    Calculate painting area
    6 Posts 4 Posters 649 Views 4 Watching
      dieter10
      Hey,
      Is there a quick way or plugin to calculate the surface area from an object (for ex. a railing). It should be very usefull for me to know how many hours/paint we need for a job.
      • T
        TECHDAVE02
        If made up of components a simple 1.select all surfaces of components
        2.then X by the number of each component
        3.total it up and Bobs your uncle total area.
        • sdmitchS
          sdmitch
          @dieter10 said:
          Hey,
          This should do it.
          Usage: Plugins>SDM Tools>Face Tool>Area of Faces
          Area of Faces.rb
          http://sdmitch.blogspot.com/
            dieter10
            @sdmitch said:
            @dieter10 said:
            Hey,
            This should do it.
            Thanks for your answer. I tried out an came to the conclusion that it takes all the "white" (default) sides of a face. But the problem is that all off my construction drawings are tubes, and they have an inner side that does not need to be painted. So what i did: use the plugin to calculate the area, divide it by 2. And mulitply it by *1,2. And thats quite near to the reality. Is there anyone with a better solution ?
            • panixiaP
              panixia
              i would strongly reccomend to give a look at fredo tools plugin.. it has a couple of tools to deal with area labels/material/reporting/flipping/painting and other useful stuff. the most of theese tools also can operate on group and subgroups without having to open them for editing..
              404 Not Found
              (sketchucation.com)
              you also need this additional library to have it working properly
              404 Not Found
              (sketchucation.com)
              hope this can help πŸ‘
              • sdmitchS
                sdmitch
                If the tubes happen to be components, edit any instance and remove all surfaces not to be painted. Or if the surfaces to be painted have a unique texture applied, then that could be used in the search to select only those faces.
