    How to use emitters in Maxwell Standalone for Sketchup
    extensions
    45 Posts 15 Posters 32.4k Views 15 Watching
    • jason_marantoJ Offline
      jason_maranto
      @carloh said:
      are there MXM files with IES in the maxwell material gallery? this far i haven't figuered out how to create a spot light with the maxwell standalone sketchup plugin 😒
      The newest version of the plugin supports creating IES materials directly within SketchUp (as an embedded character type material) -- I would re-download the plugin (from the Maxwell website) to get the new features. Also, I would check the Maxwell forum regularly for the latest pre-release version (which right now is 2.6.11) because often they will be newer than what is available from the Maxwell website: http://www.maxwellrender.com/forum/viewforum.php?f=107
      Best,
      Jason.
      • CarlohC Offline
        Carloh
        thank you very much jason! wooohooo finally the possibility to put IES in my scenes!
        and i was this close to buying the full render suite just for IES lights πŸ˜‰
          duVriez
          I'v been reading all the previous, but I'm still having problems with my lights. I'm using Sketchup pro 8 an the Maxwell plugin only. I added a test-render (attachment: test 7), in which I used no artificial light. Obviously, it needs some artificial light, but I've been trying emitters (on a rectangle) and an IES (on as spere) but it keeps on turning black. I've tried reversing the material, but nothing worked so far.
          Stupid thing though: in a test-setup I made (attachment: test 2), the lighst do work (although I'm still struggling with the settings)
          Please help!!!
          Not fully rendered, because it was just a test.
          Same here
          • N Offline
            numerobis
            intensity too low? Maybe try with multilight.
            Did you try bouth face orientations? Some time ago a had the problem that emitter faces got reversed on export.
              Sketchfield
              Hi, I am a newbie to Maxwell - I have the free Maxwell render plug-in for SU.
              I have read all the above posts and I appear to have the same problem as many.
              I am working in an outdoor scene.
              I read the whole of the manual that is relevant to the above and followed the guidelines, but I'm not getting any light emission from geometrical objects created. I applied light emitters to each face of planar emitters and then made them a group but still no light. I tried various means: such as IES lights, customised emitters, daylight and 1000W lighting.
              I have HDRI loaded as background and also in associated channels, reflectance, etc. Can this affect the light emitters? But I did disable the HDR at one point.
              Many thanks in anticipation for help with this.
              • novenaN Offline
                novena
                Sketchfield, check units and scale of the objects in your 3d model, make sure that you are working with real scale and the size of objects correspond with units used...
                best
                V
                http://hdzarkitektur.wordpress.com/
                  Sketchfield
                  Thanks for the prompt response novena - the objects scales certainly need to be reviewed and revised. I will give it a go ... here's hoping!
                    Sketchfield
                    Interesting one - under materials texture I clicked 'Link to Application' instead of 'Texture' and hey presto! we have light. Link to application seems to give a more exact fit with the selected material, emitter, etc, but correct me if I'm wrong.
                    I also had to review a range of things like the exposure values, scale of objects and so on. Trial and error the order of the day! Thanks again.
                    • novenaN Offline
                      novena
                      good to hear that it's solved!!! πŸ˜„
                      interesting the issue with 'link to application' and 'texture' will give it a try myself
                      best
                      V
                        skippy_28
                        Just wondering is anyone knows how to hide Emitters from the camera so you get the light but not the geometry that it is coming from.
                        • neetsN Offline
                          neets
                          Hey, right click the component, you'll see a sub menu, go to Maxwell, another sub menu will appear, select 'from camera', there's a few other options in there too for invisibility, for example, if you want to illuminate an area and there are windows/mirrors and you don't want the actual source of light to be visible in the reflections, then you'd need to enable 'from reflections/refractions' too.
                          Anita
                          Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
                          • 3 / 3
