    Geometry size not consistent in SU 2015
    32 Posts 10 Posters 2.9k Views 10 Watching
    • dereiD
      derei
      @cotty said:
      You draw the wall 12655 mm long and it is dimensioned that way?
      I can't reproduce this... if I create it with that length or scale it to that length, the dimension will reads as "1655,000000mm" in your file (and without the ~ with less accuracy).
      As you can see in my file, there is one 300mm dimension. That remained unchanged. But others change randomly. This is why I submitted this in SketchUp Bug Reporting. And the funny thing, this happened all over my model, not only on this walls. Could be the axis orientation?
      I attached the original file - with the original axis orientation. Is part of a house that has a specific orientation, based on some topographic measurements and terrain.
      the original file, preserving the axis orientation
      DESIGNER AND ARTIST DEREI.UK
        I work at much higher precision than needed for architectural applications and I've never seen SketchUp "randomly" change dimensions. It doesn't matter whether I'm working in imperial or metric units.
        • dereiD
          derei
          your answer is making the things even stranger... so, I am the only one who encountered this? Again - could be because of axis orientation? is there something wrong with that and I can't figure out?
            I don't know why axis orientation should affect it. Perhaps it has to do with having length snapping enabled? Try working with it disabled for awhile and see if that has any impact.
            • dereiD
              derei
              I actually used numeric input for all dimensions and axis inference. So, length snapping has nothing to do with his. Once I input a size and hit enter, it should go for that size, shouldn't ? The same with push-pull.
                It's the only thing different I see in your Units setup from mine so I thought it worth a try. I never use or want Length Snapping.
                I should have done this before. Note the x and z coordinates of the end points of the line. The line is a little off axis. I don't know why that is. There are several things that could account for it.
                • dereiD
                  derei
                  I see that off-axis... can't figure it why either. And is incredibly small displacement too. How can I check is my XYZ axis are perfectly perpendicular? As I said, the model's axis might be modified to align to the topo file.
                  • cottyC
                    cotty
                    I would follow Daves suggestion and try without the length snapping...
                    my SketchUp gallery
                    • dereiD
                      derei
                      I'll try that
                        I moved the model away from the origin a little to have clear access to the origin and then right clicked on it. If the axes had been changed, Reset would have been black instead of grayed out. There is some tolerance as in any drawing program. Sort of a close enough thing. Maybe you're running into that.
                        • dereiD
                          derei
                          Maybe. But if that's the case, SU should be fixed by Trimble to properly handle this tolerance. Like not showing the ~ symbol when that's the case. Somehow is reassuring to see that is not so common issue, that means is something that i shouldn't be so concerned for other drawings. But still annoying that i can't figure out why it's happening here.
                          thanks all for the effort. 👍
                            Every drawing program has to have some sort of tolerance setting.
                            It may not help but I don't see the ~ when I reduce the precision.
                            • dereiD
                              derei
                              [attachment=0:1r3zxqoz]<!-- ia0 -->Screenshot - 6_13_2015 , 8_52_26 AM.png<!-- ia0 -->[/attachment:1r3zxqoz]
                              That's what i was talking about...reducing precision places that strange symbol "~"
                                Do you see ~ in my screen shot anywhere? I don't see it.
                                • Wo3DanW
                                  Wo3Dan
                                  There shouldn't be any issue with creating your geometry without ~ and to accurate dimensions.
                                  Dave already mentioned that (some) faces aren't on axes planes.
                                  At some stage you may have inadvertently moved some geometry slightly off axis.
                                  Use the 'Tape Measure' tool > disable the +sign by hitting [Ctrl] once > click on a large face with the tool to fix its starting point > orbit to get the axis color perpendicular to that face > now also hold down [Shift] and see how the values change when measuring locations on that face where they all should read 0.000000
                                  I recreated your geometry next to yours, only relying on SketchUp's inferencing engine and estimated (your model) lengths to input. See attached model.
                                  Component_134_duplicated.skp
                                    Thinking about this reminds me that another member had a similar issue a few years ago. Turned out he had managed to get things off axis somehow. It was only slightly but enough to show in the dimensions.
                                    • pbacotP
                                      So if your object is not orthogonal it cannot have accurate dimensions? Really?
                                      • cottyC
                                        cotty
                                        No, if the geomtery is accurate, the dimensions will be too.
                                        my SketchUp gallery
                                        • Wo3DanW
                                          Wo3Dan
                                          That is not what I am saying.
                                          But working with some geometry that is slightly off means that you should be extra cautious when expecting to continue collinear or coplanar. The axes may draw new edges on axis
                                          Of course it is possible to model 'not orthogonal'.
                                          Also with geometry slightly off axis the 'Dimensiion' tool may indicate the ortoganal dimensions instead of the expected real edge lengths. Here again you can of course get the real edge lengths but SketchUp may trick you without bein noticed.
                                          Thing is that the original model wasn't accurate anymore, maybe due to moving some edges or faces.
                                          • dereiD
                                            derei
                                            But is interesting how the geometry ended slightly off-axis when all of it was drawn using axis inference.
                                            This was actually my problem... i know how to measure/check things... but I am still confused how can be possible that drawing parallel to axis can result in displaced geometry. And whats even stranger is that turning on ColorByAxis, all edges seemed aligned.
