to keep the formatting and colours of Excel
                    1] select range in excel
                    2] paste as image in powerpoint
                    3] copy that image from powerpoint
                    4] pasting into layout - quick and pretty spreadsheet
                    hope that helps
                    • C
                      Chailas
                      • ashscottA
                        ashscott
                        Have just been doing some tables from excel to Layout - they copied and pasted quite nicely so long as I didn't try and edit them in Layout - it seems Layout reads them better than it did a few versions back when I tried this and consistently got tabs jumping all over the place.
                        TL;DR: Try copy pasting from your spreadsheet to Layout first - could save you some time.
                        Just some stuff I do with Sketchup.
                          shawb
                          I have been looking at the Excel table into LO thing (or lack of in the PC version). Here is my offering:
                          Create your table in Excel with cell widths, heights, font size and formulas. Make sure that any editable data can be copied and pasted as a block (for convenience).
                          Format a matching area in the spreadsheet as a swap area.
                          Select the entire table, copy and paste into LO. The table comes in as an editable text block with cells bordered in black lines.
                          Make any changes to data in individual cells. Note, no formulas are copied just the numbers.
                          Double click in the text box which will select all cell data.
                          Copy and then paste back into the Excel sheet but in the formatted swap area.
                          Select the data to be changed and paste into the original table position.
                          The formula results will update.
                          Start back at the beginning! Re-copy the updated table and double click in the LO text box, paste.
                          Not perfect but seems to work. Basically it is a way of re-calculating a table using Excel and not having to do it manually.
                          Brian
