    Watercolor palette for shapeways
    22 Posts 3 Posters 11.2k Views 3 Watching
    • cottyC Offline
      cotty
      you can try to add some hinges, one example...
      my SketchUp gallery
        tallbridgeguy
        That's cool but I'm not sure how it works?
        s
        Nielsen
        http://www.tallbridgeguy.com/
        • cottyC Offline
          cotty
          It's a kind of a simple click system...
          click to animate
          my SketchUp gallery
            tallbridgeguy
            That is really cool, have you tried on it on a project? I might have to go that a go.
            Thanks again for all the help! πŸ‘
            s
            Nielsen
            • cottyC Offline
              cotty
              No, I haven't. The difficult part will be to choose the right fit so that it can be rotated slightly and still holds together.
              my SketchUp gallery
                d12dozr
                Stuart, I'm always glad to help you, and even more pleased to you posted publicly. This way others with the same questions will benefit and you get answers faster. πŸ˜„
                I would try a sort of piano hinge, where half of the hinge parts are on the top of the box, and the other half are on the bottom half, then run a brass rod through for a pin.
                http://www.robertkarl.org/woodworkingblog/uploaded_images/PianoHinge-797236.jpg
                (not my image)
                1/16" should be thick enough, but you will have to paint or otherwise seal the plastic because it is very porous.
                You should also increase the resolution of the circles used to make the paint holding trays so that you get a smoother surface. Running fredo's Roundcorner plugin on the sharp corners is a good idea.
                http://goo.gl/f7ooYh
                  tallbridgeguy
                  Thanks I will give that a go! πŸ‘
                  s
                  Nielsen
                    tallbridgeguy
                    I have put some hinges on the boxes.
                    So the question, is it worth about $60 to print it?
                    How porous is the plastic, will it leak?
                    I just noticed I have to put some bump outs by the hinges, so when it is open it will stay flat..
                    thanks for all the help!
                    s
                    Nielsen
                      d12dozr
                      The hinges you made look great! Yes, the plastic will leak unless you paint it. $60 sounds about right for commercial printing. You could get it printed cheaper on a small desktop FDM machine, but the quality won't be nearly as good and you'll still have to seal it with paint or epoxy.
                        tallbridgeguy
                        I bought the four well side of the palette, $23 bucks delivered. I chose white polished plastic...
                        I thought I would see how good it is before buying the other side.
                        Thanks for all the help!
                        Stuart
                        Nielsen
                          d12dozr
                          πŸ‘ good thinking to just print a small part for testing, Stuart. Please let us know how it goes!
                            tallbridgeguy
                            I made a quick video to show the finished product.
                            s
                            Nielsen
                              d12dozr
                              Looks great, Stuart!
                                tallbridgeguy
                                Thanks for all your help!
                                It went great and I'm looking forward to doing more 3D things!
                                s
                                Nielsen
