    [Plugin] EP_Fasteners. Creates 3d printable threaded UPDATED
    39 Posts 19 Posters 20.8k Views 19 Watching
      driven
      hi Jay,
      as Oxer points out none of your html will show on a mac...
      The primary reason is you are using 'non' ruby, window only paths...
      If I change for e.g. to
       @@HTMLFile = File.join(__dir__,"HTML","EP_Fasteners.html")
      they do work on a mac...
      Once running 'thru holes' work but the plugin fails at the build stage for any with thread detail...
      It 'beachballs' i.e. 'freezes' at this step...
      goes no further, SU must be 'force quit'
      • pagejaws2P Offline
        pagejaws2
        @bob james said:
        Does the fact that some of the results have reversed faces have any impact on printing?
        That was why I zoomed in on it in the video. That was not normal. The build process is careful to order the faces correctly. I believe I may have an error on the 1/2" coarse specification.
          pagejaws2
          @driven said:
          hi Jay,
          [attachment=0:2zjahov9]<!-- ia0 -->hole_crash.png<!-- ia0 -->[/attachment:2zjahov9]
          Hi John, Thanks! I haven't tested anything on Mac. I will modify the HTML entries and repost. Perhaps with all of the html correct, it will run for you. If not I would be very pleased if you could help me isolate the problems!
          Thanks,
          Jay
            pagejaws2
            Here is an Updated Plugin **(v1.0.1)**with the phillips head faces corrected as noted by Bob and Dave, and the HTML paths updated as described by Driven, so they should work on Macs too...
            Thanks! Jay
            v1.0.1
              Thanks for fixing the 1/2" bolt. It looks like the nuts could use some attention, too. Top faces are reversed at least on the 1/2 and 1/4 in. nuts.
              What about making the threads smoother? Any chance for an option to adjust that?
              • OxerO Offline
                Oxer
                The HTMLs work now on Mac but when you try to create some element it appears a error message in Ruby Console, here the error messages:
                setStatus('Creating a METRIC DRILLEDHOLE');
                continue DRILLEDHOLE in METRIC
                4.0
                create_drilled_hole d=0,40cm  l=0,00cm
                Error; #<ArgumentError; Cannot convert "0.0" to Length>
                /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFasteners.rb;56;in `to_l'
                /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFasteners.rb;56;in `onPlaceComponent'
                setStatus('Creating a METRIC BOLT');
                continue BOLT in METRIC
                create bolt  Hex d=-1.0 p=-1.0 l=3,00cm No
                setStatus('Creating a METRIC NUT');
                continue NUT in METRIC
                Error; #<ArgumentError; Cannot convert "24.000mm" to Length>
                /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPNut.rb;124;in `to_l'
                /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPNut.rb;124;in `performOK'
                /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPNut.rb;82;in `block in InitializeDialog'
                SketchUp;1;in `call'
                setStatus('Creating a METRIC WASHER');
                continue WASHER in METRIC
                create_washer id=-2,54cm od=-2,54cm t=-2,54cm
                setMeasurementType('METRIC');
                setStatus('Creating a METRIC TAPPEDHOLE');
                continue TAPPEDHOLE in METRIC
                /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPTappedHole.rb;28;in `to_l'
                /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPTappedHole.rb;28;in `create'
                /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFastenersMenu.rb;39;in `continue'
                /Users/Oxer/Library/Application Support/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFastenersMenu.rb;56;in `block in InitializeDialog'
                And the EyePhisics Fastener Menu window isn't refreshed automatically when you reopen it, see the image below.
                • micioneM Offline
                  micione
                  Ruby Console:
                  SU 2015
                  Windows 7
                  setMeasurementType('SAE');
                  Error: #<ArgumentError: Cannot convert "0.0" to Length>
                  C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPTappedHole.rb:28:in to_l' C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPTappedHole.rb:28:in create'
                  C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFastenersMenu.rb:39:in continue' C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFastenersMenu.rb:56:in block in InitializeDialog'
                  C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFastenersMenu.rb:90:in call' C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFastenersMenu.rb:90:in execute_script'
                  C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFastenersMenu.rb:90:in performOK' C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFastenersMenu.rb:54:in block in InitializeDialog'
                  SketchUp:1:in call' setMeasurementType('METRIC'); setStatus('Creating a METRIC BOLT'); continue BOLT in METRIC create bolt Socket d=-1.0 p=-1.0 l=3,0cm No Error: #<ArgumentError: Cannot convert "0.0" to Length> C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFasteners.rb:56:in to_l'
                  C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFasteners.rb:56:in onPlaceComponent' attribute value not defined: img_width returning from add_context_menu_handler - nothing selected returning from add_context_menu_handler - nothing selected returning from add_context_menu_handler - nothing selected setMeasurementType('METRIC'); setStatus('Creating a METRIC WASHER'); continue WASHER in METRIC create_washer id=~ -2,5cm od=~ -2,5cm t=~ -2,5cm Error: #<ArgumentError: Cannot convert "0.0" to Length> C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFasteners.rb:56:in to_l'
                  C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPFasteners.rb:56:in onPlaceComponent' setMeasurementType('METRIC'); setStatus('Creating a METRIC NUT'); continue NUT in METRIC Error: #<ArgumentError: Cannot convert "34.000mm" to Length> C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPNut.rb:124:in to_l'
                  C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPNut.rb:124:in performOK' C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPNut.rb:82:in block in InitializeDialog'
                  SketchUp:1:in `call'
                    driven
                    This will reset the dialog on a mac
                          @@dialog.show()
                          @@dialog.execute_script('location.reload(true);')
                    The issue I have is with threaded thru holes, both breeds...
