    Write to serial port with Ruby [SOLVED!]
    19 Posts 7 Posters 21.6k Views 7 Watching
      Bas9999
      Hi all,
      I've made some projects to control 3D objects with an Arduino with connected hardware, like potentiometers and gyroscopes (making mini games 😉 ), just trough the serial interface.
      Therefore i am using:
      • SketchUp 8
      • Sketchup 8 plugin - SketchyPhysics v3.5.6
      • Sketchup 8 plugin - Supy v1.6 for Python v2.5
      • Python 2.5
      • Python 2.5 library – PySerial v2.5
      But... does SuPy v1.6 work in SU2014 / SU2015?
      I know there are Ruby changes with the 2.x version that break scripts, but this was from SU2014 to SU 2015 right?
      In SketchUp 8 you just could do:
      onstart{
        Py.exec("import serial")
        Py.exec("ser = serial.Serial('COM8', 9600)")
      ontick{
        Py.exec("serialdata = ser.readline()")
        $serialdata = Py.eval("serialdata")
      onend{
        Py.exec("ser.close()")
      And in the controller box you could put:
      $serialdata.to_f
      So...i was wondering if there is any Ruby GEM needed to make serial things happen?, and wat would be a sample code?
      Please let me know!
        Anton_S
        I found source code for SuPy and I will see if it could be compiled under 2.0.0. If compiling goes with success, I'll post SuPy compatible with SU2014 and SU2015.
        Anton
          driven
          have either of you had a look at RubySerial
          http://artoo.io/blog/2014/07/18/introducing-rubyserial/#.VPMWVUKUmDA
          it's on my 'long' list but I haven't chased it up yet...
            Anton_S
            Nice find, John!
            I find it very convincing as it has been kept up to date with latest Ruby version and doesn't require installation of Python. However, it does require Ruby FFI gem, which needs to have some tweaking before it can be used with SU.
            Anton
              Bas9999
              Hi Anton_S & driven,
              Wow, i really hope you can make this work!, so that we can use the new SU version to communicate with a serial port, we can make lots of cool things with Arduino & Raspberry.
              If i need to test something, let me know!
              Thanks in forward!
                Bas9999
                Hello Anton_S
                I've tested it with Sketchup 2015... 😍 , it works like a charm!
                This is the code to read data for the serial port so far...
                onstart{
                  @serial = Serial.new('COM8', 9600)
                ontick{
                  MSketchyPhysics3.closeControlPanel if frame == 1
                  $serialdata = eval(@serial.read(1024))
                  logLine("Serial data; " + $serialdata.to_s)
                  logLine("")
                  logLine("")
                  logLine("")
                  logLine("")
                  logLine("")
                  logLine("")
                onend{
                  @serial.close
                Thank you!, i see if i can make a script that SENDS data to the Arduino / Raspberry...
                  mptak
                  I see you tested it with SU2015...this confuses me. Were you using the 64 bit version of sketchup? Which Sketchy Physics download did you use? Thanks.
                    Anton_S
                    I'm glad it works with SU2014 😉
                      Bas9999
                      No, i used the 32-bit version of SU2015, sketchyphysics does not work on 64-bit (yet)
                        Bas9999
                        Hi All,
                        This is an example how to SEND data to the Arduino with SU 14/15, SketchyPhysics and Ruby Serial
                        First the Arduino programming, here is the code to lit the integrated LED on digital 13, when there is a serial "1" recieved, the LED goes out when there is a "0" recieved.
                        Arduino code:
                        String readString;
                        void setup() {
                          pinMode(13, OUTPUT);
                          Serial.begin(9600);
                        void loop() {
                          while (Serial.available()) {
                            delay(3);
                            if (Serial.available() >0) {
                              char c = Serial.read();
                              readString += c;
                          if (readString.length() >0) {
                            if (readString == "1") { digitalWrite(13, HIGH); }
                            if (readString == "0") { digitalWrite(13, LOW); }
                            readString = "";
                        Now...once programmed, create a sketchyphysics solid and paste this code in it:
                        onstart{
                        onclick{
                          @m = Sketchup.active_model.materials.add "My material"
                          group.material = @m
                          @m.color="Yellow"
                          logLine("LED ON!")
                          @serial.write('1')
                        onunclick{
                          group.material = @m
                          @m.color="White"
                          logLine("LED OFF!")
                          @serial.write('0')
                        ontick{
                        onend{
                          @serial.close
                        How does this work?
                        When you run the script and click on the solid, the color will change to yellow and over the serial port a "1" will be send, de Arduino will recieve this "1" and will put on the LED light, when you release the mouse button, the model changes color back to white and a "0" will be sent, the Arduino recieves this and will put the LED light out!
                        Have fun!
                        Ps. Is there any code to read out a textbox or something (userinput possible?), where the user can specify the COMPORT and BAUDRATE?
