    [Plugin] EP_Fasteners. Creates 3d printable threaded UPDATED
    39 Posts 19 Posters 21.4k Views 19 Watching
    • pagejaws2P Offline
      pagejaws2
      @micione said:
      Ruby Console:
      SU 2015
      Windows 7
      setMeasurementType('SAE');
      setStatus('Creating a METRIC TAPPEDHOLE');
      continue TAPPEDHOLE in METRIC
      Error: #<ArgumentError: Cannot convert "0.0" to Length>
      C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPTappedHole.rb:28:in `to_l'
      Weird! cannot convert "0.0" to length?
      "0.0".to_l should always work shouldn't it? (Um.... apparently not!)
      What were your model Measurement units?
      Oops... U.S. decimal places. Sorry. I will fix it and repost!
      Jay
        pagejaws2
        @dave r said:
        Thanks for fixing the 1/2" bolt. It looks like the nuts could use some attention, too. Top faces are reversed at least on the 1/2 and 1/4 in. nuts.
        [attachment=0:8cyjdv1l]<!-- ia0 -->nuts.png<!-- ia0 -->[/attachment:8cyjdv1l]
        What about making the threads smoother? Any chance for an option to adjust that?
        Hi! Thanks! I will check all of the faces again... I need to fix a preconception I built in about decimal places (oops) and at the very least I will put a variable in the constants file that will let you add more segments to the arcs. Long term I need to add a settings page for that and smoothing...
        Should be an updated post in a couple of days. if you could try it again after that, I would greatly appreciate your feedback.
        Thanks, Jay
          Jay, I will be happy to try again when you post the next update. It seems like it could be a useful plugin even if you don't want to 3D print the results.
            d12dozr
            Looks really nice! I could have used this on a project about 2 years ago πŸ˜„
            How do the threads turn out on your Formlabs? Are supports required, and if so are the threads usable without post-processing?
            http://goo.gl/f7ooYh
              pagejaws2
              Hi! They print quite nicely in the black resin. didn't need any interior or exterior supports on my vertical tests. The black resin is being a bit touchy in general sometimes it just doesn't setup regardless of supports. Don't know if it was just the one batch or a laser power issue. The blue castable resin works great everytime! Though its a little rubbery to use the threads directly. Haven't tried casting the threads yet, but the finish looks really good.
                Any chance you'll make it use more segments to create smoother curves? They still seem pretty rough to me.
                • H Offline
                  HENRYREYES
                  Hi!
                  FOr some reason, at the main Screen all icons appear double one of them is the normal icon and the other is the selected icon(blueish color). Uninstalled from the root of the SU2015 folder and reinstalled again but nothing happens.
                  Pretty good pluggin and so far the unique one that does this but still have some glitches.
                  Too bad I cant reply with a solution.
                    driven
                    Henry,
                    can you add a screenshot?
                      pagejaws2
                      Hi, I added a Quality dropdown on the main menu where you can select higher segment counts...
                      Jay
                        pagejaws2
                        @henryreyes said:
                        Hi!
                        Hi! That would happen if the Javascript or JQuery doesn't run... Can you please tell us what your OS and Sketchup versions are?
                        Thanks! Jay
                        • tibetT Offline
                          tibet
                          hi,
                          thanks for your excellent plugin!
                          iΒ΄m glad, because it starts working... πŸ‘
                          iΒ΄ve found that it cuts hole through unclosed model, is there any
                          way how to make it cuts through component or a group please?
                          wondering, if is there any chance in the future version to make our unique eg.nuts or bolts please? ( something like profile builder ruby )
                          keep working!
                          http://s23.postimg.org/jd9fnpavf/sketch_logo.png
                          SU 2015 Pro on Win10 x64
                            mroek
                            Just wanted to say thanks for creating this extension, and to ask why the version in the Extension Warehouse (which is 1.0.0) is older than the one posted here?
                            I first installed via the warehouse, but it didn't work properly, so it was a relief to find that the one posted here worked as expected.
                            Thanks again.
                              junaramaro
                              Hello sir i found your plugin amazing even though i cant use it..coz the icon in the html are not aligned properly..maybe coz im using ie8 in xp..i cant buy anew laptop...coz in the phil. only the rich can afford it..^^, hope i can use it when i have a new one... best plug in ... i,ve seen the preview^^,
                                MrAP
                                Great work!!!
                                Is it possible to add left turn treads
                                //Affe
                                  SchonVergeben
                                  With this update it works sweet!
                                  I salute you Sir! πŸ€“
                                  • F Offline
                                    francoisinnuedo
                                    Hi everybody,
                                    @oxer said:
                                    And the EyePhisics Fastener Menu window isn't refreshed automatically when you reopen it, see the image below.
                                    [attachment=0:gf7e5eye]<!-- ia0 -->Fastener Menu window.jpg<!-- ia0 -->[/attachment:gf7e5eye]
                                    @driven said:
                                    This will reset the dialog on a mac
                                          @@dialog.show()
                                    >       @@dialog.execute_script('location.reload(true);')
                                    The issue I have is with threaded thru holes, both breeds...
                                    the first threaded thru hole takes minutes [many], a second of the same is instant...
                                    a change in the params will revert to slow-mo...
                                    BTW: what are the observers for, if possible it is best not to have them on mac SU...
                                    I have the same problem than Oxer, (me menu box doesn't refresh...)
                                    I don't understand how to reset with this code in the ruby console...
                                    Can someone clearly explain to me ( /us ) how to reset the dialog box????
                                    thanks!
                                    Francois
                                    • OxerO Offline
                                      Oxer
                                      I do it manually, right-click over the window and refresh.
                                      • F Offline
                                        francoisinnuedo
                                        It had to be said ...
                                        Thank you very much, I could look for so long it was obvious 😳
                                        And many thanks for this great plugin!
                                        • OxerO Offline
                                          Oxer
                                          Nobody help us with the code so I used a rapid solution. πŸ˜‰
                                            BallBearing
                                            The menu does not work at all. Win8 SU 2016. v1.04.
                                            SketchUp, 3D printing stuff and more:
                                            http://www.youtube.com/user/CinemaTablet
                                            • 2 / 2
