    Re: [Plugin] Quick Lathe v1.2.0 31mar2013
    58 Posts 23 Posters 66.4k Views 23 Watching
      Very funny! 😎
      You can select the face after the fonction and Scale or move it(with Alt)! 💭
      here Color by Slope by Chris Fullmer
      • T
        Trogluddite
        He he! 😲
        Wow, Pilou, you discovered a function that I didn't even know was there!
        This is a side effect of the "keep the hoops intact" function - if you show hidden edges, and try selecting once of the "ribs", you will see that they are all 'welded' - proper arc's with centre and radius.
        For a 360deg turned shape (e.g. chair leg), you can use this to play with the diameters of the hoops for easy re-shaping...
        ...but it never occurred to me that it would do this "tapering" effect, I had never even tested it to see what scale would do for an 'extrusion'.
        I must, of course, now check all the new code I'm working on for the next version - to make sure that I haven't broken this, because those shapes you're making are great!
        Hopefully will have the next update ready in a week or two - learning to make a decent GUI has been harder than the geometry, and more lines of code too!!
        I already have several of your suggestions working. For 'loose geometry' it will work much more like an 'arc push/pull', with no internal faces, and respecting the soft/smooth of the geometry that it joins on to - and with the 'pushed' face selected for easy 'follow on'.
        • X
          xEme77
          a GREAT rbz
            SpookyChick1013
            Apparently I'm missing something here. How do you install a .rbz when there is no "install" option in your plugins menu? I'd very much like to use QuickLathe, but there seems to be no way to install it on my system. WinXP, SU7.1
            https://kuromatsudriveyards.com
            Fo-su to tomo ni aran koto o...
            • BoxB
              You can change the file extension from .rbz to .zip then extract the contents and install in the usual way.
                You could update to SU8 and then you'd be able to install the RBZ file normally, too.
                • mitcorbM
                  mitcorb
                  In case it is unclear how to rename the file, look at this procedure:
                  http://www.mediacollege.com/microsoft/windows/extension-change.html
                  Keep in mind that the author may not have tested his script in earlier versions. Whether he did or did not would be nice to have this spelled out. So, proceed with caution, even though maybe nothing will happen, and the worst case may be that you will just need to uninstall.
                    What's not to like? And you can keep 7.1 if you want even with 8 installed.
                      SpookyChick1013
                      Wow, Thank you, gentlemen. Quicker replies than I expected.
                      @ Box: That was my first instinct, but I guess I psyched myself out and decided it couldn't be that simple, so I didn't even think to try.
                      @Dave R: Yeah, I suppose I could do that. Except that I didn't just plain didn't like SU8 when it came out.
                      Anyway, thanks, both of you.
                      Edit: Thanks Mitcorb. Looks like we cross-posted there. I'll report back on whether it works with 7.1
                      Just to clarify; I may finally switch over to SU 8 when I finally get the new machine I've been trying to get for over a year. Right now, this thing is a delicate balance in order to even keep the machine running, and it's not worth it to muck about with SU 8 when I'm sooner or later going to be redoing everything anyway.
                      Thanks, all
                      • mitcorbM
                        mitcorb
                        Like Dave said. Many people hang on to their earlier versions of Sketchup.
                          SpookyChick1013
                          Update: Works beautifully under 7.1! This solves so many problems...Thanks awfully much, Trogluddite. THis does exactly everything I have wanted a lathe plugin to do without any major identifiable problems. Definitely going in my must have plugins file.
                          @ Mitcorb. It could be worse, I could be one of those Paleo-Luddites who still uses SU 5!
                          • T
                            Trogluddite
                            You're welcome - and thankyou for "Beta testing" in SU7; I never used any of the older versions, but the guys are right, it should be made clear whether it is back-compatible (and Mac compatible for that matter - something else I haven't been able to test).
                            Just to let everyone know - the new version with snazzy user interface and proper "arc push-pull" feature is still in the pipeline; but certain personal circumstances have left me without much time for Rubying for a few weeks - but it is not "abandon-ware"!
                            • preetpaulP
                              preetpaul
                              hey, got ur plugin a bit.. but here's my problem...
                              want to use 'follow me' that sector plane, around rectangle with round corners....
                              quick lathe helps? how?
                                Why don't you post at least a screen shot of what you're trying to accomplish? Your description is not clear.
                                  Anton_S
                                  Thankyou Trogluddite for the amazing plugin. I always wanted to draw with something more advanced than the follow me tool 👍 😄
                                    mitchellch
                                    Doesn't work for me. Once in a while I get the expected shape if I start with the simplest of shapes, but most of the time I get "Error in Quick Lathe: undefined method 'position' for #<sketchup::Edge:0x113...44".
                                    I'm using SketchUp Pro 2013, Version 13.0.4811. Is ther an update?
                                      Maybe you could post an example SKP file where it fails?
                                      • T
                                        tredekka
                                        Awesome PlugIn... now it's one of my standard collection of tools!
                                        This should have way more upvotes!
                                        • Miner_JeffM
                                          Miner_Jeff
                                          Well done Sir!
                                          Very useful Ruby indeed!
                                          Thank you for the updates and additional feature programming.
                                          Cheers!
                                          Miner_jeff
                                          • 3 / 3
