    Layout Plan/Section Linework Colour Change?
    layout
    5 Posts 3 Posters 1.2k Views 3 Watching
    • brettsichellodesignB
      brettsichellodesign
      Sketchup Layout Linework Colour Change ExampleWhen applying a material on one element in my Sketchup model I some how managed to apply that material to the entire Sketchup model. In Layout, I have plans and sections set up with the heavier section cuts lines now showing up as cyan instead of black.
      I've tried selecting the entire model, all of the groups and components, linework, etc. and adjusting the colour to "default" using "Entity Info" but no luck with that.
      Anyone come across this before and know the solution?
        You might try deleting the material from the In Model library and then apply it again to the one entity you originally intended.
        • KrisidiousK
          Krisidious
          One work around would be to delete that texture... that will send all materials back to default on those surfaces.
          By: Kristoff Rand
          • KrisidiousK
            Krisidious
            🤣 Can't beat him...
            By: Kristoff Rand
              brettsichellodesign
              Weird, I responded to this last night using "quick reply" but it must not have posted. Anyways, I couldn't delete the texture but what I did was simply adjust the RGB to black for that one material and that worked perfectly! Thank guys, really appreciated!
