    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Auto connect points with component (stretching)
    8 Posts 4 Posters 362 Views 4 Watching
      Lersince1991
      I have 2000 points which I need to connect up using the same component.
      Essentially this is a walkway and the points are where the posts come up.
      I'd like to add rope between each point (nearest points) as a kind of hand rail, and it would be good for performance if that span of rope between each point was the same component but rotated and stretched/scaled along a single axis.
      I have attached my points for your reference.
      Does anyone know how I could do this?
      The only alternative for me would be to draw up them all and extrude it pretending its good enough.
      I don't have time to move & copy, rotate and then scale every block individually.
      points.skp
        Sam D Mitch made a tool to link cpoints.
        http://sketchucation.com/pluginstore?pln=Connect_Guide_Points
        If you make the connected edges you could then use a tool [I think SDM also has one - 'Add&AlignComponent' ?] to replace selected edges with say a cube component which is inserted at each edge's start, then stretched along that edge direction/length.
        Visit his web-site for more info/ideas... http://sdmitch.blogspot.co.uk/
          Lersince1991
          Many thanks TIG as always, a great idea.
          I'm connect the points manually as no program will know which points to connect to another.
          So now I'm looking to replace the edges with a component which is rotated and stretched.
          I've installed the plugin you recommended but its not doing what I hoped. 😳
            If you want a 'tube' then this will add tubes to selected edges...
            You can adjust the diameter, reduce the number of sides etc...
            http://sketchucation.com/pluginstore?pln=lines2tubes
              Lersince1991
              That would be good, might be the way to go, can it 'droop' a little between end points of the line? (i.e. 150mm droop) a slight arc
                Lersince1991
                ok I've made the paths (using illustrators join points), imported in SKU again and generated the tubes.
                That will do for now, but does anyone know if I can make them droop down in the middle a bit?
                Basically I would need to convert each edge into an arc and then run the lines2tubes again.
                Any idea how to do this?
                • sdmitchS Offline
                  sdmitch
                  Would like to help but I'm stuck on v2014 so can't load the model posted.
                  http://sdmitch.blogspot.com/
                    driven
                    I look at ae_wiretool
                    This Plugin allows to draw physically accurate wires and ropes (catenary curves) between two points with only two clicks.
                    and chrises Component Stringer to replace line with rope...
