    Need to split object
    19 Posts 10 Posters 3.7k Views 10 Watching
    • cottyC
      cotty
      Another solution with the plugin s4u_slice:
      click to animate
      my SketchUp gallery
        This last one is the more productive! 😎
        (Enable Internal - Plane By 3 Ppoints - Add Section Faces)
        • ntxdaveN
          ntxdave
          I have been able to get all of these methods to work except the Intersect Faces method from DaveR. I know I am doing something wrong with it. I remember seeing an animated tutorial on this once before but I cannot find it. DaveR, you may have been the one that posted it.
          I like doing things without plugins as much as possible so I would like to remember how to do the Intersect Faces for future references.
          @Box your method also works without a plugin but does require a fair amount of work to clean things up.
          Can someone point me to a good tutorial on the Intersect Faces method? I also am still a little confused on the difference of With Selection and With Model.
          Press F1...thank me later
          • pbacotP
            Where's the cleanup in Box's method? Looked pretty straight-forward and clean to me. Also a good reminder--quick and direct as any method. Requires objects are drawn right in the first place, whereas other methods "chopping" geometry can handle messy modelling.
            • ntxdaveN
              ntxdave
              You get a missing face on one of the groups and the other one had some missing lines because of the shape of the molding. Not a big deal, just needed some attention but otherwise pretty straight forward.
              Still wanting to understand how to use the "cutting plane" method @DaveR showed. I know it works but I am doing something wrong.
              • andybotA
                andybot
                are you working in the same active space? The intersect lines won't be added to the molding if you have the molding grouped. The plane should be in the same active context as the molding. (another way to do it if the molding is grouped is to open the molding, select all, and then go to context menu "intersect with model")
                • pbacotP
                  If you intersect with model to a face outside the group, you won't get a face made. You have to put the cutting face in the group and select all intersect with context or selected. But no matter. It's easy enough to add a face in this case. Just redraw an edge.
                  • BoxB
                    A cutting plane is just a way of drawing the lines on the surface all in one go.
                    In it's most basic form you need to be at the raw geometry level for it to work.
                    ie: the cutting plane must be touching the faces you want to cut, so if there are groups involved you must be in them for editing.
                    Here's 3 different versions of intersect.
                    See what happens when you intersect from outside the groups.
                    • ntxdaveN
                      ntxdave
                      Nice - this has turned into an interesting thread with multiple methods for achieving a useful task.
                      πŸ‘ πŸ‘
                        mrossk
                        I wonder if this is the video you thought you saw? From Aidan's tutorials from some years back : http://www.youtube.com/watch?v=PzOSwaUp_gc
                        https://www.mkaplanfinefurniture.com/
                        • ntxdaveN
                          ntxdave
                          No, this was not the video but it was interesting. I liked the thought of the Jigs. If you do something like that on a regular basis it was a good idea.
