    Layout is not showing a section cut model
    4 Posts 2 Posters 539 Views 2 Watching
    • 4 Offline
      4hotshoez
      I created a Sketchup model in 2014 Make and just purchased 2015 Pro and opened the model and worked on it for a bit. I created a section plane and saved it in a Scene and enabled sections in the Style, BUT when I imported the model to Layout, the Scene would not show the cut or the section plane. I do not know how to make it cut the model as I had done in Sketchup. I need to dimension the section and share the info to a client. This is why I have paid for PRO. What might be going on?
      PintoBunk04.skp
      SU 2016
      Win10 (64-bit), ASUS ZenBook Pro UX501J
      i7 2.6 Ghz, 16 GB RAM, 64-bit, 512 SSD
      NVIDIA GeForce GTX 960M, VRAM 2 GB
      32" Samsung SD850
        When I opened your file I found the section cut was turned off for the BunkSection scene and the style showed as changed but not updated.
        After turning on the section, the style showed as updated. I updated the scene, saved the SKP file and sent it to LO. The section cut shows just fine. I think you needed to update the scene so the style with the section cut turned on is active.
        There are some unneeded styles in your your In Model library that you could purge.
        • 4 Offline
          4hotshoez
          Thanks for looking into this for me. I must have missed a step, because I thought I did all of that. Nevertheless, I was having server update issues too so...
          SU 2016
          32" Samsung SD850
            So, what? Is there a question, still?
