    [Plugin] Hide Overlapping Geometry (Updated 20150511)
    29 Posts 10 Posters 10.6k Views 10 Watching
    • JQLJ
      JQL
      @pilou said:
      YEP! Excellent! ๐Ÿ‘
      What make exactly this double click ?
      When you create a group and copy it, it is just like any component, and you get duplicate instances of the same definition (duplicate groups behaving like duplicate components).
      However, if you double-click it, you edit it, and even if you do nothing on it, it is made into a different definition, therefor "unique".
      What happened is that the plugin hide the face of a group behaving as a component and in doing so it hid the face of both components. If you'd flipped it like Dave suggested, you wouldn't see the problem.
      www.casca.pt
      Visit us on facebook!
        I don't believe that many people knows that! ๐Ÿ˜ฎ
        (maybe in the manual but don't have the luck to see it! ๐Ÿ˜„
        It's the Dohdoh Duh of the day! ๐Ÿ‘
        • tt_suT
          tt_su
          This isn't documented well in the API either. Something we need to improve. Developers need to call group.make_unique to ensure groups are unique before modifying them.
          • JClementsJ
            JClements
            I noticed that if the normals of the two overlapping faces are the same (both are "pointing" in the same direction), then the script fails.
            Overlapping Fail.skp
            • C
              CAUL
              This is not really a bug (nor a feature). It's mentioned in the initial post. The reason for this behaviour is that it's a very convenient simplification from a developers point of view. The extension is centered around solids with consistently oriented faces so it's a reasonable simplification.
              • PixeroP
                Pixero
                Thanks for version 2. That seems to work well now. ๐Ÿ‘
                Would you please also add a "Show overlapping edges"?
                When for example designing a multi floor facade it would be great to hide the edges to see how the whole facade looks and then it could be useful to turn the edges back on for viewing the different floors.
                • C
                  CAUL
                  Maybe the possibility to move the geometry to a specific layer is enough? Then you can turn the visibility of the layer on and off.
                  • PixeroP
                    Pixero
                    Yes that would do. ๐Ÿ˜„
                    • JQLJ
                      JQL
                      If you're developing that, could we define the layer's name by tinkering with rb?
                      www.casca.pt
                      • ntxdaveN
                        ntxdave
                        Feeling really dumb. I created a box and then duplicated it and drug the corner of one box to the corners of the other box. I tried double clicking one of the boxes and then used the selection box to select both boxes. When I clicked on the Hide Overlapping Geometry, the overlapping geometry was not hidden.
                        I tried Dave's approach of flipping one of the boxes (that was the only change), clicked the Hide Overlapping Geometry and it worked as it should.
                        Not sure what I did wrong with the first approach.
                        Press F1...thank me later
                        • C
                          CAUL
                          The current version lets you select an existing layer.
                          I'm not sure what you're doing wrong (if anything). Do you have a sample model?
                          • ntxdaveN
                            ntxdave
                            I have attached a VERY simple model that just has two boxes. Flipping one of them works fine. Where I am messing us is with the double click method. When I double click on one, how do I then select the other one so that I can then apply your plugin to the 2 of them. This is making me feel really dumb........
                            Two Boxes.skp
                            • C
                              CAUL
                              You should not enter (double click) any of the components, just select the two components and run the script.
                              • ntxdaveN
                                ntxdave
                                The problem I am having is exactly as Pilou described in this post:
                                @pilou said:
                                Ok! But seems there is a little glitch! ๐Ÿ˜‰
                                A simple copy box (Group)
                                [attachment=0:1y0rgddy]<!-- ia0 -->overlap1.gif<!-- ia0 -->[/attachment:1y0rgddy]
                                In another post, @JQL summarized the situation very well:
                                However, I am doing something that should be very basic, very wrong. When I double-click one of the boxes it seems to not be becoming unique so I am not sure what I am doing wrong.
                                Good news is that I do get it to work fine if I slect one of the boxes and then right-click and select make unique, it does work for me. So I guess my real question (based on these posts is why does the box not become unique when I double-click it or am I not understanding the instructions correctly?
                                  The answer is in your question. ๐Ÿ˜‰
                                  Your box is a component, not a group. If it were a group, you wouldn't see the Make Unique option in the Context menu. And just opening a component for editing won't make it unique. (That would be counterproductive.)
                                  • ntxdaveN
                                    ntxdave
                                    See, I told everyone it was a dumb question. I deleted the 2nd box, exploded the first one, and then made it a group. Used the move tool to make the 2nd copy, double-clicked it and you guessed it, it worked.
                                    Thanks Dave for pulling my head out of my posterior. ๐Ÿ‘
                                      Not a dumb question. Sometimes it's the little things that make all the difference, though.
                                      • 2 / 2
