    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Solid Inspector
    303 Posts 99 Posters 275.5k Views 98 Watching
    • KrisidiousK Offline
      Krisidious
      ๐Ÿ‘
      By: Kristoff Rand
        Version 2.2.1 is now available in the Plugin Store and Extension Warehouse.
          Krisidious
          Used it on this group and it worked except when it came to the 11 reversed faces. it left 3 faces reversed and when I went to manually flip them I noticed there were 4 reversed faces and not just 3.
          Group_111.skp
          By: Kristoff Rand
            When I opened that file I visually saw 4 reversed faces - and SI detected 4.
            Where are the 11 you talked about? Different model?
              Krisidious
              Yes, this model is after I fixed the 11... I had already saved and didn't bother undoing back before it. sorry. I got 3 on mine with new version. strange. But I didn't restart SU after install? Not a big deal to me though.
              By: Kristoff Rand
                Can you reproduce it?
                If you didn't restart after updating you might be still have been using the old version.
                  Krisidious
                  after restarting SU I get this... ๐Ÿ˜„
                  By: Kristoff Rand
                  • jgbJ Offline
                    jgb
                    I don't know if something ain't right or what....
                    I really like the improved SI over what I had been using in SU 8 for years.
                    I'm now on SU-15.
                    But I just noticed that the found errors are not highlighted with big red/yellow circles. Up until yesterday, that was not a problem, as SI fixed 100% of my errors. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                    But then there was a new error (can't remember exactly what) that only offered info and no fix. The problem was the line was so tiny, even in red, that it took me about an hour to find it in an object with over 4,000 lines. Only by zooming in and going over the whole thing twice (2 separate but identical errors) did I find the tiny red lines, deleting them, and all was OK.
                    No red circle to guide me to the errors. Why?
                    jgb
                      Did you not see a label in the viewport pointing to the edge?
                      (got sample model or screenshot?)
                      • jgbJ Offline
                        jgb
                        I do not recall seeing anything other than the warnings box.
                        I will try to set up a "fail" and see if I get that same error message, or see a viewport.
                        Stay tuned......
                        10 min later ====================
                        Well I did not get the same error msg with this test, but I got an error msg without a circle or a "viewport" pointing me to where the error was, in this case an external face.
                        It is at the top center of the comp.
                        Unless I zoomed in, I would not see where it was, especially if it were much smaller.
                        The error is hard to find without a red circle.
                        Can't see the error!
                        jgb
                          I have an issue filed for adding back functionality to circle highlight the errors.
                          • jgbJ Offline
                            jgb
                            That would be great. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                            Thank you.
                            jgb
                            • jgbJ Offline
                              jgb
                              Another problem.....
                              Inspector says "all Shiny" but SU-15 says not solid. ๐Ÿ˜ฎ
                              Why??
                              SI2 says Shiny, but it is not solid.
                              jgb
                                I could see the problem immediately upon opening the file. There are two overlapping faces. Delete one of them and it's solid. Why SI2 doesn't detect it is a good question, though.
                                • jgbJ Offline
                                  jgb
                                  Thank you. That is in the very same small area that I had a lot of SI2 found errors (most it could not fix) that took a while for me to find (no circles!!) and manually fix.
                                  How did you find it so fast???
                                  jgb
                                    It showed up white when I opened the SKP file and appeared to flicker as I orbited indicating z-fighting. It wasn't difficult at all to locate.
                                    • BoxB Offline
                                      Use Tab to cycle through.
                                        SketchUp perform a very naive manifold test - if all edges have exactly 2 faces connected.
                                        However - there are edge cases where this fails, like with this model:
                                        Solid Inspector use a different method to detect solids. However, in this case with the overlapping face (which shouldn't happen) it fails to detect this anomaly.
                                        • jgbJ Offline
                                          jgb
                                          Now that I knew where to look, I copied the comp to 1 side and saw the white face.
                                          Gone in 5 seconds and fixed! Thanks again Dave. ๐Ÿ‘ ๐Ÿ‘
                                          In its original location those gear teeth in that area were visually covered by another gear (comp) so I could not see it. It was also the same area that SI2 found numerous non-fixable errors, and in my manual search and cleanup, missed that one. I never looked at the isolated comp I sent to this thread.
                                          ThomThom: Is this sort of error findable or fixable in SI2?
                                          I don't recall having this sort of error undetected in earlier SU-8 versions of SI.
                                          jgb
                                            I ran it in CleanUp - which actually does look for these kind of things (but off by default because it's a very slow thing to do) but even that seemed to fail to detect it.
                                            Not sure what's going on with that model...
                                            • 15
                                            • 16
                                            • 3 / 16