                    the first threaded thru hole takes minutes [many], a second of the same is instant...
                    a change in the params will revert to slow-mo...
                    BTW: what are the observers for, if possible it is best not to have them on mac SU...
                      driven
                      Jay,
                      also, both the above error messages contain commas as decimal separators, so I assume your code isn't handling them...
                      there are some posts in the developer forum on the topic...
                        pagejaws2
                              @@dialog.show()
                        Hi, the Observers are what let it create the 2nd component and glue it to the 2nd face. Otherwise
                        I couldn't let you use component place to set the first hole location.
                        Part of the speed issue is creating all of the geometry in one Geom::PolygonMesh. When I tried just calculating one threads worth and duplicating it offset by a thread, the results were not as good... but it was much faster! I expect that this can be faster, and if there is enough interest, i will try to make some time to work on it again.
                          pagejaws2
                          [code]setStatus('Creating a METRIC DRILLEDHOLE');
                          4.0
                          Ah, Thanks! Now I feel provincial.
                          I am stuck in the U.S. mindset for decimal places. πŸ‘Š
                          I will go back through the code and try and find all of the decimal place biases I've put in.
                          Please accept my apologies! I will post another patch in a day or two, if you would be kind enough to test it again after that I would appreciate more feedback.
                          Thanks again for spotting these errors for me!
                          Jay
                            pagejaws2
                            @micione said:
                            Ruby Console:
                            SU 2015
                            Windows 7
                            C:/Users/Utente/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/EP_Fasteners/EPTappedHole.rb:28:in `to_l'
                            Weird! cannot convert "0.0" to length?
                            "0.0".to_l should always work shouldn't it? (Um.... apparently not!)
                            What were your model Measurement units?
                            Oops... U.S. decimal places. Sorry. I will fix it and repost!
                            Jay
                              pagejaws2
                              [attachment=0:8cyjdv1l]<!-- ia0 -->nuts.png<!-- ia0 -->[/attachment:8cyjdv1l]
                              Hi! Thanks! I will check all of the faces again... I need to fix a preconception I built in about decimal places (oops) and at the very least I will put a variable in the constants file that will let you add more segments to the arcs. Long term I need to add a settings page for that and smoothing...
                              Should be an updated post in a couple of days. if you could try it again after that, I would greatly appreciate your feedback.
                              Thanks, Jay
                                Jay, I will be happy to try again when you post the next update. It seems like it could be a useful plugin even if you don't want to 3D print the results.
                                  d12dozr
                                  Looks really nice! I could have used this on a project about 2 years ago πŸ˜„
                                  How do the threads turn out on your Formlabs? Are supports required, and if so are the threads usable without post-processing?
                                  http://goo.gl/f7ooYh
                                    pagejaws2
                                    Hi! They print quite nicely in the black resin. didn't need any interior or exterior supports on my vertical tests. The black resin is being a bit touchy in general sometimes it just doesn't setup regardless of supports. Don't know if it was just the one batch or a laser power issue. The blue castable resin works great everytime! Though its a little rubbery to use the threads directly. Haven't tried casting the threads yet, but the finish looks really good.
                                      Any chance you'll make it use more segments to create smoother curves? They still seem pretty rough to me.
                                      • H Offline
                                        HENRYREYES
                                        Hi!
                                        FOr some reason, at the main Screen all icons appear double one of them is the normal icon and the other is the selected icon(blueish color). Uninstalled from the root of the SU2015 folder and reinstalled again but nothing happens.
                                        Pretty good pluggin and so far the unique one that does this but still have some glitches.
                                        Too bad I cant reply with a solution.
                                          driven
                                          Henry,
                                          can you add a screenshot?
                                            pagejaws2
                                            Hi, I added a Quality dropdown on the main menu where you can select higher segment counts...
                                            Jay
