    [Plugin] EP_Fasteners. Creates 3d printable threaded UPDATED
    39 Posts 19 Posters 20.4k Views 19 Watching
      driven
      Henry,
      can you add a screenshot?
      • pagejaws2P Offline
        pagejaws2
        @dave r said:
        Any chance you'll make it use more segments to create smoother curves? They still seem pretty rough to me.
        Hi, I added a Quality dropdown on the main menu where you can select higher segment counts...
        Jay
          pagejaws2
          @henryreyes said:
          Hi!
          FOr some reason, at the main Screen all icons appear double one of them is the normal icon and the other is the selected icon(blueish color). Uninstalled from the root of the SU2015 folder and reinstalled again but nothing happens.
          Hi! That would happen if the Javascript or JQuery doesn't run... Can you please tell us what your OS and Sketchup versions are?
          Thanks! Jay
          • tibetT Offline
            tibet
            hi,
            thanks for your excellent plugin!
            i´m glad, because it starts working... 👍
            i´ve found that it cuts hole through unclosed model, is there any
            way how to make it cuts through component or a group please?
            wondering, if is there any chance in the future version to make our unique eg.nuts or bolts please? ( something like profile builder ruby )
            keep working!
            http://s23.postimg.org/jd9fnpavf/sketch_logo.png
            SU 2015 Pro on Win10 x64
              mroek
              Just wanted to say thanks for creating this extension, and to ask why the version in the Extension Warehouse (which is 1.0.0) is older than the one posted here?
              I first installed via the warehouse, but it didn't work properly, so it was a relief to find that the one posted here worked as expected.
              Thanks again.
                junaramaro
                Hello sir i found your plugin amazing even though i cant use it..coz the icon in the html are not aligned properly..maybe coz im using ie8 in xp..i cant buy anew laptop...coz in the phil. only the rich can afford it..^^, hope i can use it when i have a new one... best plug in ... i,ve seen the preview^^,
                  MrAP
                  Great work!!!
                  Is it possible to add left turn treads
                  //Affe
                    SchonVergeben
                    With this update it works sweet!
                    I salute you Sir! 🤓
                    • F Offline
                      francoisinnuedo
                      Hi everybody,
                      @oxer said:
                      And the EyePhisics Fastener Menu window isn't refreshed automatically when you reopen it, see the image below.
                      [attachment=0:gf7e5eye]<!-- ia0 -->Fastener Menu window.jpg<!-- ia0 -->[/attachment:gf7e5eye]
                      @driven said:
                      This will reset the dialog on a mac
                            @@dialog.show()
                      >       @@dialog.execute_script('location.reload(true);')
                      The issue I have is with threaded thru holes, both breeds...
                      the first threaded thru hole takes minutes [many], a second of the same is instant...
                      a change in the params will revert to slow-mo...
                      BTW: what are the observers for, if possible it is best not to have them on mac SU...
                      I have the same problem than Oxer, (me menu box doesn't refresh...)
                      I don't understand how to reset with this code in the ruby console...
                      Can someone clearly explain to me ( /us ) how to reset the dialog box????
                      thanks!
                      Francois
                      • OxerO Offline
                        Oxer
                        I do it manually, right-click over the window and refresh.
                        • F Offline
                          francoisinnuedo
                          It had to be said ...
                          Thank you very much, I could look for so long it was obvious 😳
                          And many thanks for this great plugin!
                          • OxerO Offline
                            Oxer
                            Nobody help us with the code so I used a rapid solution. 😉
                              BallBearing
                              The menu does not work at all. Win8 SU 2016. v1.04.
                              SketchUp, 3D printing stuff and more:
                              http://www.youtube.com/user/CinemaTablet
                                makacharya
                                Hello,
                                I have used your tool EP Softwares and works well with 2016 sketchup.
                                I have an application where I have to use metric LEFT hand threads both internal and external.
                                How can I use EP Tool for metric LEFT hand threads making.
                                Please help me to understand.
                                Thanks & Regards,
                                Makarand Acharya
                                makacharya48@gmail.com
                                  T_om
                                  I am using Sketchup 2016, which others here seem to have no problem with. However, the plugin will not drill threaded holes though a solid. If I make a box 2"x2"x2", I cannot drop a threaded hole through the thing. I place the "circle" on a face, but then nothing happens.
                                  HOWEVER, if I pick a length, like for a blind hole, and set the depth to 2", it does fine. Goes right through.
                                  Any idea why the threaded through hole is not working?
                                  • 2 / 2
