    How to import dwg files into sketchup with faces?!
    3 Posts 2 Posters 1.0k Views 2 Watching
      sketchuh
      hi you all, I found a problem that when i import a dwg file the faces aren't there!!
      it's so painful if I have to recreate every face possible. is there a better way or a plugin that i can use to import dwg files? to turn 2d into 3d? Im using mac. so i haven't found a mac plugin for 2d to 3d. please help.
      thanks in advance.
      no faces there!!
        sketchuh
        the skp file:
        https://www.dropbox.com/s/dfxd70qyrmw533r/How%20to%20have%20faces.skp?dl=0
        the dwg file:
        https://www.dropbox.com/s/49qlgy7s6pnrnes/green-leaf-silhouettes-vector-set-leaves-silhouette-delicate-texture-illustration-342231621.dwg?dl=0
        • jujuJ Offline
          juju
          select all, right click, interact with all, should do the trick
