    SketchyPhysics 3.5.6 (26 January 2015)
    208 Posts 49 Posters 298.0k Views 49 Watching
    • mknorrM Offline
      mknorr
      I want to thank Chris for this amazing plugin. πŸ‘
      I do have a couple of wishes for a future release. πŸ˜„
      1. Support for 64 bit Sketchup
      2. Support for GPU number crunching monsters like CUDA.
      Thank you again and where do I donate to your cause?
      Cheers,
      Manfred
        kpalasrinne
        I'm using Sketchup 2015 and don't seem to be able to install this program. Should it work? If not, what similar physics programs are out there?
        • mknorrM Offline
          mknorr
          My understanding is that 64 bit SketchUp isn't supported.
            beeker
            Presumably an x64 version is on its way, but can anybody provide a date on when?
            Think I'll have to revert to a previous 32bit version until they do 😞
            • H Offline
              huntfortegmail.com
              Is there a timeline for development of a SketchyPhysics version that is compatible with Sketchup 2015 64 bit? Thanks. Tom
                Mrtapo8
                Hey guys exsit version for skethcup 2015 please ?
                  Mrtapo8
                  Hello can i ask if is possible to make with this plugin also working twine iam trying and trying but it is still fixed like pipeline.
                  Thank you !!!
                    dgimagge
                    Hi everyone, I am new in SketchyPhysics.
                    I don`t know if this is the best forum to ask help for my question.
                    Sorry if not, and please tell me where is the best place.
                    This is my question:
                    I installed SketchyPhysics in Sketchup 8 (Windows 32 bits).
                    I follow the tutorials but at the first test I found an error that has me stopped:
                    I create a box and another copy over that.
                    Mark "static" to the bottom box.
                    Put a hinge in one border (left or right) in the middle edge of both boxes.
                    Joint the hinge with the bottom box.
                    Group the upper box with the hinge.
                    And when I click in "play", the upper box fall down rotating from the hinge and fall through the bottom box.
                    I tried to do a lot of times and always the same result.
                    Is like that when I assign the "parent" to the hinge to rotate, that parent box become NO solid.
                    Help please. Thanks.
                      Anton_S
                      Dgimagge, to prevent bodies connected by joints from passing through each other, select the joint, open SketchyPhysics UI, and enable the "ConnectedCollide" checkbox option. By default, this option is disabled.
                        dgimagge
                        Anton_S, thank you so much. Thats the key.
                        I wonder why in any tutorial teach that !!!!
                        Thanks again.
                        • romi63R Offline
                          romi63
                          Well,
                          February 2016, Major SketchUp update (2016) out up and running but still no word on the 64 bit version of this very useful plug-in.
                          I tried to install it anyway, but obviously not being compatible with a 64 bit version, it gave me a bunch of errors and doesn't load....
                          If there was a turn around about this I should found it by now..
                          Just hoping a 64 bit version release will be out soon.
                          Thank you.
                            GreyMatter
                            Hi there, can someone please help me answer a very simple question. Is SP compatible with SU 2015 Pro on a Macbook running OSX 10.9.5?
                            I've expanded the SP zip and dumped the contents into the Plugin folder associated with SU2015. SketchyPhysics is visible in the extensions tab found under File/Preferences etc but nothing relating to SP comes up in the toolbar. I have also tried the same process with my previous versions of sketchup 2014 and 8.
                            Am I doing something wrong or does SP just not work on Mac?
                            Thanks in advance
                            Matt
                              gepponline77
                              I've just downloaded the new version of Sketchup Make, installed sketchyphisics and all seems to work, but if i try to edit joint setting nothing happen.
                              I right click on a joint, select "joint settings" and i expect a widows appear (i used this in an old version) but no window appear and i don't know which is the problem. Is there a way to have a debug of it?
                              thank you!
                                jumpjack
                                @anton_s said:
                                SketchyPhysics is a real-time physics simulation plugin for SketchUp created by Chris Phillips.
                                See extended versions maintained by PituPhysics: http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=62453
                                SP 3.5, the unofficial release, comes with many bug fixes
                                SketchyPhysics 3.7.1
                                SketchyPhysics 3.7.1 Release date: December 23, 2015. Copyright Β© 2009-2016, Chris Phillips
                                It remains just for 32-bit SketchUp to use.
                                I'm a bit confused...
                                V.3.2 was the last one from Chris Phillips, now stopped?
                                Than a new branch named "3.5.x" was started? By Anton_S ?
                                Then a NEW branch named "3.7.x" was started? By PituPhysics? Or this is the continuation of 3.5?!?
                                What does "It remains just for 32-bit SketchUp to use" mean? That a 64-bit version exists?
                                3.5.x branch.
                                3.7.x branch
                                  sekramer10
                                  Hello,
                                  Just downloaded SU 2016 64 bit. I was looking for a physics simulator, it seems this is the only one so far. But it doesn't install on SU2016 64 bit? Will there be a new version soon? I need it now.
                                  Thanks.
                                  • chriC Offline
                                    chri
                                    @sekramer10 said:
                                    Hello,
                                    Thanks.
                                    hi sekramer10
                                    Perhaps , you can use MSPhysics by Anton
                                    link here :
                                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56852
                                    Chri
                                      Anton_S
                                      I received the C++ source of SketchyPhysics and been looking over it for a while now. I tried compiling it under 64bit but did not succeed. SketchyPhysics source is shipped with the 32bit version of the Newton 1.53 static library however not with the 64bit version. In order to compile SketchyPhysics under 64bit, I would need to have a 64bit version of the Newton 1.53 static library, which would require recompiling the source of Newton 1.53 under 64 bit configuration. The problem is that SketchyPhysics source does't comes with the source of Newton 1.53, as well as, the source of Newton 1.53 is no longer available on the internet. This meanders my ability to compile SketchyPhysics under 64 bit. I could upgrade SktechyPhysics to use newer versions of newton, but they could change the way older SketchyPhysics models work. Not to mention the problems that could come upgrading SDL libraries and all the adjustments that would have to be made in order to compile SketchyPhysics under Mac OS X. However it's worth a try. I'll keep it posted.
                                      • W Offline
                                        willeykj
                                        I have the source to 1.53 as well as the 64bit library. It ships as a static lib, I've got an automator script that runs lipo on the library to strip out the extra stuff and then "ar" to dump the object files and then a g++ link command to put it all together as a dylib so that the ruby c bridge can open it.
                                        Let me know how to get it to you and we can keep moving.
                                        Kevin Willey
                                        original porter of SP for the Mac
                                          Anton_S
                                          Hello Kevin,
                                          I haven't been working on SketchyPhysics in a while, but I would appreciate the 64bit version of the newton static library and more importantly the source to newton 1.53. It is good that you have the Mac side going as I have relatively no experience compiling and running libraries on Mac OS X. You could send the files to anton.synytsia@gmail.com via google drive or any other desired storage and I would inspect it from there.
                                          Anton
                                          • F Offline
                                            faust07
                                            @Anton_S: "However it's worth a try. I'll keep it posted." πŸ‘
                                            @willeykj: "Let me know how to get it to you and we can keep moving." πŸ‘
                                            • 11
                                            • 10 / 11
