How to import dwg files into sketchup with faces?!
hi you all, I found a problem that when i import a dwg file the faces aren't there!!
it's so painful if I have to recreate every face possible. is there a better way or a plugin that i can use to import dwg files? to turn 2d into 3d? Im using mac. so i haven't found a mac plugin for 2d to 3d. please help.
thanks in advance.
select all, right click, interact with all, should do the trick
