    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 53.9k Views 40 Watching
    • pbacotP Offline
      Oh. Those are connected. Just multiple connected paths. I guess it could work. PB has directionality. As you know after applying to a path you can switch the direction and orientation in different ways. One way may not apply to all paths selected.
      Of course we are comparing a $40 SU plugin to 3ds max.
      @rv1974 said:
      @pbacot said:
      @whaat said:
      @rv1974 said:
      @whaat said:
      @rv1974 said:
      I wish the Author will overcome (in the near future) the biggest limitation:
      only connected edges are accepted as profile path.
      NB: Dudes leaf through the Help pages. This is really thermo-nuclear power plugin!
      Thanks - but how would you propose that it should work to determine the path?
      By pre-selecting the edges.
      Its implemented in 3ds Max for ages:
      One 'top' spline entity can incorporate numerous not connected splines.
      OK, so you want to be able to select multiple polylines (not connected to each other) prior to building along path? That feature will probably come eventually...
      How would the plugin know what edge is first and what to do between disconnected edges? And doesn't PB-1 do this, but separately apply profile to each edge?
      • panixiaP Offline
        panixia
        that's a good point 😆
        actually 3dsmax railing itself doesn't place nowere near to the flexibility of PB on many other aspect.. you should add 200€ railclone to use custom parts and fine-tune every aspect such as PB does (well actually that's way more powerful)
        • W Offline
          Whaat
          @pcmoor said:
          Thanks Dale,
          First, "Whaat" a great plugin!
          However when using the PB Quantifier, the report shows the shorter measure of a cut sheet, is it possible to show the bounding box measure as a alternative or check?
          [attachment=0:39kov7e0]<!-- ia0 -->cut sheet measure.JPG<!-- ia0 -->[/attachment:39kov7e0]
          Hi pcmoor,
          Did you create that object with Profile Builder? If so, the length should be based on the length of the underlying path. Using the bounding box to calculate length will not work on a Profile Member composed of multiple segments.
          • W Offline
            Whaat
            @raineysky said:
            I'm getting this error while trying to download the trial.
            Hi Raineysky,
            If you (or anyone else) is getting this message, please contact the SketchUp Extension Warehouse team here:
            Attention Required! | Cloudflare
            (help.sketchup.com)
            Please follow this link for complete instructions on installing purchased extensions:
            http://help.sketchup.com/en/article/3000059
            Thanks for reporting this. I am told that the EW team is working to resolve this issue.
            Dale
              pcmoor
              @whaat said:
              Hi pcmoor,
              I created the object using PB2, then used the trim to surface tool, when the surface is within the length of the object, this produced a result where the PMPI is the same length as the short point of the cut. However if i place the cutting surface outside the object the "trim to face tool" extends the object and the PMPI is the same as the long point of the cut.
              so this resolves my issue to create a exact overall cut length. provided I use the extend method
                raineysky
                Whaat,
                I reported it to the link you provided.
                Thank You,
                Paul
                • jujuJ Offline
                  juju
                  @juju said:
                  I think the point is that the price advertised should include taxes.
                  Paypal not supported? That's unfortunate.
                  Why not have it available on Smustard.com as well?
                  yeah well, so I caved, I bought this minutes ago, no taxes on my billing ($37.50 total).
                  wondering if i can resell Profilebuilder I bought years back through Smustard?
                  • david_hD Offline
                    david_h
                    So. . .how does one upgrade from the trial to the purchase. The pullout doesn't seem to have a license or "purchase" tab. Also, I can't find "Profile Builder 2" in the Ext. WH anymore. can somebody help me on this. Also, there seemed to be some chatter on this thread about purchasing issues. Have those been resolved?
                    Thx,
                    David_H
                    • W Offline
                      Whaat
                      Thx,
                      David_H
                      Hi David, first un-install the Trial, then follow these instructions:
                      (help.sketchup.com)
                      • W Offline
                        Whaat
                        This issue should now be fixed thanks the hard-working EW team!
                        If you have had this error, please try installing again - it should now work.
                          raineysky
                          Dale,
                          I got the same error but this time I went out for a while and when I came back it was installed....Also had trouble finding the plugin, even with search. I sent a message in to let them know. Just had a few minutes to play with PB2 but it looks awesome!
                          Thank You,
                          Paul
                            AcesHigh
                            Has anyone tried to use Profile Builder 2 to build curtain walls?
                            I guess we could set components for mullions and such... not sure how to make the glass (specially if you want single planes as glass to render using "architectural glass" material (instead of using heavier materials for glass where the render will calculate light dispersion and such)
                            I guess vertical mullions as components and horizontal mullions AND glass as profiles?
                            • JClementsJ Offline
                              JClements
                              A few quirks.
                              I kind of expected issues 2 and 3 to happen, but issue 1 is a surprise (I think it is fixable).
                              trim to solid issue.skp
                              • W Offline
                                Whaat
                                @jclements said:
                                A few quirks.
                                [attachment=1:eaqqxjit]<!-- ia1 -->trim to solid issue.jpg<!-- ia1 -->[/attachment:eaqqxjit]
                                Thanks John - I'll take a look
                                  rv1974
                                  Whaat, If I'm not mistaken there's important feature missing- Follow'n'Keep mode:
                                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=16465
                                  Would it be possible to add this humble check box (in PB andAssembler Dialog) in near future?
                                  • W Offline
                                    Whaat
                                    PB2 is designed to make this process automatic. For non-planar paths (like a helix) PB2 will use a method similar to Follow'n'Keep. Otherwise, it works similar to the SketchUp follow-me tool.
                                    Are you finding this to be a significant limitation?
                                      rv1974
                                      For instance, tilted curb stones on sloped roads\ramps look weird. There are lot of similar cases- 7 pages of vivid 'thank you' discussion surely prove it.
                                      • utilerU Offline
                                        utiler
                                        Hi Dale, not sure what's going on here: for some reason a profile from either a face or polyline won't execute....?
                                        PB2-issue.wmv
                                        Just Curious...
                                          rv1974
                                          try to remove smartdrop.rb
                                          • W Offline
                                            Whaat
                                            Yes, it looks like you have a conflicting plugin installed (possibly smartdrop). Open the Ruby Console Window and checked for errors. It should give you a clue about which plugin is causing the problem.
                                            • 11
                                            • 4 / 11
