    SketchyPhysics 3.5.6 (26 January 2015)
    213 Posts 53 Posters 351.1k Views 53 Watching
    • L
      Lumenous1
      Thanks Anton_S
      Very good proof of concept. I'll have a go at testing settings and models and let you know how I get on. Generally our earthquakes are fault slippage in a north/south direction so one piston is fine as I can change the orientation of the object depending on how it would be exhibited. The tricky bit is modeling for any uplift during a p wave event. Maybe a single pulse piston in the up-down direction?
        Anton_S
        Here is an example of earthquake left/right and up/down movement: sp_earthquake.skp You can adjust oscillation speed/length by adjusting slider properties. Do that by opening SP UI, selecting the desired slider joint, and editing properties.
        • P
          PituPhysics
          SketchyPhysics 3.6 is available this link: http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=62453
          • mknorrM
            mknorr
            I want to thank Chris for this amazing plugin. πŸ‘
            I do have a couple of wishes for a future release. πŸ˜„
            1. Support for 64 bit Sketchup
            2. Support for GPU number crunching monsters like CUDA.
            Thank you again and where do I donate to your cause?
            Cheers,
            Manfred
            • K
              kpalasrinne
              I'm using Sketchup 2015 and don't seem to be able to install this program. Should it work? If not, what similar physics programs are out there?
              • mknorrM
                mknorr
                My understanding is that 64 bit SketchUp isn't supported.
                • B
                  beeker
                  Presumably an x64 version is on its way, but can anybody provide a date on when?
                  Think I'll have to revert to a previous 32bit version until they do 😞
                  • H
                    huntfortegmail.com
                    Is there a timeline for development of a SketchyPhysics version that is compatible with Sketchup 2015 64 bit? Thanks. Tom
                      Mrtapo8
                      Hey guys exsit version for skethcup 2015 please ?
                        Mrtapo8
                        Hello can i ask if is possible to make with this plugin also working twine iam trying and trying but it is still fixed like pipeline.
                        Thank you !!!
                          dgimagge
                          Hi everyone, I am new in SketchyPhysics.
                          I don`t know if this is the best forum to ask help for my question.
                          Sorry if not, and please tell me where is the best place.
                          This is my question:
                          I installed SketchyPhysics in Sketchup 8 (Windows 32 bits).
                          I follow the tutorials but at the first test I found an error that has me stopped:
                          I create a box and another copy over that.
                          Mark "static" to the bottom box.
                          Put a hinge in one border (left or right) in the middle edge of both boxes.
                          Joint the hinge with the bottom box.
                          Group the upper box with the hinge.
                          And when I click in "play", the upper box fall down rotating from the hinge and fall through the bottom box.
                          I tried to do a lot of times and always the same result.
                          Is like that when I assign the "parent" to the hinge to rotate, that parent box become NO solid.
                          Help please. Thanks.
                            Anton_S
                            Dgimagge, to prevent bodies connected by joints from passing through each other, select the joint, open SketchyPhysics UI, and enable the "ConnectedCollide" checkbox option. By default, this option is disabled.
                              dgimagge
                              Anton_S, thank you so much. Thats the key.
                              I wonder why in any tutorial teach that !!!!
                              Thanks again.
                              • romi63R
                                romi63
                                Well,
                                February 2016, Major SketchUp update (2016) out up and running but still no word on the 64 bit version of this very useful plug-in.
                                I tried to install it anyway, but obviously not being compatible with a 64 bit version, it gave me a bunch of errors and doesn't load....
                                If there was a turn around about this I should found it by now..
                                Just hoping a 64 bit version release will be out soon.
                                Thank you.
                                • G
                                  GreyMatter
                                  Hi there, can someone please help me answer a very simple question. Is SP compatible with SU 2015 Pro on a Macbook running OSX 10.9.5?
                                  I've expanded the SP zip and dumped the contents into the Plugin folder associated with SU2015. SketchyPhysics is visible in the extensions tab found under File/Preferences etc but nothing relating to SP comes up in the toolbar. I have also tried the same process with my previous versions of sketchup 2014 and 8.
                                  Am I doing something wrong or does SP just not work on Mac?
                                  Thanks in advance
                                  Matt
                                  • G
                                    gepponline77
                                    I've just downloaded the new version of Sketchup Make, installed sketchyphisics and all seems to work, but if i try to edit joint setting nothing happen.
                                    I right click on a joint, select "joint settings" and i expect a widows appear (i used this in an old version) but no window appear and i don't know which is the problem. Is there a way to have a debug of it?
                                    thank you!
                                      jumpjack
                                      @anton_s said:
                                      SketchyPhysics is a real-time physics simulation plugin for SketchUp created by Chris Phillips.
                                      See extended versions maintained by PituPhysics: http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=62453
                                      SP 3.5, the unofficial release, comes with many bug fixes
                                      SketchyPhysics 3.7.1
                                      SketchyPhysics 3.7.1 Release date: December 23, 2015. Copyright Β© 2009-2016, Chris Phillips
                                      It remains just for 32-bit SketchUp to use.
                                      I'm a bit confused...
                                      V.3.2 was the last one from Chris Phillips, now stopped?
                                      Than a new branch named "3.5.x" was started? By Anton_S ?
                                      Then a NEW branch named "3.7.x" was started? By PituPhysics? Or this is the continuation of 3.5?!?
                                      What does "It remains just for 32-bit SketchUp to use" mean? That a 64-bit version exists?
                                      3.5.x branch.
                                      3.7.x branch
                                        sekramer10
                                        Hello,
                                        Just downloaded SU 2016 64 bit. I was looking for a physics simulator, it seems this is the only one so far. But it doesn't install on SU2016 64 bit? Will there be a new version soon? I need it now.
                                        Thanks.
                                        • chriC
                                          chri
                                          @sekramer10 said:
                                          Hello,
                                          Thanks.
                                          hi sekramer10
                                          Perhaps , you can use MSPhysics by Anton
                                          link here :
                                          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56852
                                          Chri
                                            Anton_S
                                            I received the C++ source of SketchyPhysics and been looking over it for a while now. I tried compiling it under 64bit but did not succeed. SketchyPhysics source is shipped with the 32bit version of the Newton 1.53 static library however not with the 64bit version. In order to compile SketchyPhysics under 64bit, I would need to have a 64bit version of the Newton 1.53 static library, which would require recompiling the source of Newton 1.53 under 64 bit configuration. The problem is that SketchyPhysics source does't comes with the source of Newton 1.53, as well as, the source of Newton 1.53 is no longer available on the internet. This meanders my ability to compile SketchyPhysics under 64 bit. I could upgrade SktechyPhysics to use newer versions of newton, but they could change the way older SketchyPhysics models work. Not to mention the problems that could come upgrading SDL libraries and all the adjustments that would have to be made in order to compile SketchyPhysics under Mac OS X. However it's worth a try. I'll keep it posted.
                                            • 11
                                            • 10 / 11
