    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 82.7k Views 40 Watching
    • W Offline
      Whaat
      @david_h said:
      So. . .how does one upgrade from the trial to the purchase. The pullout doesn't seem to have a license or "purchase" tab. Also, I can't find "Profile Builder 2" in the Ext. WH anymore. can somebody help me on this. Also, there seemed to be some chatter on this thread about purchasing issues. Have those been resolved?
      Thx,
      David_H
      Hi David, first un-install the Trial, then follow these instructions:
      http://help.sketchup.com/en/article/3000059
      • W Offline
        Whaat
        @raineysky said:
        I'm getting this error while trying to download the trial.
        This issue should now be fixed thanks the hard-working EW team!
        If you have had this error, please try installing again - it should now work.
          raineysky
          Dale,
          I got the same error but this time I went out for a while and when I came back it was installed....Also had trouble finding the plugin, even with search. I sent a message in to let them know. Just had a few minutes to play with PB2 but it looks awesome!
          Thank You,
          Paul
            AcesHigh
            Has anyone tried to use Profile Builder 2 to build curtain walls?
            I guess we could set components for mullions and such... not sure how to make the glass (specially if you want single planes as glass to render using "architectural glass" material (instead of using heavier materials for glass where the render will calculate light dispersion and such)
            I guess vertical mullions as components and horizontal mullions AND glass as profiles?
            • JClementsJ Offline
              JClements
              A few quirks.
              I kind of expected issues 2 and 3 to happen, but issue 1 is a surprise (I think it is fixable).
              trim to solid issue.skp
              • W Offline
                Whaat
                @jclements said:
                A few quirks.
                [attachment=1:eaqqxjit]<!-- ia1 -->trim to solid issue.jpg<!-- ia1 -->[/attachment:eaqqxjit]
                Thanks John - I'll take a look
                  rv1974
                  Whaat, If I'm not mistaken there's important feature missing- Follow'n'Keep mode:
                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=16465
                  Would it be possible to add this humble check box (in PB andAssembler Dialog) in near future?
                  • W Offline
                    Whaat
                    PB2 is designed to make this process automatic. For non-planar paths (like a helix) PB2 will use a method similar to Follow'n'Keep. Otherwise, it works similar to the SketchUp follow-me tool.
                    Are you finding this to be a significant limitation?
                      rv1974
                      For instance, tilted curb stones on sloped roads\ramps look weird. There are lot of similar cases- 7 pages of vivid 'thank you' discussion surely prove it.
                      • utilerU Offline
                        utiler
                        Hi Dale, not sure what's going on here: for some reason a profile from either a face or polyline won't execute....?
                        PB2-issue.wmv
                        Just Curious...
                          rv1974
                          try to remove smartdrop.rb
                          • W Offline
                            Whaat
                            Yes, it looks like you have a conflicting plugin installed (possibly smartdrop). Open the Ruby Console Window and checked for errors. It should give you a clue about which plugin is causing the problem.
                              raineysky
                              Dale,
                              I can't get the pipe segments to align properly. What's the trick?
                              Thanks,
                              Paul
                              • W Offline
                                Whaat
                                @raineysky said:
                                Dale,
                                Thanks,
                                Paul
                                Add a small extension to your arcs in the direction of the joining pieces.
                                  raineysky
                                  Dale,
                                  That's the trick
                                  Thank You,
                                  Paul
                                  • W Offline
                                    Whaat
                                    @jclements said:
                                    A few quirks.
                                    [attachment=1:1glim78o]<!-- ia1 -->trim to solid issue.jpg<!-- ia1 -->[/attachment:1glim78o]
                                    Thanks for the feedback John.
                                    1. Is this an issue? The smoothing of edges is based on the angle between adjacent faces. If it is less than 30 degrees the edge gets smoothed
                                    2. This is a bug that I hope to fix soon.
                                    3. I couldn't see any issue here. The path could be edited as expected. Could you clarify the problem you noticed.
                                    • Mistro11M Offline
                                      Mistro11
                                      I have the 1st version and I love it.Really looking forward to this one. But why no PayPal? Just curious.
                                      i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                      Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                      • utilerU Offline
                                        utiler
                                        Thanks mate, worked! 👍
                                        Just Curious...
                                        • pep75P Offline
                                          pep75
                                          Just bought it...what an amazing plugin! Great work Dale!
                                            AcesHigh
                                            Anyone knows where the Plugin stores it´s library of profiles?
                                            I find no way to select different profiles, and when clicking "browse" (the mag glass button) it takes me to "My Documents" folder, where there are several skp files but no library as far as I know.
                                            • 11
                                            • 3 / 11
