    RBeautify - Ruby Code Beautifier
    8 Posts 4 Posters 2.3k Views 4 Watching
    • Al HartA
      Al Hart
      There are a couple of things I like to do to Ruby code to make it easier to work with:
      1. Use Indents properly to make it easy to follow groups of code
      2. Add #xxx after 'end' to make it easier to remember what they are the end of:
      #e.g.
          if (a == b)
              c = d
          end#if
      (I really wish the Ruby inventors had not decided to use the same word, 'end', for the end of everything. It would make it a lot easier to track down mistakes.
      1. Make blank lines consistent.
      So I borrowed a Ruby Beautifier Script from Paul Lutus, (which did #1), and added logic to it to do #2 and #3.
      I have attached a copy if you want to try it out.
      new version 5/29/2015
      Here is what it does to a ruby script which was already in good shape - bomb.rb by Rick Wilson (A free script I downloaded from Smustard)
      Original on right, RBeautify version on left
      (This output is from Araxis Merge - a great program we use to show changes between versions of source code)
      Al Hart
      IRender nXt from Render Plus
      • C
        cesaro36
        Hi Al
        I'm trying to use your rbeautify.rb but I get this error:
        RBeautify.beautify_file("c:/rotular.rb")
        Error: #<NoMethodError: undefined method each' for #<String:0x0000000fef1050>> C:/rbeautify.rb:90:in beautify_string'
        C:/rbeautify.rb:194:in beautify_file' <main>:in <main>'
        SketchUp:1:in `eval'
        where rotular.rb is just a generic rb that I'm using as a sample.
        Could you please help me?
        Tks
          This is an old script.
          It's not compatible with >= v2014's Ruby 2.
          You can 'fix it' by finding the offending line -
          source.each do |line|
          that is processing the string OK in earlier Ruby's and use something like:
          source**.split**.each do |line|
          IMHO the script is a bit flawed and flaky.
          It uses $ global variables that are frowned on in current coding circles...
          You'd be better off getting Notepad++ [or TextWrangler for MAC] and using its built-in Ruby syntax highlighting and learn to indent your code manually as you go...
          That would do much of what Al's script did anyway 😕
          • sdmitchS
            sdmitch
            @cesaro36 said:
            Hi Al
            Tks
            I just downloaded this plugin and the line numbers,C:/rbeautify.rb:90:in beautify_string' and C:/rbeautify.rb:194:in beautify_file', don't seem to match the current version. My initial test produced a similar error but at C:/rbeautify.rb:146:in beautify_string' and C:/rbeautify.rb:368:in beautify_file'.
            After changing line 146 from "source.each do |line|" to "source.each_line do |line|", the plugin worked. So I would suggest downloading a new copy and make that change.
            http://sdmitch.blogspot.com/
            • Al HartA
              Al Hart
              [Seems to be working ok - give it a try]
              SketchUp 2014 and 2015, (ruby 1.9), changed the name of the .each function for strings.
              Change line 146 or 147 to read:
              I have also uploaded a new version into the original post.
              Al Hart
              • sdmitchS
                sdmitch
                Al, The only problem I have encountered is a line with multiple closing braces, ie }}}.
                This causes an imbalance between indents and outdents. I don't know enough about regular expressions to know it is even possible to trap such a string.
                • C
                  cesaro36
                  Wow thank you all,
                  Now it does what I needed.
                  Anyhow I found a workaround by using the sublime text 2 code editor.
                  Here it is:
                  https://packagecontrol.io/packages/RubyFormat
                  Gracias
                  ¡Saludos a todos!
                  • Al HartA
                    Al Hart
                    I found a different problem. I was using this code to set a string:
                    (This loads all text up to the word HERE into a string with new lines, etc.)
                    ` smess = <<HERE
                    This face will not render in the material you have created, since it is on placed the reverse side of a face.
                    Use "Setup Options/Special/Process 2 Sided Faces" to allow materials on reverse faces to be rendered.
                    HERE`
                    and the beautifier indented the last line (HERE) which cause the ruby to fail
                    Al Hart
