    Watercolor palette for shapeways
    22 Posts 3 Posters 12.1k Views 3 Watching
    • T
      tallbridgeguy
      A few of more questions.
      I made the two sides, one for mixing paint and one for holding paint.
      1. any advice on a hinge for the box? I thought some hollow tubes and then I would put a metal rod through the holes when I get it.
      2. could this whole piece be printed together somehow?
      3. I made everything 1/16" thick. Will that be strong enough? The trays are each 7/16" tall
      s
      Nielsen
      http://www.tallbridgeguy.com/
      • T
        tallbridgeguy
        Strong and flexible plastic?
        thanks!
        s
        Nielsen
        • cottyC
          cotty
          Here are the design guidelines for this material...
          http://www.shapeways.com/materials/strong-and-flexible-plastic#guidelines
          my SketchUp gallery
          • T
            tallbridgeguy
            Thanks for the info! I think 1/16" = 1.5875 mm so it should be doable. Whether it is strong enough I don't know? Most of my plastic palettes are 1/16" thick, so I think it should work.
            I can print them separately but I need some hinges?
            thanks!
            s
            Nielsen
            • cottyC
              cotty
              you can try to add some hinges, one example...
              my SketchUp gallery
              • T
                tallbridgeguy
                That's cool but I'm not sure how it works?
                s
                Nielsen
                • cottyC
                  cotty
                  It's a kind of a simple click system...
                  click to animate
                  my SketchUp gallery
                  • T
                    tallbridgeguy
                    That is really cool, have you tried on it on a project? I might have to go that a go.
                    Thanks again for all the help! πŸ‘
                    s
                    Nielsen
                    • cottyC
                      cotty
                      No, I haven't. The difficult part will be to choose the right fit so that it can be rotated slightly and still holds together.
                      my SketchUp gallery
                        d12dozr
                        Stuart, I'm always glad to help you, and even more pleased to you posted publicly. This way others with the same questions will benefit and you get answers faster. πŸ˜„
                        I would try a sort of piano hinge, where half of the hinge parts are on the top of the box, and the other half are on the bottom half, then run a brass rod through for a pin.
                        http://www.robertkarl.org/woodworkingblog/uploaded_images/PianoHinge-797236.jpg
                        (not my image)
                        1/16" should be thick enough, but you will have to paint or otherwise seal the plastic because it is very porous.
                        You should also increase the resolution of the circles used to make the paint holding trays so that you get a smoother surface. Running fredo's Roundcorner plugin on the sharp corners is a good idea.
                        http://goo.gl/f7ooYh
                        • T
                          tallbridgeguy
                          Thanks I will give that a go! πŸ‘
                          s
                          Nielsen
                          • T
                            tallbridgeguy
                            I have put some hinges on the boxes.
                            So the question, is it worth about $60 to print it?
                            How porous is the plastic, will it leak?
                            I just noticed I have to put some bump outs by the hinges, so when it is open it will stay flat..
                            thanks for all the help!
                            s
                            Nielsen
                              d12dozr
                              The hinges you made look great! Yes, the plastic will leak unless you paint it. $60 sounds about right for commercial printing. You could get it printed cheaper on a small desktop FDM machine, but the quality won't be nearly as good and you'll still have to seal it with paint or epoxy.
                              • T
                                tallbridgeguy
                                I bought the four well side of the palette, $23 bucks delivered. I chose white polished plastic...
                                I thought I would see how good it is before buying the other side.
                                Thanks for all the help!
                                Stuart
                                Nielsen
                                  d12dozr
                                  πŸ‘ good thinking to just print a small part for testing, Stuart. Please let us know how it goes!
                                  • T
                                    tallbridgeguy
                                    I made a quick video to show the finished product.
                                    s
                                    Nielsen
                                      d12dozr
                                      Looks great, Stuart!
                                      • T
                                        tallbridgeguy
                                        Thanks for all your help!
                                        It went great and I'm looking forward to doing more 3D things!
                                        s
                                        Nielsen
