    Re: [Plugin] Quick Lathe v1.2.0 31mar2013
    58 Posts 23 Posters 66.4k Views 23 Watching
    • mitcorbM
      mitcorb
      Like Dave said. Many people hang on to their earlier versions of Sketchup.
        SpookyChick1013
        Update: Works beautifully under 7.1! This solves so many problems...Thanks awfully much, Trogluddite. THis does exactly everything I have wanted a lathe plugin to do without any major identifiable problems. Definitely going in my must have plugins file.
        @ Mitcorb. It could be worse, I could be one of those Paleo-Luddites who still uses SU 5!
        https://kuromatsudriveyards.com
        Fo-su to tomo ni aran koto o...
        • T
          Trogluddite
          You're welcome - and thankyou for "Beta testing" in SU7; I never used any of the older versions, but the guys are right, it should be made clear whether it is back-compatible (and Mac compatible for that matter - something else I haven't been able to test).
          Just to let everyone know - the new version with snazzy user interface and proper "arc push-pull" feature is still in the pipeline; but certain personal circumstances have left me without much time for Rubying for a few weeks - but it is not "abandon-ware"!
          • preetpaulP
            preetpaul
            hey, got ur plugin a bit.. but here's my problem...
            want to use 'follow me' that sector plane, around rectangle with round corners....
            quick lathe helps? how?
              Why don't you post at least a screen shot of what you're trying to accomplish? Your description is not clear.
                Anton_S
                Thankyou Trogluddite for the amazing plugin. I always wanted to draw with something more advanced than the follow me tool ๐Ÿ‘ ๐Ÿ˜„
                  mitchellch
                  Doesn't work for me. Once in a while I get the expected shape if I start with the simplest of shapes, but most of the time I get "Error in Quick Lathe: undefined method 'position' for #<sketchup::Edge:0x113...44".
                  I'm using SketchUp Pro 2013, Version 13.0.4811. Is ther an update?
                    Maybe you could post an example SKP file where it fails?
                    • T
                      tredekka
                      Awesome PlugIn... now it's one of my standard collection of tools!
                      This should have way more upvotes!
                      • Miner_JeffM
                        Miner_Jeff
                        Well done Sir!
                        Very useful Ruby indeed!
                        Thank you for the updates and additional feature programming.
                        Cheers!
                        Miner_jeff
                        ๐Ÿ‘ ๐Ÿ‘
                        • 3 / 3
