    [Plugin] Estimates (extended)
    50 Posts 23 Posters 54.3k Views 23 Watching
    • jemagnussenJ Offline
      jemagnussen
      @tig said:
      You has a very subtle problem indeed !
      A Ruby script is typically in "UTF-8 without BOM" text-encoding format.
      When you edited it with Notepad and saved it, its format changed to "UFT-8", which corrupts the text so it then fails to load properly...
      I will PM you a suitably encoded copy...
      Can I suggest you get "Notepad++" [free].
      It has special Ruby Syntax highlighting etc and you can set it to always open/save files with the right encoding...
      Thank you TIG,
      It works like a charm, and I will rush to get Notepad++ to avoid this in the future.
      Thanks again to both and have a fine day,
      Jesper
      HP ZBook 15, Windows 10 64 bit
      Intel Core i7-6820HQ @ 2.70GHz
      32 GB Ram
      NVIDIA Quadro M2000M
        chiklopes
        @dave r said:
        Looks to me as if you haven't ticked the box for "Ruby Script Examples" in Window>Preferences>Extensions.
        it is ticked but the error message is the same!
        "Error Loading File attributes.rb
        undefined method `GetString' for nil:NilClass"
          This error message relates to the 'language handler' system tool...
          There would have been more text, you curtailed it just before the line number generating the error... πŸ˜’
          For example .GetString("Square meters"). That is looking up the 'translation' in the '.string' file.
          Have you edited the file ?
          Have you got any text reading something like .GetString() or .GetString(**nil**) or .GetString(**any_text_without_paired_quotes**)
          Is the .rb file still in "UTF-8 without BOM" encoding etc ??
          Check that with Notepad++...
          Just to double-check...
          Do you have a file named 'langhandler.rb' in the 'Tools' folder?
          If not you should !
          Try reinstalling/repairing Sketchup to get it back.
          If you have a similar file in the 'Plugins' folder then remove.
          Have you installed one of the older rogue compilation tool-bar scripts?
          These can come zipped with some older SketchUp 'system' files that then get installed into 'Plugins', whereby the correct [newer] ones Sketchup provides in 'Tools' get screwed !
          The files they can mess with include 'sketchup.rb', 'extensions.rb' and 'langhandler.rb'.
          If you have any of these in your Plugins folder remove them.
          If you do not have them in your Tools folder reinstall/repair Sketchup...
            ptasznick
            I've read all posts on estimate plugin and can't find any solution for my problem. Plugin installed as in readme file. Cost settig for materials, and cost estimation by material works fine.
            However plugin seems to only see default Susan component despite i have 2 components in my scene.
            I tried this plugin on another - more complicated model - and it seems that only components which have "by" attribute filled in are listed in Your plugin. I have a scene with hundreds of components, yet only 3 of them are listed - these are downloaded form 3d warehouse and have ie. "by Google" attribute set in them.
            I guess it is a glitch, and it would be nice to get it fixed or some kind of workaround.
            I use win7 pro sketchup 8.
            Thanks for advice!
            UPDATE: My problem is that only components having an author are listed in assign cost to component dialog window. If i save a component to a different file, then open the file, claim credit to it, the go back to original file and replace all old instances to a new "credited" one, it appears in assign cost to component dialog box. It this the way it's ment to be?
            • brodieB Offline
              brodie
              I seem to be having a similar issue as others have reported.
              When I installed the plugin via the link in this thread I got the
              error. So I deleted the files and installed it via the sketchucation plugin store (I'm on SU v7). It worked although the only component I could select was Susan. Based on one of the other posters I was going to try crediting a component to myself to see if that would be a workaround. After closing and reopening sketchup I now get the same error as above though and the plugin no longer shows up in my list.
              -Brodie
              Edit: I'm actually on SU 8
                minerva1984
                hi I am using sketchup 2014, I placed the attributes.rb file in the plugins folder which in my case was not in the main sketchup folder but C:\Users\SarahPaulus\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins but it gave me an error message when I restarted sketchup. Also what do I do with the examples_en-US.string file. Please explain step by step I am not good with computers and only starting out with sketchup.
                  Welcome to SCF, Sarah. This is another plugin by Didier Bur that needs to be updated to work with SU2014. So far he hasn't released an update for this one so you might as well remove it from your Plugins folder so it doesn't give you errors when you start SketchUp. For what it's worth, the "strings" file would also go into Plugins, too. And you found the correct location for the folder in SU2014.
                  • doush-007D Offline
                    doush-007
                    Hello,could make this plugin to estimate areas for each layers?
                      Arch08
                      hi everyone, I test the plugin and it work so well. but I have a problem here, the plugin just calculate material which painted in 'front face' and not calculate painted 'back face'
                      is there a way to calculate 'back material' as well? it will be a more powerful and efficient plugin if it can calculate 'back face'
                      thank you for your help πŸ˜‰
                        Is that because you aren't correcting face orientation? You shouldn't leave back faces exposed.
                        • N Offline
                          nicro
                          Will this work in SK2017?
                          • V Offline
                            Vivek Saxena
                            Sir,
                            There can be currency of RUPEES(INDIAN CURRENCY)?
                            Because I am from India so there should be Indian currency
                            please reply how to change into RUPEES
                              kostiaarh
                              Can someone update this plugin for Sketchup 2020? Please. Maybe @Didier Bur @TIG
                              • 3 / 3
