Bricks
I have a drawn a building and want to put bricks around the outside - I have tried using the plugin 'oob' but this doesn't work around corners so is a little annoying. I don't want it to be rendered, I want physical 3d bricks. Does anyone know a different plugin that could help me with this? Thank you!
This can be done without a plugin. Take some time to learn about creating linear arrays with Move/Copy. You can lay out the first two courses of brick and then copy those up the building.
My SDM_FloorGenerator plugin creates a 3D brick pattern and works on walls also. It is available in the Plugin Store or on my blog page.
Thank you both!
S -
You want bricks? Here ya go
