    [Plugin] 2.5D CAM Plugin 20121202
    80 Posts 32 Posters 101.2k Views 32 Watching
      Find line #701 and change:
      vert = new_faces[0].vertices
      to
      **if new_faces[0];**vert = new_faces[0].vertices**;else;vert = face.outer_loop.vertices;end**
      That part has a similar un-trapped call as before.
      If there are no new face there are no vertices ! πŸ˜’
      • ely862meE
        ely862me
        Yep, that seems to have made it work. Thanks a lot !
        There are some other errors appearing though.
        And the written code it is a bit bizarre, instead of just two passes of 15 mm it does like 4.. I hoped by using this plugin to get rid of the other a lot more complicated software to write the code for me(at least for the simple parts). I am about to complete the build of my CNC and last time I tried to do some works with it and because of the lack of the experience and proper software I had to let it go until the next time.
        I designed my router in Sketchup and that helped me a lot. Yet, if I would do it again, most likely I would change the design entirely- lots of parts seems now to be not well thought.
        error 2.txt
        Elisei (sketchupper)
        Come and See EliseiDesign
          Find lines #866-#869 in the RB file...
          filename = UI.savepanel "Save Gcode File", "c:\\", "default.nc" #header outputfile = File.new( filename, "w" )
          If you do not choose a file in the 'savepanel' the output fails badly.
          Change the lines to read...
          filename = UI.savepanel**(**"Save Gcode File", "c:\\", "default.nc"**)** #header **return nil unless filename;**outputfile = File.new( filename, "w" )
          This exits the file writing method if you have canceled the 'savepanel' - i.e. filename==nil...
            apochroma
            Hi TIG
            Seems great work to me. I give it a try this afternoon. Before, i was using SketchUcam.
            Your software was not intended to make pockets?
            That would be really great, if i could also cut pockets.
            At the moment it cuts only inner parts the nearest distant to the geometry.
            Do you still work at this plugin? Did you know, there are other guys working on a similar project?
            http://www.phlatforum.com
            Maybe sharing would be great? Otherwise, could you help me and tell me how i could make a pocket with your Plugin?
            Kind regards
            Claus
            This should be a pocket
              @Claus
              This not 'my' plugin.
              I simply stepped in to fix some issues it had...
              Perhaps someone else can advise you on setting up 'pockets' ?
              • T
                tramspotters
                I think I found another error:
                ( This file created by CNC_profile.rb )
                ( Cutter Diameter: 0.03937007874015748 )
                ( Stock Size: 7.330896464323272 x 1.3754388245933877 x 0.05905987881581955 )
                G21 ( Unit of measure: millimeter )
                G90 ( Absolute programming )
                M03 ( Spindle on [clockwise] )
                G00 Z5,000 F30 (Move safety height)
                G00 X0.00 Y.00 F100 ( Move to origin )
                G00 X3,321 Y4,880 F100
                G01 Z0.019685039370078546 F15
                G01 X3,321 Y4,880 Z0,500 F50
                G01 X14,173 Y4,880 Z0,500 F50
                Unit are millimeter, but the move in z direction is made in inches: G01 Z0.01968.... that are exactly 0.5mm. But where is the 0 level in z direction? On top of the bed or on top of the workpiece?
                Also the cutter diameter is given in inches.
                • K
                  kevplank
                  Did I miss something? I can't get the plugin to install. It's looking for an .rzb file. It won't recognize a .rz file. Did I miss something in the setup? -running OSX latest Sketchup version as of 01-01-16.
                  • BoxB
                    Start by going back one page and reading the answers to your own questions.
                      The Installer needs an RBZ file.
                      It's an old thread - the original comes in a ZIP file:
                      http://sketchucation.com/forums/download/file.php?id=98895
                      If you change the file-type suffix to ".rbz" it'll install.
                      You need the helper[s] mentioned earlier.
                      http://sketchucation.com/forums/viewtopic.php?p=443051#p443051
                      You'll also need to make the edits mentioned earlier !
                      http://sketchucation.com/forums/viewtopic.php?p=443070#p443070
                      http://sketchucation.com/forums/viewtopic.php?p=444949#p444949 [adjust for v2016 !!!]
