    Screw and thread
    8 Posts 4 Posters 722 Views 4 Watching
      se777ens
      Hi can anyone help? I am designing a plastic tube and I need to design it so that 2 of the tubes can screw together. Ie one with a screw and one with a thread. Similar to a coke bottle top and cap but much larger.
      Can anyone help? I am willing to pay if need be.
      Will be greatly appreciated.
      many thanks
      Mark - aka (se777ens)
      • cottyC Offline
        cotty
        There are a lot of tutorials out there about this topic, have you tried to follow one of them?
        One great example by Dave: http://www.finewoodworking.com/item/112614/screw-threads-in-sketchup
        my SketchUp gallery
          se777ens
          Thanks Cotty - I will give that a try.
            se777ens
            Hi Cotty,
            I tired the tutorial you sent me but am unable to use it as the one plugin is no longer available (Draw Helix)
            Can anyone help?
              It's still available here. I'm not sure how you got the idea it isn't. I just downloaded it againfrom that link and it worked fine. That's the link I provided in the blog post, too. Make sure you download DrawHelix14.
              An alternative would be the Curve Maker plugin available in the SCF Plugin Store or EW.
              • pagejaws2P Offline
                pagejaws2
                many thanks
                Hi, Please try EP_Fasteners.rbz
                I updated it today, and hopefully it will help you! It can add threaded holes and bolts.
                You should be able to edit the results to make the threads you need.
                There is a video in another plugin thread showing how to use it.
                Let me know how it goes!
                Jay
                  Have you updated it so it makes smoother curves?
                    pagejaws2
                    Yes. On the main menu at the bottom is a dropdown for Quality.
                    Does look much better at higher quality πŸ˜„
