    Storage
    23 Posts 17 Posters 2.5k Views 17 Watching
    • DanielD
      Daniel
      Excellent job, John.
      Even after it's been pointed out, the repetitive use of the same texture still doesn't jump out at me. By changing its scale and using it on different planes, I think he did a great job of doing a lot with the same texture.
      My avatar is an anachronism.
      • hellnbakH
        hellnbak
        While I too noticed some repetition in the stone textures, I didn't feel the need to say anything about it because I don't feel they detract in any way at all from John's consistently amazing work (which nobody here can come close to touching).
        And I noticed them only because I was specifically looking for them, and the only reason I was looking for them is because John's creations are so perfect I always feel the need to try and find something a little less than perfect. Just to make myself feel a little better about my inadequacies. Perhaps that is also why others scrutinize John's work so hard.
        I very rarely find anything.
        Please keep the masterpieces coming, John!
        • Bryan KB
          Ha! I knew it! You've been posting photographs all this time! πŸ˜†
          Incredible as always. πŸ‘ Each one better than the last.
          • marked001M
            marked001
            i think this might be the best one yet, john.
            http://www.revision21vis.com
            instagram: revi21on
            • tademaT
              tadema
              Thank you everyone for your comments I'm humbled by them 😳
              The model is too big to be covered in a single stone texture ~ 138m visible, but could easily have been fixed as TIG rightly pointed out with a little PP. To borrow a word he often uses but is very apt here.. it's "sloppy" PP.
              @ rodman100 your correct recycling was here long before the plastic bottle, I often use several textures to covey this.
              Whoever gave TIG's comment/opinion the thumbs down needs to take a look at themselves...childish.
              Once again thanks for the comments
              John
              • andybotA
                andybot
                wow, I had to do a double take that it's not a photograph! Great job πŸ˜„
                • BoxB
                  Lovely piece of work as usual! πŸ‘
                  • BoxB
                    Sorry I should have kept my mouth shut.
                    It's only me being sad bastard recognising the patterns in a brilliant rendering.
                      Brightened my day nicely, thanks John. Bloomin' marvellous.
                      • RichardR
                        Richard
                        Man, If there is any film studio looking for the development of an older english village YOU ARE DA MAN!
                        I actually like the repeat in the texture, it looks like the stone was sourced from different quarries or available sources which could well be the case.
                        BUILTBRAND.COM.AU
                        • 2 / 2