                      Other fixes:
                      http://sketchucation.com/forums/viewtopic.php?p=562603#p562603
                      http://sketchucation.com/forums/viewtopic.php?p=562741#p562741
                      http://sketchucation.com/forums/viewtopic.php?p=562756#p562756
                      I 'gave up':
                      http://sketchucation.com/forums/viewtopic.php?p=572144#p572144
                      What to do repeated ! http://sketchucation.com/forums/viewtopic.php?p=555761#p555761
                      What NOT to do ! http://sketchucation.com/forums/viewtopic.php?p=555759#p555759
                      Other ideas: http://sketchucation.com/forums/viewtopic.php?p=541812#p541812
                      There might be better / newer tools available...
                      • K
                        kevplank
                        OK I got it. I found the post that said to change the name of the .zip file from .zip to .rzb and that worked like a charm. Now it's on to plugging in the gcode to my mach3 pre and post code and this should work like a charm. Thank you!!
                          Not to pick nits but rather to avoid confusion for someone else who might come along with a similar issue, it is not rzb as you've written several times. Instead, it is rbz for the file extension.
                            ModuleProduction
                            Hello, how to download the plugin? Or tell me is it posible to cut the pieces obtained with 3D software fusion cuisine here is the link of project SketchUp DXF:
                            https://onedrive.live.com/redir?resid=8C46341F9A818E64!1101%26amp;authkey=!AMHLt97zV81Nx9M%26amp;ithint=file%2cdxf
                            Pierre
                              MaterG
                              this plugin gives me the following error, whatever the value of safety distance is:
                              "Safety Height is lower than top of part. Please correct."
                              Therefore sometimes the program freeze and I notice in the outliner some outer and inner group being created and deleted.
                              The parameter "Safe distance from table" ("Safety Height" I suppose) is higher than the height of the model, so why does the message appears?
                              The test model and the settings used are attached, can you help me?
                              Other two question:
                              • I used inches values but what happens using another unit? How exactly unit measures are managed by this plugin?
                              • what means 2.5D? The GCode generated doesn't rappresent a truly 3D model?
                              Thank you.
                              cam_test.skp
                                @materg said:
                                Since your part is less than 8 in. tall and the Safety Height is set to 9 in., it's no wonder you're getting that message. What happens if you set the safety height to half an inch?
                                  MaterG
                                  @dave r said:
                                  @materg said:
                                  thanks for your reply
                                  first of all the safety heigth is NOT lower than the top of the part,
                                  furthermore even if I lower the value to 7.5 (smaller than the height of model) the message still appears, so definitely the message appears in both conditions, lower or higher then the heigth of the model.
                                  Did you test my model?
                                  Can I have a working example?
                                    You can make your own working model. Get rid of those hidden grids and try it again. It works fine for me without the grids. You'll have to unlock the one parallel to the red axis before you can delete it.
                                    My results
                                      MaterG
                                      [attachment=1:2ugannqm]<!-- ia1 -->Screenshot - 6_7_2016 , 5_13_32 PM.png<!-- ia1 -->[/attachment:2ugannqm]
                                      My results
                                      Thank for your help Dave!
                                      But still remain some serious glitches.
                                      Those grids where not selected so why the plugin process them?
                                      Therefore I exported the GCode for a simple cube, the file is attached and opencam gives me the errors reported in the screenshot.
                                      As you can see the decimal number are written with comma insted of point and this is not valid.
                                      I replaced the characters and the model is displayed correctly.
                                      Then I tried to work the model posted here but the program, after have processed it correctly, doesn't show the save dialog and crashes.
                                      At this point I wonder what the correct workflow is to generate GCode with sketchup? I open a thread in "SketchUp for 3D Printing" section but for some reason was moved in "SketchUp Pro & Make Discussions":
                                      http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=65111%26amp;p=597157#p597157
                                      Can you give me some hints?
                                      • G
                                        guyrob175
                                        I have just found this plugin and would love to have a go at using it, but I cant get it to work on 2013. Will it work on this version or newer versions?
                                          Did you try following TIG's directions here?
                                          I ran it in SU2016 and showed an example of the output.
                                          • FBPrescherF
                                            FBPrescher
                                            i have Sketchup 2017 pro and i can not seam to get this plugin to even show up let alone work. i'm very interested in this. can you shed some light on what to do?
                                            Trimbling Addiction can be a Good Thing!
                                            • 4 / 4
