    Write to serial port with Ruby [SOLVED!]
    19 Posts 7 Posters 22.7k Views 7 Watching
      Bas9999
      Hello Anton_S
      I've tested it with Sketchup 2015... 😍 , it works like a charm!
      This is the code to read data for the serial port so far...
      onstart{
        @serial = Serial.new('COM8', 9600)
      ontick{
        MSketchyPhysics3.closeControlPanel if frame == 1
        $serialdata = eval(@serial.read(1024))
        logLine("Serial data; " + $serialdata.to_s)
        logLine("")
        logLine("")
        logLine("")
        logLine("")
        logLine("")
        logLine("")
      onend{
        @serial.close
      Thank you!, i see if i can make a script that SENDS data to the Arduino / Raspberry...
        mptak
        I see you tested it with SU2015...this confuses me. Were you using the 64 bit version of sketchup? Which Sketchy Physics download did you use? Thanks.
          Anton_S
          I'm glad it works with SU2014 😉
            Bas9999
            No, i used the 32-bit version of SU2015, sketchyphysics does not work on 64-bit (yet)
              Bas9999
              Hi All,
              This is an example how to SEND data to the Arduino with SU 14/15, SketchyPhysics and Ruby Serial
              First the Arduino programming, here is the code to lit the integrated LED on digital 13, when there is a serial "1" recieved, the LED goes out when there is a "0" recieved.
              Arduino code:
              String readString;
              void setup() {
                pinMode(13, OUTPUT);
                Serial.begin(9600);
              void loop() {
                while (Serial.available()) {
                  delay(3);
                  if (Serial.available() >0) {
                    char c = Serial.read();
                    readString += c;
                if (readString.length() >0) {
                  if (readString == "1") { digitalWrite(13, HIGH); }
                  if (readString == "0") { digitalWrite(13, LOW); }
                  readString = "";
              Now...once programmed, create a sketchyphysics solid and paste this code in it:
              onstart{
              onclick{
                @m = Sketchup.active_model.materials.add "My material"
                group.material = @m
                @m.color="Yellow"
                logLine("LED ON!")
                @serial.write('1')
              onunclick{
                group.material = @m
                @m.color="White"
                logLine("LED OFF!")
                @serial.write('0')
              ontick{
              onend{
                @serial.close
              How does this work?
              When you run the script and click on the solid, the color will change to yellow and over the serial port a "1" will be send, de Arduino will recieve this "1" and will put on the LED light, when you release the mouse button, the model changes color back to white and a "0" will be sent, the Arduino recieves this and will put the LED light out!
              Have fun!
              Ps. Is there any code to read out a textbox or something (userinput possible?), where the user can specify the COMPORT and BAUDRATE?
              I think i will start to create the 204/2015 walktrough soon!, this will be the banner for the
              projects:
              SU_14_15 - Ruby Serial SEND Example with Sketchup Sketchyphysics.skp
                Bas9999
                Hi Anton_S
                *EDIT SOLVED!!! SEE BELOW
                Could you assist on this one?
                When for example i use a diffrent baudrate (on purpose) i still get this error:
                The original code was:
                ontick{
                  string_size = 1024
                  $serialdata = eval(@serial.read(string_size))
                I changed it to this, but that doesn't work:
                ontick{
                  string_size = 1024
                  begin
                  rescue RubySerial;;Exception => e
                    @serial.close if @serial
                    MSketchyPhysics3;;SketchyPhysicsClient.physicsReset
                    UI.messagebox("ERROR!")
                How to catch this error?
                *EDIT SOLVED!!!
                I just changed the line to:
                $serialdata = @serial.read(string_size)
                so it's only:
                ontick{
                  picpic020960
                  Hello
                  fine !
                  but the link above is dead
                  https://googledrive.com/host/0B3qg8f4WrNdHdHVyLVFuaHRjOTA/ffi%20+%20rubyserial.zip
                  help and thanks
                    Anton_S
                    Hello Bas9999,
                    I managed to tweak ffi and rubyserial (suggested by driven) into the plugins for SU. Download
                    https://googledrive.com/host/0B3qg8f4WrNdHdHVyLVFuaHRjOTA/ffi + rubyserial.zip
                    ffi + rubyserial.zip and extract into the plugins folder. It should work on Windows with SU2014 and SU2015. The advantage of it is that it doesn't require Python to run.
                    Here is RubySerial usage Wiki: https://github.com/hybridgroup/rubyserial
                    This is how I think your code should look like:
                    onstart {
                    ontick {
                      string_size = 1024
                      $serialdata = eval( @serial.read(string_size) )
                    onend {
                      @serial.close
                    Note: If particular serial port does not exist, an error will be raised causing simulation to reset.
                    If you want ffi and rubyserial to work with SU2013 and prior, you should upgrade SU ruby msvcrt to 1.8.6 or later. Do this by going to SketchUp Program Files, to the path of SketchUp.exe, and replace msvcrt-ruby18.dll with the new one, which can be downloaded [url=https://googledrive.com/host/0B3qg8f4WrNdHdHVyLVFuaHRjOTA/msvcrt-ruby18.zip:196vcuuf]here[/url:196vcuuf].
                    Tell me how it goes as I don't think I have any serial ports to test myself.
                    Anton
                      Anton_S
                      That's strange. For some reason SketchyUcation can't parse the url properly. Try using this unparsed link instead: https://googledrive.com/host/0B3qg8f4WrNdHdHVyLVFuaHRjOTA/ffi + rubyserial.zip
                        picpic020960
                        the download is OK
                        but other pb : i want to test the bas9999 example but
                        it's SU2015 version.
                        On my Vista dsktop only SU2014 supported.
                        Can everybody downgrade bas9999 sketchup model file from SU2015 to SU2014
                        More thanks
                        NB : maybe the serial port work with ruby without SU-Physics ?
                         if yes , how to ?
                          Here's a v2014 version SU_14_15 - Ruby Serial SEND Example with Sketchup Sketchyphysics[v2014].skp
                            Anton_S
                            if yes , how to ?
                            Yes, Ruby Serial works without SketchyPhysics.
                            It's easy to use:
                            # Require the library
                            require 'rubyserial'
                            # Instantiate serial
                            my_serial = Serial.new(address, baude_rate = 9600, data_bits = 8)
                            # Get data and do whatever you want with it
                            size = 1024
                            data = my_serial.read(size)
                            # Set data
                            data = ""
                            my_serial.write(data)
                            # Close serial once you're done using it
                            my_serial.close
                            my_serial = nil
                            See this link for more info: https://github.com/hybridgroup/rubyserial
                              tomasz
                              I installed the 'rubyserial' gem, but the initialization of Serial.new("COM3")
                              crashes for me in SU2019 Win 10.
                              rubyserial-0.6.0.gem
                              ffi-1.11.3-x64-mingw32.gem
                              I will try to figure out why it does that.
                              Does anyone have had a success with 'rubyserial' in SU2019?
                                tomasz
                                I have found the answer. It is ffi gem crashing in Win10 in SU2017...18...19
                                https://forums.sketchup.com/t/sketchup-2017-crashes-when-ffi-is-loaded-in-windows-10/40372
