    Help with wrapping around object
    14 Posts 5 Posters 1.4k Views 5 Watching
    • ely862meE
      ely862me
      You should draw that shape on a horizontal plane, then push it down and intersect it with the dome.
      You can do the same for the walls. Then group the intersections and play further rounding the corners and giving it thickness .
      Elisei (sketchupper)
      Come and See EliseiDesign
      • K
        Kashaki
        Hi Elisei,
        Thanks for your reply. But what do you mean with 'draw it on a horizontal plane and then push it down"? Because that knot shape is actually 'hugging' the dome shape but it is not hugging the blocked shape. It is coming from the dome in a curve and bending around the block.
        I have attached the file is it maybe possible to show what you mean?
        Thanks in advance,
        Kashaki
        Hak_shape2.skp
        • ely862meE
          ely862me
          Something like this. You draw the top shapes,then the sides. In a way that look like they are connected of course.
          • K
            Kashaki
            Hi Elisei,
            Thanks again, but this means that it will subtract it from the dome. I do not want to substract it. I want to make a new shape wrapping all around the rectangle and dome in a "knot" kindaway. It is difficult to explain but it is something like the picture attached. But then wrapping it around the rectangle and dome. Actually laying (in contact with) just above the dome but when coming down from the sides of the rectangle, not touching the rectangle, but coming in a curve following the curves of the dome and then bending around it.
            Thanks again,
            Kashaki
            • ely862meE
              ely862me
              You don't need to subtract it from the dome, you can simply make a copy of your shapes and work with them then move the resulted geometry over your actual building.
              • pbacotP
                I like Elisei idea to give you the form the shape follows on the dome but then you must continue with giving it thickness and extending beyond the dome, which is a "Hands-on" modeling job, which you may have to build bit by bit. You could continue the ribbons, making paths (curves) defining the "edges" of the ribbon and Extrude Tools to fill in a shape between those curves.
                • oceanembersO
                  oceanembers
                  Elisei is right. Like this:
                  http://i.imgur.com/SUDiUsn.gif
                  excuse the selection gore
                  • pbacotP
                    Nice example video!
                      Else you have the new Flowify by Caul! πŸ˜‰
                      By Panixia
                      http://sketchucation.com/forums/download/file.php?id=129686&mode=view/rokbox.jpg
                        Or FredoScale
                          Concept of the Flowify πŸ˜„
                          The only constraint : the "target surface" must be quadrangular!
                            • oceanembersO
                              oceanembers
                              I was getting into flowify the other day - really powerful stuff, I can see no end of possible applications.
                              http://i.imgur.com/3VWt3Vu.png
