    [Plugin] 2.5D CAM Plugin 20121202
    80 Posts 32 Posters 93.3k Views 32 Watching
      MgRasmussen
      I'm just getting my CNC up and running, and I'd like to use this plugin, but I can't seem to get it to load in the new version, Sketchup 2015. I have unloaded it into the correct folder (per Sketchup's own instructions, but it still doesn't want to load).
      Did try renaming the files from *.rb to *.rbz, but got an error when I tried to open the extension automatically using the Sketchup plugin installer.
      Thoughts?
        You can't just rename the rb file to rbz and expect it to work. Change the .zip extension to .rbz and try installing that with Install Extension.
          Thoughts?
          This toolset comes in a ZIP, if you change the .zip ending into .rbz, then you can install it with the Preferences > Extensions > Install... button.
          See this earlier post http://sketchucation.com/forums/viewtopic.php?p=541812#p541812
          However, it is an old Plugin and might not be compatible with v2015...
          Assuming it is installed properly try this in the Ruby Console:
          load "CNC-profile.rb"
          Plus <enter>
          It should return 'true' OR errors ?
          • ely862meE Offline
            ely862me
            I have no idea what this should mean.
            Error: #<ArgumentError: wrong number of arguments (1 for 0)>
            C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:86:in deactivate' C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:902:in select_tool'
            C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:902:in block in <module:CNC>' SketchUp:1:in call'
            C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC_Files/CNC_Profile_Defaults.txt
            Error: #<NoMethodError: undefined method outer_loop' for nil:NilClass> C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:535:in block in outside_offset'
            C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:468:in each' C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:468:in outside_offset'
            C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:218:in mode' C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:79:in activate'
            C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:902:in select_tool' C:/Users/Elisei/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/CNC-profile.rb:902:in block in module:CNC'
            SketchUp:1:in `call'
            Greatly appreciate any help.
            Elisei (sketchupper)
            Come and See EliseiDesign
              @Elisei
              Open the file ../Plugins/CNC-profile.rb in Notepad or Notepad++ and at line #86 change:
              def deactivate
              to
              def deactivate**(view)**
              Find line #535 and change:
              vert = new_face.outer_loop.vertices
              to
              **if new_face;**vert = new_face.outer_loop.vertices**;else;vert = face.outer_loop.vertices;end**
              Save it and restart SketchUp.
              See if that helps... πŸ˜•
              • ely862meE Offline
                ely862me
                Seems like it is acting better but still no results.
                I have attached the model I am working on and also the error in the ruby console.
                Thank you !
                Girld contour.skp
                error.txt
                  Find line #701 and change:
                  vert = new_faces[0].vertices
                  to
                  **if new_faces[0];**vert = new_faces[0].vertices**;else;vert = face.outer_loop.vertices;end**
                  That part has a similar un-trapped call as before.
                  If there are no new face there are no vertices ! πŸ˜’
                  • ely862meE Offline
                    ely862me
                    Yep, that seems to have made it work. Thanks a lot !
                    There are some other errors appearing though.
                    And the written code it is a bit bizarre, instead of just two passes of 15 mm it does like 4.. I hoped by using this plugin to get rid of the other a lot more complicated software to write the code for me(at least for the simple parts). I am about to complete the build of my CNC and last time I tried to do some works with it and because of the lack of the experience and proper software I had to let it go until the next time.
                    I designed my router in Sketchup and that helped me a lot. Yet, if I would do it again, most likely I would change the design entirely- lots of parts seems now to be not well thought.
                    error 2.txt
                      Find lines #866-#869 in the RB file...
                      filename = UI.savepanel "Save Gcode File", "c:\\", "default.nc" #header outputfile = File.new( filename, "w" )
                      If you do not choose a file in the 'savepanel' the output fails badly.
                      Change the lines to read...
                      filename = UI.savepanel**(**"Save Gcode File", "c:\\", "default.nc"**)** #header **return nil unless filename;**outputfile = File.new( filename, "w" )
                      This exits the file writing method if you have canceled the 'savepanel' - i.e. filename==nil...
                        apochroma
                        Hi TIG
                        Seems great work to me. I give it a try this afternoon. Before, i was using SketchUcam.
                        Your software was not intended to make pockets?
                        That would be really great, if i could also cut pockets.
                        At the moment it cuts only inner parts the nearest distant to the geometry.
                        Do you still work at this plugin? Did you know, there are other guys working on a similar project?
                        (www.phlatforum.com)
                        Maybe sharing would be great? Otherwise, could you help me and tell me how i could make a pocket with your Plugin?