                        I think i will start to create the 204/2015 walktrough soon!, this will be the banner for the
                        projects:
                        SU_14_15 - Ruby Serial SEND Example with Sketchup Sketchyphysics.skp
                          Bas9999
                          Hi Anton_S
                          *EDIT SOLVED!!! SEE BELOW
                          Could you assist on this one?
                          When for example i use a diffrent baudrate (on purpose) i still get this error:
                          The original code was:
                          ontick{
                            string_size = 1024
                            $serialdata = eval(@serial.read(string_size))
                          I changed it to this, but that doesn't work:
                          ontick{
                            string_size = 1024
                            begin
                            rescue RubySerial;;Exception => e
                              @serial.close if @serial
                              MSketchyPhysics3;;SketchyPhysicsClient.physicsReset
                              UI.messagebox("ERROR!")
                          How to catch this error?
                          *EDIT SOLVED!!!
                          I just changed the line to:
                          $serialdata = @serial.read(string_size)
                          so it's only:
                          ontick{
                            picpic020960
                            Hello
                            fine !
                            but the link above is dead
                            https://googledrive.com/host/0B3qg8f4WrNdHdHVyLVFuaHRjOTA/ffi%20+%20rubyserial.zip
                            help and thanks
                              Anton_S
                              Hello Bas9999,
                              I managed to tweak ffi and rubyserial (suggested by driven) into the plugins for SU. Download
                              https://googledrive.com/host/0B3qg8f4WrNdHdHVyLVFuaHRjOTA/ffi + rubyserial.zip
                              ffi + rubyserial.zip and extract into the plugins folder. It should work on Windows with SU2014 and SU2015. The advantage of it is that it doesn't require Python to run.
                              Here is RubySerial usage Wiki: https://github.com/hybridgroup/rubyserial
                              This is how I think your code should look like:
                              onstart {
                              ontick {
                                string_size = 1024
                                $serialdata = eval( @serial.read(string_size) )
                              onend {
                                @serial.close
                              Note: If particular serial port does not exist, an error will be raised causing simulation to reset.
                              If you want ffi and rubyserial to work with SU2013 and prior, you should upgrade SU ruby msvcrt to 1.8.6 or later. Do this by going to SketchUp Program Files, to the path of SketchUp.exe, and replace msvcrt-ruby18.dll with the new one, which can be downloaded [url=https://googledrive.com/host/0B3qg8f4WrNdHdHVyLVFuaHRjOTA/msvcrt-ruby18.zip:196vcuuf]here[/url:196vcuuf].
                              Tell me how it goes as I don't think I have any serial ports to test myself.
                              Anton
                                Anton_S
                                That's strange. For some reason SketchyUcation can't parse the url properly. Try using this unparsed link instead: https://googledrive.com/host/0B3qg8f4WrNdHdHVyLVFuaHRjOTA/ffi + rubyserial.zip
                                  picpic020960
                                  the download is OK
                                  but other pb : i want to test the bas9999 example but
                                  it's SU2015 version.
                                  On my Vista dsktop only SU2014 supported.
                                  Can everybody downgrade bas9999 sketchup model file from SU2015 to SU2014
                                  More thanks
                                  NB : maybe the serial port work with ruby without SU-Physics ?
                                   if yes , how to ?
                                    Here's a v2014 version SU_14_15 - Ruby Serial SEND Example with Sketchup Sketchyphysics[v2014].skp
                                      Anton_S
                                      if yes , how to ?
                                      Yes, Ruby Serial works without SketchyPhysics.
                                      It's easy to use:
                                      # Require the library
                                      require 'rubyserial'
                                      # Instantiate serial
                                      my_serial = Serial.new(address, baude_rate = 9600, data_bits = 8)
                                      # Get data and do whatever you want with it
                                      size = 1024
                                      data = my_serial.read(size)
                                      # Set data
                                      data = ""
                                      my_serial.write(data)
                                      # Close serial once you're done using it
                                      my_serial.close
                                      my_serial = nil
                                      See this link for more info: https://github.com/hybridgroup/rubyserial
                                        tomasz
                                        I installed the 'rubyserial' gem, but the initialization of Serial.new("COM3")
                                        crashes for me in SU2019 Win 10.
                                        rubyserial-0.6.0.gem
                                        ffi-1.11.3-x64-mingw32.gem
                                        I will try to figure out why it does that.
                                        Does anyone have had a success with 'rubyserial' in SU2019?
                                          tomasz
                                          I have found the answer. It is ffi gem crashing in Win10 in SU2017...18...19
                                          SketchUp crashes when FFI is loaded in Windows 10
                                          Hi, I’m trying to load the FFI gem version (ffi-1.9.17-x64-mingw32) in Windows 10, Sketchup 2017 (maintenance build - 17.2.2555). Edit note: In my old post, I had only loaded the ffi_c.so file corresponding to ruby ver…
                                          SketchUp Community (forums.sketchup.com)