                        Kind regards
                        Claus
                        This should be a pocket
                          @Claus
                          This not 'my' plugin.
                          I simply stepped in to fix some issues it had...
                          Perhaps someone else can advise you on setting up 'pockets' ?
                            tramspotters
                            I think I found another error:
                            ( This file created by CNC_profile.rb )
                            ( Cutter Diameter: 0.03937007874015748 )
                            ( Stock Size: 7.330896464323272 x 1.3754388245933877 x 0.05905987881581955 )
                            G21 ( Unit of measure: millimeter )
                            G90 ( Absolute programming )
                            M03 ( Spindle on [clockwise] )
                            G00 Z5,000 F30 (Move safety height)
                            G00 X0.00 Y.00 F100 ( Move to origin )
                            G00 X3,321 Y4,880 F100
                            G01 Z0.019685039370078546 F15
                            G01 X3,321 Y4,880 Z0,500 F50
                            G01 X14,173 Y4,880 Z0,500 F50
                            Unit are millimeter, but the move in z direction is made in inches: G01 Z0.01968.... that are exactly 0.5mm. But where is the 0 level in z direction? On top of the bed or on top of the workpiece?
                            Also the cutter diameter is given in inches.
                              kevplank
                              Did I miss something? I can't get the plugin to install. It's looking for an .rzb file. It won't recognize a .rz file. Did I miss something in the setup? -running OSX latest Sketchup version as of 01-01-16.
                              • BoxB Offline
                                Start by going back one page and reading the answers to your own questions.
                                  The Installer needs an RBZ file.
                                  It's an old thread - the original comes in a ZIP file:
                                  http://sketchucation.com/forums/download/file.php?id=98895
                                  If you change the file-type suffix to ".rbz" it'll install.
                                  You need the helper[s] mentioned earlier.
                                  http://sketchucation.com/forums/viewtopic.php?p=443051#p443051
                                  You'll also need to make the edits mentioned earlier !
                                  http://sketchucation.com/forums/viewtopic.php?p=443070#p443070
                                  http://sketchucation.com/forums/viewtopic.php?p=444949#p444949 [adjust for v2016 !!!]
                                  Other fixes:
                                  http://sketchucation.com/forums/viewtopic.php?p=562603#p562603
                                  http://sketchucation.com/forums/viewtopic.php?p=562741#p562741
                                  http://sketchucation.com/forums/viewtopic.php?p=562756#p562756
                                  I 'gave up':
                                  http://sketchucation.com/forums/viewtopic.php?p=572144#p572144
                                  What to do repeated ! http://sketchucation.com/forums/viewtopic.php?p=555761#p555761
                                  What NOT to do ! http://sketchucation.com/forums/viewtopic.php?p=555759#p555759
                                  Other ideas: http://sketchucation.com/forums/viewtopic.php?p=541812#p541812
                                  There might be better / newer tools available...
                                    kevplank
                                    OK I got it. I found the post that said to change the name of the .zip file from .zip to .rzb and that worked like a charm. Now it's on to plugging in the gcode to my mach3 pre and post code and this should work like a charm. Thank you!!
                                      Not to pick nits but rather to avoid confusion for someone else who might come along with a similar issue, it is not rzb as you've written several times. Instead, it is rbz for the file extension.
                                        ModuleProduction
                                        Hello, how to download the plugin? Or tell me is it posible to cut the pieces obtained with 3D software fusion cuisine here is the link of project SketchUp DXF:
                                        https://onedrive.live.com/redir?resid=8C46341F9A818E64!1101%26amp;authkey=!AMHLt97zV81Nx9M%26amp;ithint=file%2cdxf
                                        Pierre
                                          MaterG
                                          this plugin gives me the following error, whatever the value of safety distance is:
                                          "Safety Height is lower than top of part. Please correct."
                                          Therefore sometimes the program freeze and I notice in the outliner some outer and inner group being created and deleted.
                                          The parameter "Safe distance from table" ("Safety Height" I suppose) is higher than the height of the model, so why does the message appears?
                                          The test model and the settings used are attached, can you help me?
                                          Other two question:
                                          • I used inches values but what happens using another unit? How exactly unit measures are managed by this plugin?
                                          • what means 2.5D? The GCode generated doesn't rappresent a truly 3D model?
                                          Thank you.
                                          cam_test.skp
                                            @materg said:
                                            Since your part is less than 8 in. tall and the Safety Height is set to 9 in., it's no wonder you're getting that message. What happens if you set the safety height to half an inch?
                                            • 4 / 4
